cumpar tranzistor 2SB558 Toshiba
Va salut, stimati membri ai acestui forum. Am nevoie de tranzistorul Toshiba 2SB558. As fi foarte recunoscator aceluia care m-ar putea ajuta in acest sens. Imi e necesar pentru readuceea la viata a unui amplificator audio foarte drag. Va multumesc.
  • Răspunsuri 3
  • scoro2000
  • BUGHIU
  • Nostalgic
  • 3 săptămâni mai târziu...
Nu ma pricep la electronica. Stiu doar ca am nevoie de acest tranzistor pentru a repara un amplificator. Probabil ca va functiona si cu echivalenti, insa caut originalul.
Type Designator: 2SB558
Material of transistor: Si
Polarity: PNP
Maximum collector power dissipation (Pc), W: 60
Maximum collector-base voltage |Ucb|, V: 100
Maximum collector-emitter voltage |Uce|, V: 100
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 7
Maksimalna temperatura (Tj), °C: 150
Transition frequency (ft), MHz: 4
Collector capacitance (Cc), pF: 400
Forward current transfer ratio (hFE), min: 40
Noise Figure, dB: -
Package of 2SB558 transistor: TO3
Editat de scoro2000
Cu BD246C sau 2SA1294 nu ar merge ''scula''?!?!
Posted Image Posted Image BD246C TRANZISTOR SI-P 115V 10A 80W TO-3P -ROHS-
37890 Tip capsula: TO-3PN, Producator: Inchange Semiconductor, Polaritate: PNP, Conectare: THT, ROHS: da, Tensiune (Vcb): 115V, Tensiune (Vce): 100V, Tensiune max.: 100V, Tip tensiune: -, Putere: 80W, Curent max.: 10A, Temperatura max.: 150°C   RON 3,86
RON 8,20
Posted Image
>20 Posted Image Posted Image     Posted Image Posted Image 2SA1294 TRANZISTOR P 230V 15A 130W TO-3P -ROHS-
152933 Tip capsula: TO-3P, Producator: Allegro Sanken, Polaritate: PNP, Conectare: THT, ROHS : da, Frecventa: 35MHz, Tensiune (Vcb): 230V, Tensiune (Vce): 230V, Tensiune max.: 230V, Putere: 130W, Curent max.: 15A, Temperatura max.: 150°C
SANKEN RON 10,04
RON 20,66
Posted Image
