adam stefan Postat Octombrie 24, 2014 Partajează Postat Octombrie 24, 2014 va salut ma ajutati va rog cu sm la un tv thomson 21mg130 multumesc o zi buna Link spre comentariu
BUGHIU Postat Octombrie 24, 2014 Partajează Postat Octombrie 24, 2014 1. Service Mode Access 1.1 With the RCU, switch the TV set into the “Standby’ mode. 1.2 Switch “Off” the TV set by mains supply switch (wait until LED is dark). 1.3 Whilst pressing the “Magenta (text)” button on the RCU switch “On” the TV set using the mains switch. Continue to press the “Magenta (text)” button until the Service-setup Sub-menu appears. Link spre comentariu
adam stefan Postat Octombrie 24, 2014 Autor Partajează Postat Octombrie 24, 2014 1. Service Mode Access 1.1 With the RCU, switch the TV set into the “Standby’ mode. 1.2 Switch “Off” the TV set by mains supply switch (wait until LED is dark). 1.3 Whilst pressing the “Magenta (text)” button on the RCU switch “On” the TV set using the mains switch. Continue to press the “Magenta (text)” button until the Service-setup Sub-menu appears. multumesc e ok o zi buna Link spre comentariu
