KCam
Vizitator rozone
Vizitator rozone
Nume fișier: KCam
Emitent fișier: rozone
Fișier trimis: 29 mai 2014
Categorie fișier: Software CNC
KCam Router/Mill software is designed to run low cost hobby CNC equipment. Program your paths using the built in Gcode editor, or import DXF, NC, and PLT files. Create signs and plates using your CAD software and import your work into KCam. Dual cutting depth allows for holes and outlines to be punched out after routing. No more drilling holes for switches or cutting plates to size before engraving.
Engrave signs, make name tags, drill printed circuit boards, mill parts, plasma cuts, plot pictures onto paper...
Here are a few of the key features:
  • [*]Load GM code files [*]Import Excellon ASCII drill files (.NC) [*]Import DXF files (.DXF) [*]Import HPGL files (.PLT) [*]Import Gerber files(.GB0) [*]Edit/Write GM code files [*]3D Graphical Viewer w/ Zoom, Pan and Table Views [*]Manual Jogging motor control [*]Controller and Table setup features [*]Supports Parallel Port (LPT) Stepper Motor Controllers [*]Supports MaxStepper pulse generator [*]Selectable Feed Rate [*]Backlash Compensation [*]Windows 98/NT/2000/XP/Vista 32bit Software [*]PCB Isolation conversion from Gerber(RS274X) files [*]Constant Velocity Contouring [*]Multiple Machine Setups
Click aici pentru a descărca acest fișier
  • Răspunsuri 3
  • myshyk
  • Badman
  • Administratori
Nici eu nu am reusit sa fac nimic cu acest soft dar sunt useri care il folosesc cu succes
Si eu il folosesc la decupat litere in polistiren, dar import doar fisiere hpgl, merge perfect, editeaza codul G foarte bine.
Dar la import .dxf, nu genereaza cod G lizibil.
