Toader Postat Noiembrie 9, 2014 Partajează Postat Noiembrie 9, 2014 Am vazut pe net ca unii au incercat bass reflex, altii BLH.Ce parere avet despre parametrii difuzorului?Asta e proiectul firmei http://www.ciare.com/pdf/Progetti/MyPersonalSpeaker/h07.pdf http://consumer.ciare.com/?altoparlanti=ph250 Difuzorul e fabricat din 85 incontinuu.A avut succes la public. &tbm=isch&imgil=ncYbr8Aa70moOM%253A%253BIOaC8mtBrAFkVM%253Bhttp%25253A%25252F%25252Fwww.audiocostruzioni.net%25252Fforum%25252Fviewtopic.php%25253Ff%2525253D21%25252526t%2525253D776%25252526start%2525253D0%25252526view%2525253Dprint&source=iu&pf=m&fir=ncYbr8Aa70moOM%253A%252CIOaC8mtBrAFkVM%252C_&usg=__jDafkfA2_PXO61O2fNQJh1_RLBc%3D&ved=0CDEQyjc&ei=oNZfVJC1Is7kap20grAB#facrc=_&imgdii=_&imgrc=ncYbr8Aa70moOM%253A%3BIOaC8mtBrAFkVM%3Bhttp%253A%252F%252Fdigilander.libero.it%252Fgiovannidefilippo%252Fmonoviaalbertob%252FtrombaconCH252oPH250.jpg%3Bhttp%253A%252F%252Fwww.audiocostruzioni.net%252Fforum%252Fviewtopic.php%253Ff%253D21%2526t%253D776%2526start%253D0%2526view%253Dprint%3B2000%3B1200'>https://www.google.ro/search?q=ciare+ph250+progetti&sa=X&biw=1280&bih=&tbm=isch&imgil=ncYbr8Aa70moOM%253A%253BIOaC8mtBrAFkVM%253Bhttp%25253A%25252F%25252Fwww.audiocostruzioni.net%25252Fforum%25252Fviewtopic.php%25253Ff%2525253D21%25252526t%2525253D776%25252526start%2525253D0%25252526view%2525253Dprint&source=iu&pf=m&fir=ncYbr8Aa70moOM%253A%252CIOaC8mtBrAFkVM%252C_&usg=__jDafkfA2_PXO61O2fNQJh1_RLBc%3D&ved=0CDEQyjc&ei=oNZfVJC1Is7kap20grAB#facrc=_&imgdii=_&imgrc=ncYbr8Aa70moOM%253A%3BIOaC8mtBrAFkVM%3Bhttp%253A%252F%252Fdigilander.libero.it%252Fgiovannidefilippo%252Fmonoviaalbertob%252FtrombaconCH252oPH250.jpg%3Bhttp%253A%252F%252Fwww.audiocostruzioni.net%252Fforum%252Fviewtopic.php%253Ff%253D21%2526t%253D776%2526start%253D0%2526view%253Dprint%3B2000%3B1200 Link spre comentariu
Toader Postat Noiembrie 10, 2014 Autor Partajează Postat Noiembrie 10, 2014 http://www.steo.it/archives/63/nuovo-anno-nuovi-diffusori http://www.tforumhifi.com/t14403-ph-250-a-tromba-posteriore-progetto-e-foto Link spre comentariu
VTP Postat Noiembrie 10, 2014 Partajează Postat Noiembrie 10, 2014 Mai avantajos ar fi un Voigt: - ar ajuta mai mult la joase; - BLH -ul este poate cea mai buna solutie privind castigul la joase, dar implica dimensiuni mai mari decat Voigt-ul. Difuzoarele de acest tip asigura un bas f.corect, mai putin "pufos"! Pe inalte nu se simte neaparat nevoia de a ajunge la 20 kHz, dar se poate simplu, chiar si cu un piezo de calitate (Motorola) si un condensator MKP. Link spre comentariu
Toader Postat Noiembrie 19, 2014 Autor Partajează Postat Noiembrie 19, 2014 Unde as pute gasi PDF-urile cu Revista Tehnium?Intr-un numar vechi un prieten mi-a spus ca ar fi un proiect VTP ptr acest difuzor.Cineva din Bucuresti are asemenea incinta cu acest difuzor si e satisfacut de rezultate. Ok.Am gasit.Sper sa fie printre ele si ce caut. Link spre comentariu
klauss00 Postat Septembrie 12, 2015 Partajează Postat Septembrie 12, 2015 Ati reusit sa faceti incintele? Cum suna? Link spre comentariu
Toader Postat Septembrie 24, 2015 Autor Partajează Postat Septembrie 24, 2015 (editat) Inca nu am ajuns sa le fac.O sa le vand probabil ptr ca mi-a aparut o oferta foarte buna ptr HW321 tot Ciare.Ptr cei interesati, le las ieftin.Sant in cutie, doar inspectate, noi noute.Cine are chef deVTP sau BLH, merita incercat. Editat Septembrie 24, 2015 de Toader Link spre comentariu
klauss00 Postat Septembrie 24, 2015 Partajează Postat Septembrie 24, 2015 Aveti MP Link spre comentariu
Vizitator florinbarabas Postat Septembrie 28, 2015 Partajează Postat Septembrie 28, 2015 Inca nu am ajuns sa le fac.O sa le vand probabil ptr ca mi-a aparut o oferta foarte buna ptr HW321 tot Ciare.Ptr cei interesati, le las ieftin.Sant in cutie, doar inspectate, noi noute.Cine are chef deVTP sau BLH, merita incercat.Ce oferta buna pentru Ciare ai primit? Link spre comentariu
