boxa de 50w
Vizitator catalin2187
salut...vreau sa fac un sw cu acest difuzor si nu stiu ce incinta sa folosesc ...cu bass reflex,sau inchisa,si cam ce dimensiuni ar trebuii sa aiba?ma gandeam sa folosesc pal de 16-18mm cu holsuruburi si aracet...ce spuneti?multumesc anticipat
Nominal Diameter(ins)10 Frequency Range(Hz)51-6K Sensitivity(db,1w/1m)91 Power Handling(w rms)100 Nominal Impedance(ohm)8 Resonance, Fs(Hz)51 Effective Piston Diameter (mm)210 Volume Vas(litres)42,2 Total Dynamic Mass, Mmt(gm)38,8 Total Q, Qts1,22 Mechanical Factor, Qms7,84 Electrical Factor, Qes1,44 BL factor, BL(Txm)6,87 Compliance, Cms(mm/N)0,25 Coil Inductance @ 1kHz, Le(mH)1,18 Baffle Cutout Diameter (mm) 230...............
http://www.telecomenzi.ro/index.php?off ... y&pid=3266
  • Răspunsuri 0
Zile populare
