Vlad Mihai Postat Martie 30, 2014 Partajează Postat Martie 30, 2014 Buna ziua, ieri am avut ceva timp sa finalizez un proiect mai mic ce consta in pornirea unui motor de HDD. Motorul este in conexiune stea cu nulul accesibil(4 fire). Initial am gasit secventele de pornire pe site-ul asta http://theamateurprogrammer.blogspot.hk/2014/02/revitalizing-old-hard-drive-motors.html dar partea de forta nu ma incanta de loc, asa ca am proiect o noua schema cu mosfet. Schema: PCB: 3D 3/ Realizare practica: Cod sursa: const int phase1pin = 2;const int phase2pin = 3;const int phase3pin = 4;float holdTime = 90000; // microsecsconst unsigned long minHoldTime = 3400; unsigned long p1start, p1end, p2start, p2end, p3start, p3end; void setup(){ Serial.begin(9600); pinMode(phase1pin, OUTPUT); pinMode(phase2pin, OUTPUT); pinMode(phase3pin, OUTPUT); p1start = micros(); digitalWrite(phase1pin, HIGH);} void chkP1(){ unsigned long currentTime = micros(); unsigned long td = currentTime - p1start; unsigned long refractory = 2.25*holdTime; if(digitalRead(phase1pin)){ if(td > holdTime){ digitalWrite(phase1pin, LOW); p1end = currentTime; } }else if(td > refractory){ digitalWrite(phase1pin, HIGH); p1start = currentTime; }} void chkP2(){ unsigned long currentTime = micros(); unsigned long td = currentTime - p1start; if(digitalRead(phase2pin)){ if(td > 1.75*holdTime || td < 0.75*holdTime){ digitalWrite(phase2pin, LOW); p2end = currentTime; } }else if(td > 0.75*holdTime && td < 1.75*holdTime){ digitalWrite(phase2pin, HIGH); p2start = currentTime; }} void chkP3(){ unsigned long currentTime = micros(); unsigned long td = currentTime - p1start; if(digitalRead(phase3pin)){ if(td > 0.25*holdTime && p3start < p1start){ digitalWrite(phase3pin, LOW); p3end = currentTime; } }else if(td > 1.5*holdTime){ digitalWrite(phase3pin, HIGH); p3start = currentTime; }} void loop(){ chkP1(); chkP2(); chkP3(); delayMicroseconds(100); if(holdTime >= minHoldTime){ holdTime -= 0.5; }}Nu prea sunt incantat de ceea ce ar putea face acest motor, cuplul e mic, si consuma mult o sursa de 12V 2A nominal in 10-15 minute e calda, suge vreo 3A si are rezistenta infasurarilor de circa 3 ohmi.La secventa de pornire iar e nasol ca nu am reusit sa il stabilizez, atasez si un video. E dedicatie pentru Thunderer acest topic, e acelasi motor care am incercat noi sa il pornim acum mult timp si am renuntat(daca iti mai amintesti), acum l-am biruit. Link spre comentariu
Dr.L Postat Martie 30, 2014 Partajează Postat Martie 30, 2014 Frumos!Daca consuma mult, atunci trebuie sa aiba si cuplu pe masura! Daca se incalzeste motorul, fara sa aiba cuplu, atunci comanda nu e 100% ok. Link spre comentariu
Vlad Mihai Postat Martie 30, 2014 Autor Partajează Postat Martie 30, 2014 Da am presupus si eu ca ar fi comanda. O sa mai incerc si alta varianta de soft. Eu am vrut doar sa il pornesc pentru moment . Link spre comentariu
Mircea Postat Martie 30, 2014 Partajează Postat Martie 30, 2014 Hahaha, am banuit eu ceva... Bravo, inca o data, pentru perseverenta! Link spre comentariu
Vlad Mihai Postat Martie 30, 2014 Autor Partajează Postat Martie 30, 2014 Cum mai sus am facut pornirea lui cu un cod de pe net in mediul arduino, acum vin cu varianta mea de pornire in mikroC, e bruta dar porneste motorul. void main() {TRISB.F5 = 0;TRISB.F4 = 0;TRISB.F3 = 0;PORTB.F5 = 0;PORTB.F4 = 0;PORTB.F3 = 0;while(1){PORTB.F5=1;Delay_ms(30);PORTB.F5=0;Delay_us(8); //dead timePORTB.F4=1;Delay_ms(30);PORTB.F4=0;Delay_us(8); //dead timePORTB.F3=1;Delay_ms(30);PORTB.F3=0;Delay_us(8); //dead time}} Link spre comentariu
Marian Postat Martie 30, 2014 Partajează Postat Martie 30, 2014 Asta se numeste ambitie veritabila, si merita toate cuvintele de lauda, bravo @Vlad. Link spre comentariu
Vizitator Postat Martie 30, 2014 Partajează Postat Martie 30, 2014 E bine că te-ai apucat, felicitări. Acum, e momentul să-l perfecţionezi. Adică să afli ce nu e bine şi să-l faci să meargă ca un adevărat motor de HDD.Arată-ne ce poţi! Link spre comentariu
Vlad Mihai Postat Aprilie 6, 2014 Autor Partajează Postat Aprilie 6, 2014 Buna seara, am mai studiat problema si incerc o alta partea de comanda. Voi construi in invertor trifazic cu 3 semipunti(H bridge) cu mosfeti canal N(Vds=80V, id=100-150A, Rdson-3,4mohmi, Ciss ok) alaturi de niste drivere de 2A. Momentan merge greu ca de la servici nu ma slabesc deloc, si mai am si masterul, dar inaintez ca mi-a mancat zilele acest motor, ori va merge ori il ard si gata. Ca driver HB voi folosi MAX5063D (cu intrare TTL), pentru a putea fi comandat de un microcontroler. Fiind 3 semipunti am nevoie de 6 semnale pwm sa comand motorul, dar daca cititi catalogul la MAX5063D veti vedea ca pot folosi doar 3 semnale pwm, cate unul pentru fiecare faza. Momentan sunt in stadiu de proiectare pcb si calcul pe foaie componente. Sper sa revin curand cu detalii. O zi buna! Link spre comentariu
Vlad Mihai Postat Iulie 21, 2014 Autor Partajează Postat Iulie 21, 2014 (editat) Buna dimineata, de mult am zis ca ma apuc sa fac un invertor in 3 faze pentru un acest de motor de HDD dar nu am avut timp, insa ieri nu am mai rezistat si am realizat practic. Am pornit de la o schema cu perechi de mosfeti complementari (irf3205+ irf4905) si cu cate un driver max628.De asemenea am pus si un "high side current sense" realizat cu max4377 pentru a citi curentul. Momentan testez functionarea unui soft de baza realizat dupa diagrama de comenzi preluata din documentatii, dar mai am de lucru, insa in seara asta am dat de un cod pe net cu care am putut sa testez invertorul, si am ramas impresionat cum lucreaza. Atasez cateva imagini: Schema electrica a invertorului: subefotos PCB invertor: imagen 3d invertor: PCB fizic invertor: share image invertor: Video: https://www.youtube.com/watch?v=m4w165oSSS4&feature=youtu.be Se misca mult mai bine fata de cel precedent, dar trebuie sa il realizez cu mosfeti cu canal n ca cei de sus au rds on 20mohm si cam disipa caldura, si in plus trebuie sa ii fac limitare de curent. Dar am prins curaj, se invarte cam cu aproximativ 4000 de rot/min acum. Poate il duc mai sus. Bineinteles va urma si o interfata in LabVIEW de control si monitorizare dar dupa ce termin. Folosesc o placuta Arduino sa il controlez, si folosesc 3 fire pentru a controla motorul, nu mai folosesc nulul de data asta. Ps: la inceputul clipului led-ul clipeste pentru ca sursa intra in limitare, o stoarce de curent, dar cu cresterea vitezei nu mai apare problema asta. Am facut o greseala ca am ales driverele smd, se cam incalzesc si nu au pad-uri de racire ca alte drivere dedicate smd. Editat Iulie 21, 2014 de Vlad Mihai Link spre comentariu
Mircea Postat Iulie 22, 2014 Partajează Postat Iulie 22, 2014 Pune niste radiatoare sub Mosfeturi. Daca stai sub 5-6A nu vad de ce ai trece pe punte N. Fa-ti calculul de putere disipata (vezi aici http://ww1.microchip.com/downloads/en/AppNotes/00799b.pdf) si vezi daca asta e problema driverului. Poti sa te folosesti de pinii driverului (facand trasee PCB mai groase in viitor - vezi care sunt pinii mai potriviti sa disipe caldura) sa disipi caldura. Bafta la proiecte! Link spre comentariu
ciocead4 Postat Iulie 22, 2014 Partajează Postat Iulie 22, 2014 Cel mai probabil incalzirea MOSFET-urilor este cauzata de conductia simultana a highside+lowside. Din cate stiu MAX628 nu ofera deadtime intern, de aceea el trebuie realizat de circuitul de comanda PWM. Poti sa verifici/reglezi acest deadtime din placa PWM (este Arduino?) ? Daniel Link spre comentariu
Vlad Mihai Postat Iulie 22, 2014 Autor Partajează Postat Iulie 22, 2014 Salut, da am implementat dead-time de 10uS din soft, placa arduino, o sa il mai reglez. Thunderer multumesc pentru documentatie, o sa o citesc, desi calculasem in mintea mea valorile componentelor ca sa nu depasesc limitele admise de driver. Link spre comentariu
Vlad Mihai Postat Iulie 24, 2014 Autor Partajează Postat Iulie 24, 2014 Salutare, de data asta l-am biruit, se invarte ca un un motor de hard disk cu turatie maxima. Am rezolvat cu incalzirea invertorului prin adaugare de limitare de curent de circa 0.8 A, motorul are 3 ohmi rezistenta infasurarilor. Am schimbat toate driverele, max628 cu altele noi si nu se mai incalzesc (cele anterioare erau recuperate de pe un alt montaj de-al meu, probabil erau defecte). Am realizat un soft care porneste lent si accelereaza pe parcurs pana la viteaza maxima. Acest motor e un motor BLDC outrunner adica rotorul e in exterior. Timpul mort la fiecare tranzistor este de 10uS, e arhisuficient, dupa 10 minute de functionare, invertorul sta rece. Mi-a mancat zilele motorul asta. Video: https://www.youtube.com/watch?v=clD7sbHwC8c&feature=youtu.be Link spre comentariu
giongiu Postat Iulie 24, 2014 Partajează Postat Iulie 24, 2014 (editat) Felicitari Mihai! Eu sunt impresionat de ambitia ta, ai invatat foarte multe intr-un timp scurt, ai realizat foarte multe lucruri demne de toata lauda. Chiar daca ai testat cu un motor de mica putere, invertorul, prin redimensionarea partii de forta, cred ca ar putea alimenta motoare brushless, de putere mult mai mare. Eu sunt interesat de asa ceva, vreau sa fac ceva teste cu un alternator auto, convertit in motor. Daca ai putea da ceva detalii despre realizarea partii de comanda, ti-as fi recunoscator. Cu partea de forta, cred ca ma descurc. Apropo de asta, poti folosi doar mosfeti N, folosind drivere flotante, de ex IR2110. In felul asta, tensiunea de alimentare a puntii H, poate fi pana la vreo 400V. Trebuie insa citit curentul spre masa, dar e simplu de facut, cu un senzor de curent, care poate fi o simpla rezistenta. Editat Iulie 24, 2014 de giongiu Link spre comentariu
Vlad Mihai Postat Iulie 24, 2014 Autor Partajează Postat Iulie 24, 2014 (editat) Multumesc giongiu! O sa facem in functie de ce timp am si regulatorul dvs, v-am explicat pe mesaj privat. Postez codul sursa pe care l-am scris pentru a testa acest motor, se mai poate optimiza dar eu sunt multumit deocamdata ca l-am dus la viteza maxima. Limbajul este in Arduino, procesor ATmega328 smd. Stiu ca e dezordonat codul, dar important e ca imi merge. int T1 = 5;int T2 = 6; // phase 1int T3 = 7;int T4 = 8; //phase 2int T5 = 9;int T6 = 10; //phase 3unsigned long stepLength = 40000;int minStepLength = 780;int steps = 10;void setup() { pinMode(T1, OUTPUT); pinMode(T2, OUTPUT); pinMode(T3, OUTPUT); pinMode(T4, OUTPUT); pinMode(T5, OUTPUT); pinMode(T6, OUTPUT); }void loop(){ switchStep(1); switchStep(2); switchStep(3); switchStep(4); switchStep(5); switchStep(6); if(stepLength > minStepLength) { stepLength = stepLength - steps; } else { stepLength=minStepLength; } if (stepLength < 39950) { steps = 300; } if (stepLength < 20000) { steps = 50; } if (stepLength < 3000) { steps = 2; }}void switchStep(int stage){ switch(stage) { case 1: digitalWrite(T1, LOW); digitalWrite(T2, LOW); digitalWrite(T3, HIGH); digitalWrite(T4, LOW); digitalWrite(T5, LOW); digitalWrite(T6, HIGH); delayMicroseconds(10); //dead time myDelay(stepLength); break; case 2: digitalWrite(T1, HIGH); digitalWrite(T2, LOW); digitalWrite(T3, LOW); digitalWrite(T4, LOW); digitalWrite(T5, LOW); digitalWrite(T6, HIGH);delayMicroseconds(10); //dead time myDelay(stepLength); break; case 3: digitalWrite(T1, HIGH); digitalWrite(T2, LOW); digitalWrite(T3, LOW); digitalWrite(T4,HIGH); digitalWrite(T5, LOW); digitalWrite(T6, LOW);delayMicroseconds(10); //dead time myDelay(stepLength); break; case 4: digitalWrite(T1, LOW); digitalWrite(T2,LOW); digitalWrite(T3, LOW); digitalWrite(T4, HIGH); digitalWrite(T5, HIGH); digitalWrite(T6, LOW); delayMicroseconds(10); //dead time myDelay(stepLength); break; case 5: digitalWrite(T1, LOW); digitalWrite(T2, HIGH); digitalWrite(T3, LOW); digitalWrite(T4, LOW); digitalWrite(T5, HIGH); digitalWrite(T6, LOW);delayMicroseconds(10); //dead time myDelay(stepLength); break; default: digitalWrite(T1, LOW); digitalWrite(T2, HIGH); digitalWrite(T3, HIGH); digitalWrite(T4, LOW); digitalWrite(T5, LOW); digitalWrite(T6, LOW); delayMicroseconds(10); //dead time myDelay(stepLength); break; } } void myDelay(unsigned long p) {if (p > 16380) { delay (p/1000); } else { delayMicroseconds(p); }} Editat Iulie 24, 2014 de Vlad Mihai Link spre comentariu
