Vizitator overseas Postat August 23, 2014 Partajează Postat August 23, 2014 (editat) TESLA KF517 PNP silicon planar transistor intended as AF driver / switch: O schema cu acest tranzistor : http://www.volta.estranky.cz/clanky/blikace_-svitilny/tranzistorovy_prerusovac_blikac_s_zarovkou.html Editat August 23, 2014 de overseas Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 Un tranzistor COSEM ASY26 PNP germanium alloy transistor intended as switch in industrial / computing applications. Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 (editat) Tranzistorul de RF, SGS 1W 967.. Editat August 25, 2014 de overseas Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 Tranzistorul ROS92A (IPRS 1986): Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 Un tranzistor TESLA KFY16 (cu pinii auriti), PNP silicon transistor for universal purpose. http://www.elenota.pl/datasheet-pdf/125965/Tesla/KFY16 Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 (editat) Tranzistorul TESLA KFY18 (cu pinii auriti): PNP silicon transistor for universal purpose. Editat August 25, 2014 de overseas Link spre comentariu
Vizitator overseas Postat August 25, 2014 Partajează Postat August 25, 2014 (editat) Tranzistorul BFY46 (pinii auriti): NPN silicon mesa transistor intended as AF low power amplifier / fast switch Editat August 25, 2014 de overseas Link spre comentariu
Vizitator overseas Postat August 26, 2014 Partajează Postat August 26, 2014 (editat) Tranzistorul CEMI BC211: NPN silicon planar transistor intended as AF medium power amplifier. (Detector electronic de fulger cu BC211) http://www.eres.alpha.pl/elektronika/articles.php?article_id=360 Editat August 26, 2014 de overseas Link spre comentariu
Ombladon2002 Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 E bine de stiut. Asa cum am spus mai sus a doua cifra reprezinta grupa UCB0 10V.......60V. A treia cifra din codificare reprezinta amplificarea in curent a tranzistorului (β), astfel: Cifra 1 amplificarea cea mai mica β=17...45, iar cele cu cifra 3 cea mai mare β=60...200, unde Ic=100mA In plus punctul de culoare prezinta mai exact amplificarea, astfel: Rosu................15-35 Portocaliu........25-45 Galben.............35-55 Verde...............45-65 Albastru...........55-80 Violet...............75-100 Alb....................85-180 Mai sunt si alte lucruri de spus despre EFT-uri dar pana acum cred ca am punctat esentialul. As avea si eu o intrebare,daca nu va deranjeaza.Mai foloseste cineva acesti tranzistori (EFT de ex)?Adica merita sa-i vand sau nu au valoare? Link spre comentariu
remus68 Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 In fabricatie de serie nu se mai folosesc EFT-uri dar pot fi de folos celor care vor sa depaneze aparate fabricate in anii '60...'70. Link spre comentariu
gauss Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 Tranzistorii romanesti ROS ... au fost fabricati de defunctul ICCE ( Institutul de cercetari pentru componente electronice ) ... Link spre comentariu
Ombladon2002 Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 Pai nu la fabricatie de serie,am doar cateva zeci ... Link spre comentariu
remus68 Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 merita sa-i vand sau nu au valoare? Poti incerca sa realizezi cu ei diverse montaje dupa scheme din anii '70 (de exemplu din revista "Tehnium") care pot fi utile si educative in acelasi timp. Daca nu, poti incerca sa ii vinzi dar pe "piata" nu au un pret atit de mare incit sa spui ca "ai dat lovitura" Link spre comentariu
Vizitator overseas Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 Poti incerca sa realizezi cu ei diverse montaje dupa scheme din anii '70 (de exemplu din revista "Tehnium") care pot fi utile si educative in acelasi timp. Daca nu, poti incerca sa ii vinzi dar pe "piata" nu au un pret atit de mare incit sa spui ca "ai dat lovitura" Valoare au cand repari un RR romanesc sau strain pe Ge, si il poti vinde ca functional... Link spre comentariu
Ombladon2002 Postat Septembrie 17, 2014 Partajează Postat Septembrie 17, 2014 Tocmai am vandut 230 de BC-uri cu 10 Lei (cred),nu incerc sa dau lovitura,incerc doar sa scap de ce nu-mi foloseste,mai ales ca majoritatea lucrurilor le-am primit de la cineva acum cativa ani,si cu durere-n suflet (pentru altii,nu pentru mine) spun ca acel cineva mi-a dat si un teanc (de aproximativ 40cm) de reviste Tehnium,pe care ghici ce? le-am aruncat .pe langa acele reviste,am mai ratacit multe lucruri care la varsta de 14-15 ani,pareau neinteresante,bine ca unele dintre ele le-am pastrat undeva si acum am inceput sa mai vand din ele... Link spre comentariu
