Cyberaudio ec1000?
Vizitator Vittorio pgn
Hi to all..i can't find any notice about technical informations of Cyberaudio ec1000 power amph...knows or got it anyone??? Don't need electrical scheme, but output power, power for channel, impedance, ecc.. thanks, Vitt
  • Răspunsuri 9
Hi Vittorio and welcome to our forum!
From 2x32V~ you will not get more than 120W into 8 ohms. I will say most likely 100w. I would not go lower than 4ohms for maximum reliability.
In case that there are more secondary windings, the power will be much more.
I am suspecting the latter since from the looks of the output stage, it resembles a class H.
If so, you will have 2x60V therefore the theoretical limit (assuming no losses) would be around 400w into 8R. The actual results would probably be less, assuming a 15V PSU sag you would be left with ~250W.
Hint: next time when you are shooting pictures, make sure that the writing from the tags is readable.
