Mirorr PDF
cristian_98
  • Răspunsuri 10
  • former_Alfred
  • cristian_98
  • pinky
  • one
Cu Acrobat Reader nu merge, încearcă cu Irfanview. Și există și unele imprimante la care ai în Properties opțiunea asta, dar la multe nu ai.
E plin Internetul de soluții, nu știu ce zici tu că ai căutat.
http://craftygoat.com/2006/11/printing_mirrored_text_on_any.html
1. Use your software
Many software applications have mirror-image functionality built in. For example, Microsoft Word or Publisher can do mirror image text through the use of their Word Art tool. Just create your text as WordArt, then use the Flip Horizontal tool. Photoshop also has a Flip Horizontal tool. If you're not sure whether your desktop publishing software supports mirror images, try searching its help files for "mirror image" or "flip horizontal."
2. Print to PDF
If your software doesn't support flipping objects, try the free pdf995 printer driver. It's a PDF generator, which means it takes your file (from Word, IE, etc) and "prints" or converts it to a PDF. Once you download and install the software, follow these steps to print a mirror-image item:
  • [*]Choose
PDF995 from the Printer Name drop-down. [*]Click the Properties button, and then the Advanced button. [*]On the Advanced Options page, expand the Document Options section, then the PostScript Options section. [*]Change the final list item to say Mirrored Output: Yes [*]When you tell it OK to print, it'll ask you where you want to save your PDF document. Pay attention to where you save it. [*]Two ads will pop-up (unless you splurge for the $9.95 paid version of the software). Just click Continue using the sponsored version on the first ad, and close the second. [*]Open your PDF file to see the mirrored (and, oddly, upside-down) output. [*]Print this to your printer and use it to transfer.
Editat de former_Alfred
O altă soluție simplă ar fi să faci o captură de ecran a imaginii din .pdf-ul respectiv, cu combinația de taste Alt+Print Screen. În acel moment vei avea în Clipboard-ul Windows-ului o copie a ferestrei active (Acrobat Reader, să zicem). Apoi creezi un fișier bitmap nou, cu click dreapta --> New --> Bitmap Image pe care îl deschizi cu Windows Paint (sau Edit din meniul de context). În acel fișier dai ”paste” sau Ctrl+V la imaginea din Clipboard și îl salvezi ca .bmp, ca .jpg, .gif sau orice altceva permite Paint. În felul ăsta vei avea o poză la care poți să îi dai ”Flip Horizontal” sau ”Flip Vertical”, ca să obții imaginea în oglindă. Acea poză poate fi mărită sau micșorată după dorință, iar mărimea capturii de ecran poate fi și ea ajustată, dacă te joci din zoom-ul de la Acrobat Reader.
Metoda asta ar avea avantajul că nu ai nevoie de nici un program nou, captura de ecran copiată în Clipboard cu Alt+Print Screen și prelucrarea imaginii în Windows Paint sunt realizabile cu componentele incluse în instalarea inițială de Windows.
  • 2 săptămâni mai târziu...
Ce inseamna "sa dai mirror" ? Sa printezi inversat sau sa transformi pdf-ul?
Daca driverul imprimantei tale nu iti ofera posibilitatea sa printezi in oglinda, atunci solutia este sa refaci pdf-ul cu un printer virtual, cum ar fi pdf995 sau CutePdf writer.
La mine e mai grav, eu am driver-ul PostScript instalat, dar nu văzusem opțiunea Mirror Image trecută pe ”No”.
Cred că mi-a rămas retarderul cuplat  :rade:
Cum e cu post scriptul asta , ca sunt in ceata . Inteleg ca e un format vectorial care are multe facilitati da nu am gasit nici un editor in care sa deschid fisiere din astea si sa editez textul si imaginile si sa salvez la loc.  Am inteles ca se face ceva cu gost-ul dar asta nu e vizuat si nu stiu ce comenzi are. Am citeva fisiere in post script dar nu le pot vedea .  irfanview nu ofera multe aici , si nici nu prea merge la mine. tot face figuri , nu stiu de ce.
