Achizitie amplificator + boxe
Salut,
As vrea sa achizitionez un ampificator si 2 boxe.. poate m-ati putea sfatuii :d
1. Amplificatorul
The t.amp TA450 MK-X power amplifier - 2x 200W/4Ohm, 2x 125W/8 Ohms, 0.775V input sensitivity, 40V/µs slew rate, thomann 300:1/1kHz/8 Ohms damping factor, short circuit protection, limiter, THD <0.05%/1kHz, jack & XLR in, Speakon & binding posts out. 19" rack/2U. Dimensions Abmessungen 483 x 103 x 475 mm, Weight 13,3kg, Very good quality/value ratio!
2. Boxa
Behringer Eurolive VS 1520, Fullrangespeaker 15" + Electro-Dynamic Driver, 150W/600W RMS/Peak, Pole Mount, 1/4" Jack Connectors, Frequency Range thomann 50Hz - 20kHz, 8Ohm, 80° x 40°, Dimensions 455 x 685 x 465mm weight 21,9Kg, Optional matching cover available ( order code: 275180)
Dar nu prea inteleg cu dimensiunile la boxa:
  • Răspunsuri 0
Zile populare
