dan cod Postat August 15, 2014 Partajează Postat August 15, 2014 Are cineva datasheetul astora?As cate doua perecchi si am inteles ca sunt ok .As vrea sa le pun intr-o sursa care e facuta cu 2N3055 dar cam dubioasa provenienta dupa cum arata capsula.Multumesc. Link spre comentariu
Rx-Tx Postat August 15, 2014 Partajează Postat August 15, 2014 (editat) KD607 Transistor Datasheet. Parameters and Characteristics. Type Designator: KD607 Material of transistor: Si Polarity: NPN Maximum collector power dissipation (Pc), W: 70 Maximum collector-base voltage |Ucb|, V: 80 Maximum collector-emitter voltage |Uce|, V: 80 Maximum emitter-base voltage |Ueb|, V: 5 Maximum collector current |Ic max|, A: 10 Maksimalna temperatura (Tj), °C: 150 Transition frequency (ft), MHz: 2 Collector capacitance (Cc), pF: Forward current transfer ratio (hFE), min: 30 Noise Figure, dB: - Package of KD607 transistor: TO3 http://alltransistors.com/pdfview.php?doc=kd501_kd502_kd503_kd601_kd602_kd605_kd606_kd607_kd3055_kd3442_kd3772_kd3773_kd4348_kd615_kd616_kd617.pdf&dire=_tesla Editat August 15, 2014 de Rx-Tx Link spre comentariu
dan cod Postat August 15, 2014 Autor Partajează Postat August 15, 2014 Multumesc . KU608?Oare chiar ar merge mai ok ca 2N3055? Link spre comentariu
Rx-Tx Postat August 15, 2014 Partajează Postat August 15, 2014 (editat) Nu stiu 608 insa am chinuit un KD607S original facut de Tesla si a fost peste asteptari. Era recuperat dintr-un Tv Diamant. Pinii baza si emitor sunt mult mai grosi ca la un 3055 care e recomandat la un curent de 3A. Comparat cu un 2n3055, kd607 e net superior. Eventual un KD503, asta e si mai potent, in foaia de catalog e trecut un curent de colector de 30A Se gaseau prin statiile RTM in modulul de alimentare Editat August 15, 2014 de Rx-Tx Link spre comentariu
dan cod Postat August 15, 2014 Autor Partajează Postat August 15, 2014 Am gasit prin sertare la mine 2 KD607S si doua KU608 absolut noi dinainte de 90 facute cred.Sursa in care vreau sa le pun este una liniara de 12A si are doi tranzistori 2N3055.Cred ca pana la urma voi pune KDurile.Intr-adevaa pinii sunt mai grosi ca la 2N3055. Link spre comentariu
misuraelectronic Postat August 15, 2014 Partajează Postat August 15, 2014 (editat) Eventual un KD503, asta e si mai potent, in foaia de catalog e trecut un curent de colector de 30A mai taie din ele , da-le dracu` . poate in visele matale erotice sa duca 30a ... ic-ul corect pentru kd503 este de 20 de amperi . referitor la intrebarea initiala , situatia sta cam asa... kd607 ... stie 80v / 10a / 70w . ku608 ... stie 250v / 10a / 70w 2n3055 ... stie 100v / 15a / 115w din cele de mai sus se deduce ca orice 2n3055 de fabricatie mbr bate la fund ambele tranzistoare tesla dpv al curentului ic maxim , precum si dpv al puterii maxime disipate si sta mai prost decit ku608 la vcbo maxim . acum , daca in aplicatia despre care discutam in context sint suficienti 10 amperi / tranzistor si 70w putere disipata maxim / tranzistor , este perfect adevarat ca orice kd607 sau ku608 bate la fund absolut orice 2n3055 fabricat de orice firma de pe aceasta planeta , din punct de vedere al fiabilitatii , desigur . TESLA RULES , ANYTIME AND ANYWHERE ! Editat August 15, 2014 de misuraelectronic Link spre comentariu
Rx-Tx Postat August 15, 2014 Partajează Postat August 15, 2014 mai taie din ele , da-le dracu` . poate in visele matale erotice sa duca 30a ... ic-ul corect pentru kd503 este de 20 de amperi . Asa e, am reverificat foaia de catalog si e 20A, nu stiu de ce am retinut eu 30, poate prea mult optimism Link spre comentariu
dan cod Postat August 16, 2014 Autor Partajează Postat August 16, 2014 Multumesc pentru raspunsuri.M-am lamurit. Link spre comentariu
Vizitator Postat August 16, 2014 Partajează Postat August 16, 2014 "U" indica de obicei tranzistor de baleiaj, vezi BU. Si IPRS avea BUR607 si BUR608 pt final linii tv Sport. Deci KU607 este de fapt BU607. Tranz pt baleiaj au beta mic, deci atentie la echivalare cu 2n3055. Compunere libera, nu dati cu pietre! Link spre comentariu
Kuki Postat August 16, 2014 Partajează Postat August 16, 2014 KU are in catalog beta intre 10-50 iar KD are >10 la 10A si >30 la 1A Link spre comentariu
Vizitator Postat August 16, 2014 Partajează Postat August 16, 2014 Dan poate face simplu niste masuratori. Sa puna o sarcina de 5-10A la 12V si sa vada la ce curent in baza se satureaza tranz.KD fata de KU Link spre comentariu
misuraelectronic Postat August 16, 2014 Partajează Postat August 16, 2014 (editat) "U" indica de obicei tranzistor de baleiaj, vezi BU. Deci KU607 este de fapt BU607. Compunere libera, nu dati cu pietre! lasati ca dau eu cu pietre , ca n-am nici o jena , mai ales atunci cind se publica gogomanii pe forum . avem asa... 1-- se aduce absolut degeaba in discutie tranzistorul ku607 , cind noi vorbim aici despre kd607 si despre ku608 . 2-- ku608 are vcbo maxim de 250 de volti...in concluzie..HELLO ...despre ce fel de baleiaj vorbim aici ? nici macar intr-un sport prapadit de 37cm , a /n nu poate fi folosit in baleiajul orizontal . este tranzistor final de sursa toata ziua si toata noaptea . spre edificare , iata si link-ul corect ... http://amapro.cz/datove_zdroje/stranky/mezni_hodnoty/katalog1_16.php 3-- ku607 stie 210v / 10a / 70w , iar bu607 stie 330v / 7a / 90w ...in concluzie , nu exista nici cea mai mica legatura intre cele 2 tranzistoare , cu exceptia faptului ca ambele sint tranzistoare cu siliciu si ca sint in capsula to3 . 4-- faza aceea subliniata cu rosu in link-ul din postarea precedenta n-are nici o legatura cu realitatea din teren . acela e un comentariu postat de un amator intr-ale pieselor si postata pe radiomuseum.org . aveam pretentii de la dl miticamy , nu ma asteptam sa muste chiar asa...orice timpenie postata pe net . Editat August 16, 2014 de misuraelectronic 1 Link spre comentariu
zal Postat August 16, 2014 Partajează Postat August 16, 2014 (editat) Nu mai confundaţi Ucb cu Uce la trz bipolari, 2N3055 nu ţine decît 60V sau chiar mai puţin, pînă la 25V în variantele cele mai slabe. Mai citesc şi copii pe aici... Editat August 16, 2014 de zal Link spre comentariu
remus68 Postat August 16, 2014 Partajează Postat August 16, 2014 Aceste imagini subliniaza cele mentionate de @misuraelectronic. Link spre comentariu
Vizitator Postat August 17, 2014 Partajează Postat August 17, 2014 (editat) 1)vorbeam despre baleiajul TV_AN portabile, alim de la bateria masinii. 2) ce a postat Remus confirma cele spuse de mine: KD si KU sant familii diferite. U--comutatie D-joasa frecventa La tranz U apare t/f de 0,5microsec iar frecventa de tranzitie este 26/min 9Mhz. Iar atentionarea mea era exact de acest tip--atentie, sant din categorii diferite si vedeti la ce parametrii nu ar putea corespunde. Nu am afirmat niciun moment ca nu merge la aplicatia lui Dan. Editat August 17, 2014 de Vizitator Link spre comentariu
