Ce tranzistoare vintage detineti?
Vizitator overseas
Vizitator overseas
Un tranzistor cu cod japonez 2SB89:
Posted Image
Hitachi PNP germanium alloy transistor intended as AF low power amplifier / driver.
Echivalent cu AC128.
Si cel produs de HITACHI:
Posted Image
:ewryt45w
Vizitator overseas
OC 816:
Posted Image
Type Designator: OC816
Material of transistor: Ge
Polarity: PNP
Maximum collector power dissipation (Pc), W: 0.08
Maximum collector-base voltage |Ucb|, V: 15
Maximum collector-emitter voltage |Uce|, V: 15
Maximum collector current |Ic max|, A: 0.05
Maksimalna temperatura (Tj), °C: 110
Transition frequency (ft), MHz: 0.2
Forward current transfer ratio (hFE), min: 20
Package of OC816 transistor: TO22
An de fabricatie 1958
:dffe
Vizitator overseas
Din cate am inteles pe net se fac din 1954 dar al tau avand litera F a VI a din alfabet ar fi 1956... Asa cred eu.
Caracteristici:
OC70 Germanium PNP TransistorVbr CBO : 30hfe : 20≤@ Ic (A) : 500u@ VCE (test) (V) : 2.0Ic Max. (A) : 50mTrans. Freq. (Hz) Mn. : 1.0MIcbo Max. @Vcb Max. (A) : 13uVbr CEO : 30Max PD (W) : 125mDerate (Amb) (W/ºC) : 2.5mOper. Temp (ºC) Max : 75Pkg Style : TO-1
Vizitator overseas
Tot un tranzistor HITACHI: 2SA17
Posted Image
Type Designator: 2SA17
Polarity: PNP
Maximum collector-base voltage |Ucb|, V: 12
Maximum collector-emitter voltage |Uce|, V: 10
Maximum emitter-base voltage |Ueb|, V: 12
Maximum collector current |Ic max|, A: 0.15
Maksimalna temperatura (Tj), °C: 75
Transition frequency (ft), MHz: 8
Collector capacitance (Cc), pF: 15
Forward current transfer ratio (hFE), min: 250
Package of 2SA17 transistor: TO1
Stie cineva in ce an a fost fabricat acest tranzistor, dupa inscriptia de pe el, "5SF"?
Care e modul de citire a acestei inscriptii? Chiar nu stiu.
Capsula e din sticla vopsita. Frumoasa piesa de colectie.
Tranzistoare vintage cu germaniu si siliciu.
ASZ20
Posted Image
ASY27
Posted Image
OC170 -VALVO
Posted Image
P403A
Posted Image
P416B
Posted Image
OC141 capsula de sticla.
Posted Image
P306A
Posted Image
Continuare
P216
Posted Image
GT404D
Posted Image
GT403B
Posted Image
P701A
Posted Image
2T602B
Posted Image
P308
Posted Image
