Administratori Badman Postat Mai 29, 2014 Administratori Partajează Postat Mai 29, 2014 File Name: Jedicut File Submitter: Vasile File Submitted: 29 May 2014 File Category: Software CNC Jedicut is a free CNC software for CNC foam cutting board, allowing you to cut wings and fuselages. There are many CNC board kit but software are not always adapted to model aircraft making use and Jedicut is free.Jedicut support several communication protocol thanks to its plugin system. Jedicut can control many CNC foam cutting boards like : [*]MM2001 french board, [*]VISUAL CNC kit, [*]HobbyCNC kit, [*]Xavtronic USB/parallel port adapter for MM2001 board (and compatibles) . [*]If you have another cnc foam cutting board, post a message on the website board. Important : Jedicut is a free CNC software and it must not be used as a commercial software. Click here to download this file Link spre comentariu
