Echivalent/Inlocuire BA178M15T
Vizitator username
Vizitator username
CI BA178M15T poate fi inlocuit cu un 7815?Postez caracteristicile fiecaruia, provenienta farnell.comLM7815 V REG, 2VDO, 1A, 15V, 3TO220 Input Voltage Min: 23V Input Voltage Max: 35V Output Voltage Nom.: 15V Output Current: 1A Voltage Regulator Case Style: TO-220 No. of Pins: 3 Operating Temperature Min: -40°C Operating Temperature Max: 125°C Packaging: Each MSL: - No. of Outputs: 1 Output Voltage Max: 15V Primary Input Voltage: 23V SVHC: No SVHC (16-Dec-2013)BA178M15T IC, LINEAR REG, 500MA, 15V, TO220 Input Voltage Min: 17.5V Input Voltage Max: 30V Output Voltage Nom.: 15V Output Current: 500mA Voltage Regulator Case Style: TO-220 No. of Pins: 3 Operating Temperature Min: -40°C Operating Temperature Max: 85°C Packaging: Each Base Number: 178 MSL: - No. of Outputs: 1 Operating Temperature Range: -40°C to +85°C Primary Input Voltage: 30V
  • Răspunsuri 2
  • Meta-fizica
Zile populare
