Conectare Ecran 3.2 " LCD+Touch Screen la PIC
Vizitator cpu54321
Vizitator cpu54321
Buna ziua
De curand am achizitionat un ecran LCD de 3.2 " cu Touch Screen si slod SD....
am tot cautat modalitati de conectare si programare dar nu am gasit nimic din ce sa inteleg ceva.....
sper sa gasesc pe cineva care a mai lucrat cu un asemenea ecran, dispus sa-mi dea ceva idei
atasez doua poze si descrierea ecranului
Doresc ca softul sa-l realizez in FLOWCODE 5 daca se poate
MULTUMESC
3.2inch, Resolution:240*320, with TFT touch screen
Display driver chip: ILI9341
Touch screen driver chip: XPT2046
3V voltage regulator
Screen: 65K Colors
Display Interface: 16bit parallel interface, support 6800 and 8080 Bus Interface, support FSMC Bus Interface of STM32
Touch screen interface for SPI interface is SPI interface, less cable, easy drive
Onboard low voltage large current LDO voltage stability, compatible with 5 V and 3.3 V power supply
Onboard PWM backlight control circuit, can support IO control and PWM dimming control
With SD card slot
Reserved SPI FLASH welding plate, can extend welding character chip
Support horizontal display and vertical display, support screen division display
Supports 262000 RGB color display
With 172800 bytes of the graphics display data storage area
Compatible with the punctual atoms series interface development board
SMT production, Stable and reliable hardware
  • Răspunsuri 1
  • Mondan
 salut
poate vor raspunde mai multi dupa ce am scris si eu.
Am vazurt ca acel display e folosit in general cu Arduino.
E totusi mult de munca si nu te sfatuiesc sa incepi asa.
Cumpara un asfel de display cu kit-ul complet, si programul. Poate la Mikroe. Si apoi le cauti in magazinele romanesti.
