Liviu M Postat Iunie 9, 2016 Partajează Postat Iunie 9, 2016 A, pai e mai simplu un link direct la site-ul oficial grbl (l-am mai pus eu sigur de cateva ori pe forum). Link spre comentariu
vilisie Postat Iunie 19, 2016 Partajează Postat Iunie 19, 2016 Functioneaza cu adaptor usb-paralel, dar cu unul construit dintr-un ARDUINO UNO care are incarcat un firmware GRBL, soft open source specializat pe interpretarea codurilor G. As atasa si un fisier "pdf" cu acest adaptor de 5$, dar spre rusinea mea nu ma prind cum se face asta. Poate cei interesati sa ma lumineze... Multumesc lui nickrvl ca m-a desteptat sa dau un scroll, nu vedem butoanele ale de nas! Revenind la oile noastre atasez un adaptor fabricat de GOCNC.DE gandit si fabricat exact pentru necazul vostru. Neamtul a avut proasta inspiratie sa-l pozeze si dezasamblat, asa ca este usor sa observam pe ce hard se bazeaza acesta. Nu comentez pretul (nesimtit) la neamt. Va dau si un link asa ca sa vedeti in poze cam despre ce este vb. http://www.ebay.com/itm/172221520565?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT. Americanu zice: Fix your cheap eBay CNC router/engraver for less than $10. This shield allows you to use the USB to talk to a db25 based CNC machine. What is it? The Arduino G25 Shield combined with an Arduino UNO compatible board running GRBL, allows you to connect a CNC via the db25 LPT parallel port. Why did you make it? I purchased an inexpensive CNC on eBay. The software they recommended was expensive or was free with limitations and was jittery. Moving the processing of the gcode to the Arduino allows for smoother timing that is not based on cpu cycle count. What makes it special? Now to run your CNC all you need is a 'G Code Sender'. Something as simple as a terminal window is enough to send g code commands. What do you get? You get the PCB, male headers and Female db25 right angle connector. This is a kit, you will need to solder the connectors. What you will need... Arduino UNO compatible board USB Cable LPT cable (Female to female like the one that comes with the CNC machine) 'gcode sender application' of your choosing. (If you don't know one, Google it) Use Grbl v0.9 https://github.com/grbl/grbl/wiki/Connecting-Grbl This is a video of the CNC router running on the LPT Port. https://www.youtube.com/watch?v=uZJFjWCpabw This video shows the same CNC running with the shield. https://www.youtube.com/watch?v=dm-AcufNaw0 Link spre comentariu
Liviu M Postat Iunie 19, 2016 Partajează Postat Iunie 19, 2016 Cum ziceam si in postul anterior, grbl merge foarte bine pentru contolul unui cnc, dar in cate stiu eu nu direct din mach3. Si daca citesti primul post, asta a fost cerinta. Ca altfel, cu bCNC sau ugs l-am folosit si eu si functioneaza foarte bine, da' nu e ce s-a cerut in primul topic (adica suntem off-topic ). Link spre comentariu
puriu Postat Iunie 19, 2016 Partajează Postat Iunie 19, 2016 Sistemele de operare moderne, de la W 98 SE incoace, nu permit accesul direct al porturilor paralele prin comenzi de intrare-iesire. Sunt necesare drivere de dispozitiv sau programe non-Microsoft pentru "pacalirea" SO. Aceste programe sunt specifice limbajelor de programare si sistemelor de operare, de aceea nu exista inca o solutie unica de deblocare a interfetei paralele. Internetul poate oferi solutii, pe incercate. Link spre comentariu
Liviu M Postat Iunie 19, 2016 Partajează Postat Iunie 19, 2016 In topicul asta e vorba chiar de ceva mai complicat - emularea unui port paralel printr-un dispozitiv conectat pe USB. Si asta in mod transparent pentru programele care folosesc portul. Link spre comentariu
Administratori Badman Postat Iunie 19, 2016 Administratori Partajează Postat Iunie 19, 2016 Placa asta merge sigur http://www.hi-end.ro/index.php?dispatch=products.view&product_id=15468 Link spre comentariu
dany_cta Postat Iunie 23, 2016 Partajează Postat Iunie 23, 2016 Nu infipta intr-un laptop. Nu exista USB-Paralel care sa mearga din cauza modului de functionare al portului USB. El face buffering, ceea ce din start omoara posibilitatea de transmisie paralela in timp real. Merg in schimb placi PCI cum este cel din postul precedent daca vorbim de un calculator in care se poate monta, la laptop-uri merg placi PCMCIA-to-parallel, deci orice care este direct conectat, nu trece prin portul USB. Personal nu agreez GRBL-ul pentru ca vreau sa am acces la mai multe functii in timpul prelucrarii. Recomand gasirea unui calculator ieftin si stabil cu port paralel si gata. Link spre comentariu
Administratori Badman Postat Iunie 24, 2016 Administratori Partajează Postat Iunie 24, 2016 Sunt si solutii USB sau Ethernet pentru CNC dar la cat costa mai bine un calculator second hand cu paralel... sau dece nu o solutie fara PC Link spre comentariu
Dan57 Postat Iunie 24, 2016 Partajează Postat Iunie 24, 2016 Nu stiti, daca iau un adaptor usb-port paralel functioneaza mach3 prin el? Sau trebuie neaparat sa aiba calculatorul portul? In concluzie, nu exista asemenea adaptor, obligatoriu ca acel calculator sa aibe un port paralel ca Mach3 sa functioneze. Link spre comentariu
teleflyer Postat Iulie 20, 2016 Partajează Postat Iulie 20, 2016 Sunt si solutii USB sau Ethernet pentru CNC dar la cat costa mai bine un calculator second hand cu paralel... sau dece nu o solutie fara PCȘtii o soluție fara pc care sa meargă bine si sa nu coste prea mult ? Link spre comentariu
dany_cta Postat Iulie 20, 2016 Partajează Postat Iulie 20, 2016 (editat) GRBL, te costa vreo 20lei arduino nano si cateva fire lipite. Nu merge mach3 dar merge sa trimit gcode la cnc prin usb. Editat Iulie 20, 2016 de dany_cta Link spre comentariu
Administratori Badman Postat Iulie 20, 2016 Administratori Partajează Postat Iulie 20, 2016 uite aici unu http://chinaplccenter.com/offline-cnc-controller-shaoge-smc4-4-16A16B.html Link spre comentariu
