incinta pt portbagaj
nicul
  • Răspunsuri 7
  • nicul
  • Swat Cat
  • ionut20
  • crexy
Zile populare
este f interesant ......din cate vad nu are pereti paraleli ( doar tavanul cu baza f putin ) deci are f putine unde stationare
adica mediile vor suna ceva mai bine, dar per total tot prost ca e subwoofer.
A Patent-Pending triangle-shaped enclosure to complement the RX Series Triangle Subwoofers. At just under 1.3 cubic feet, the "TVB-141" (Tri-Vent Box with one RXT1 subwoofer) will fit easily in most vehicles. This enclosure utilizes some of the same physics properties of Bazooka's patented Bass Tubes? enclosure design. The TVB-141 has a front firing woofer and 3 front firing vents and is constructed of MDF. This radically different alternative to conventional subwoofers and enclosures features a unique triple venting scheme that effectively tunes the system for added efficiency and increased usable frequency response.
baietii astia au reinventat roata ! :smt003
