pspsuceava Postat Martie 15, 2014 Partajează Postat Martie 15, 2014 IDE : MPLAB COMPILATOR : XC8 Nu exista exemple pentru acest compilator de lcd facute ok... Eu nu am gasit. M-am chinuit sa adaptez diverse programe pentru alte compilatoare dar nu am reusit... Ce am reusit pana acum: #include <xc.h>//#include <htc.h>#pragma config BOREN = OFF, CPD = OFF, FOSC = XT , MCLRE = OFF, WDTE = OFF, CP = OFF, LVP = OFF, PWRTE = ON#define _XTAL_FREQ = 4000000#define LCD_RS RB6#define LCD_RW RB5#define LCD_EN RB4#define LCD_DATA PORTB#define LCD_STROBE() ((LCD_EN = 1),(LCD_EN=0))/* write a byte to the LCD in 4 bit mode */void delay_ms(unsigned int n){ do { _delay(4000); } while(--n != 0);}void delay_us(unsigned int i){ do { _delay(4); } while(--i != 0);voidlcd_write(unsigned char c){ DelayUs(40); LCD_DATA = ( ( c >> 4 ) & 0x0F ); LCD_STROBE(); LCD_DATA = ( c & 0x0F ); LCD_STROBE();}/* * Clear and home the LCD */voidlcd_clear(void){ LCD_RS = 0; lcd_write(0x1); DelayMs(2);}/* write a string of chars to the LCD */voidlcd_puts(const char * s){ LCD_RS = 1; // write characters while(*s) lcd_write(*s++);}/* write one character to the LCD */voidlcd_putch(char c){ LCD_RS = 1; // write characters lcd_write( c );}/* * Go to the specified position */voidlcd_goto(unsigned char pos){ LCD_RS = 0; lcd_write(0x80+pos);}/* initialise the LCD - put into 4 bit mode */voidlcd_init(){ char init_value; //COMPARATORIII init_value = 0x3; //TRISA=0; TRISB=0b00000000; LCD_RS = 0; LCD_EN = 0; LCD_RW = 0; DelayMs(15); // wait 15mSec after power applied, LCD_DATA = init_value; LCD_STROBE(); DelayMs(5); LCD_STROBE(); DelayUs(200); LCD_STROBE(); DelayUs(200); LCD_DATA = 2; // Four bit mode LCD_STROBE(); lcd_write(0x28); // Set interface length lcd_write(0xF); // Display On, Cursor On, Cursor Blink lcd_clear(); // Clear screen lcd_write(0x6); // Set entry Mode}void main(){ lcd_init(); lcd_goto(0); // select first line lcd_puts("12345678"); lcd_goto(0x40); // Select second line lcd_puts("Hello world"); for(;;);} Vedeti vreo greseala? Ce cred eu ca este gresit, probabil routinele de delay... Link spre comentariu
pspsuceava Postat Martie 15, 2014 Autor Partajează Postat Martie 15, 2014 Daca poate cineva sa ma ajute, ar fi perfect, multumesc anticipat. :)Eu zic ca partea "hardware" circuitul e 100% corect... Link spre comentariu
Liviu M Postat Martie 15, 2014 Partajează Postat Martie 15, 2014 #define LCD_RS RB6#define LCD_RW RB5#define LCD_EN RB4#define LCD_DATA PORTB...lcd_write(unsigned char c){ DelayUs(40); LCD_DATA = ( ( c >> 4 ) & 0x0F );... Cand faci LCD_DATA = ( ( c >> 4 ) & 0x0F ); faci RB4..RB6 = 0. In cazul asta, RS=1 din puts e inutil, primul lcd_write il face 0:lcd_puts(const char * s){ LCD_RS = 1; // write characters while(*s) lcd_write(*s++);}Pe de alta parte, in xc8 exista _delay_ms() si _delay_us(), nu-s convins ca-ti trebuie functii proprii. Link spre comentariu
pspsuceava Postat Martie 15, 2014 Autor Partajează Postat Martie 15, 2014 Nu am inteles prima parte, iar a doua parte, mie fiecare delay din cele enumerate ( si cel cu us si cu ms ) imi dau erori ca nu sunt recunoscute... E vreo bliblioteca care trebuie inclusa ( am incercat htc.h ) si nu merge...? Link spre comentariu
Liviu M Postat Martie 15, 2014 Partajează Postat Martie 15, 2014 Daca c=0xab, rezultatul operatiei: LCD_DATA = ( ( c >> 4 ) & 0x0F );e echivalent cu PORTB = 0x0aCu alte cuvinte, RB7..RB4 = 0b0000. Cu alte cuvinte, dupa o operatie lcd_write, obtii RB6 == LCD_RS = 0. Referitor la _delay_us()/_delay_ms() care e mesajul de eroare? Link spre comentariu
pspsuceava Postat Martie 16, 2014 Autor Partajează Postat Martie 16, 2014 Referitor la delay:Cand folosesc delayms() simplu:make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-confmake[1]: Entering directory `C:/Users/Iliescu/MPLABXProjects/LCDTESTv2.X'make -f nbproject/Makefile-default.mk dist/default/production/LCDTESTv2.X.production.hexmake[2]: Entering directory `C:/Users/Iliescu/MPLABXProjects/LCDTESTv2.X'"G:\MPLAB\Microchip\xc8\v1.30\bin\xc8.exe" --pass1 --chip=16F628A -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%%f:%%l: error: (%%n) %%s" "--warnformat=%%f:%%l: warning: (%%n) %%s" "--msgformat=%%f:%%l: advisory: (%%n) %%s" -obuild/default/production/lcd.p1 lcd.c lcd.c:36: warning: (361) function declared implicit intlcd.c:90: warning: (361) function declared implicit int"G:\MPLAB\Microchip\xc8\v1.30\bin\xc8.exe" --chip=16F628A -G -mdist/default/production/LCDTESTv2.X.production.map --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: (%%n) %%s" "--msgformat=%%f:%%l: advisory: (%%n) %%s" -odist/default/production/LCDTESTv2.X.production.elf build/default/production/lcd.p1 Microchip MPLAB XC8 C Compiler (Free Mode) V1.30Copyright © 2014 Microchip Technology Inc.License type: Node Configuration:: warning: (1273) Omniscient Code Generation not available in Free modelcd.c:36: warning: (1464) number of arguments passed to function "_DelayMs" does not match function's prototypelcd.c:85: warning: (1464) number of arguments passed to function "_DelayMs" does not match function's prototypelcd.c:88: warning: (1464) number of arguments passed to function "_DelayMs" does not match function's prototypelcd.c:90: warning: (1464) number of arguments passed to function "_DelayUs" does not match function's prototypelcd.c:92: warning: (1464) number of arguments passed to function "_DelayUs" does not match function's prototype:0: error: undefined symbols: _DelayMs(dist/default/production\LCDTESTv2.X.production.obj) _DelayUs(dist/default/production\LCDTESTv2.X.production.obj) (908) exit status = 1make[2]: *** [dist/default/production/LCDTESTv2.X.production.hex] Error 1make[1]: *** [.build-conf] Error 2make: *** [.build-impl] Error 2make[2]: Leaving directory `C:/Users/Iliescu/MPLABXProjects/LCDTESTv2.X'make[1]: Leaving directory `C:/Users/Iliescu/MPLABXProjects/LCDTESTv2.X'BUILD FAILED (exit value 2, total time: 3s)cand folosesc _delay_ms(); cum ai zis tu:make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-confmake[1]: Entering directory `C:/Users/Iliescu/MPLABXProjects/STERGE.X'make -f nbproject/Makefile-default.mk dist/default/production/STERGE.X.production.hexmake[2]: Entering directory `C:/Users/Iliescu/MPLABXProjects/STERGE.X'"G:\MPLAB\Microchip\xc8\v1.30\bin\xc8.exe" --pass1 --chip=16F628A -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%%f:%%l: error: (%%n) %%s" "--warnformat=%%f:%%l: warning: (%%n) %%s" "--msgformat=%%f:%%l: advisory: (%%n) %%s" -obuild/default/production/newmain.p1 newmain.c newmain.c:22: warning: (361) function declared implicit intnewmain.c:38: warning: (361) function declared implicit int"G:\MPLAB\Microchip\xc8\v1.30\bin\xc8.exe" --chip=16F628A -G -mdist/default/production/STERGE.X.production.map --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: (%%n) %%s" "--msgformat=%%f:%%l: advisory: (%%n) %%s" -odist/default/production/STERGE.X.production.elf build/default/production/newmain.p1 Microchip MPLAB XC8 C Compiler (Free Mode) V1.30Copyright © 2014 Microchip Technology Inc.License type: Node Configuration:: warning: (1273) Omniscient Code Generation not available in Free modenewmain.c:38: warning: (1464) number of arguments passed to function "__delay_ms" does not match function's prototypenewmain.c:87: warning: (1464) number of arguments passed to function "__delay_ms" does not match function's prototypenewmain.c:90: warning: (1464) number of arguments passed to function "__delay_ms" does not match function's prototypenewmain.c:92: warning: (1464) number of arguments passed to function "__delay_us" does not match function's prototypenewmain.c:94: warning: (1464) number of arguments passed to function "__delay_us" does not match function's prototype:0: error: undefined symbols: __delay_ms(dist/default/production\STERGE.X.production.obj) __delay_us(dist/default/production\STERGE.X.production.obj) (908) exit status = 1make[2]: *** [dist/default/production/STERGE.X.production.hex] Error 1make[1]: *** [.build-conf] Error 2make: *** [.build-impl] Error 2make[2]: Leaving directory `C:/Users/Iliescu/MPLABXProjects/STERGE.X'make[1]: Leaving directory `C:/Users/Iliescu/MPLABXProjects/STERGE.X'BUILD FAILED (exit value 2, total time: 2s)Deci eroarea e UNDEFINED functions.. Link spre comentariu
Ionut Pavel Postat Martie 16, 2014 Partajează Postat Martie 16, 2014 Din ce am inteles dupa o cautare, ar trbui inclus #include .Functiile de delay ar fi: __delay_us(10);__delay_ms(10);Atentie la dublu underscore la inceput. Link spre comentariu
pspsuceava Postat Martie 16, 2014 Autor Partajează Postat Martie 16, 2014 Am inclus deja xc.h, stai sa vad daca merge, dar te referi la faptul ca pentru a pune delay de 40 de ms sa zicem, trebuie pus un for(int i=0;i<5;i++) __delay_ms(10); sau ma rog, sa il pui de 4 ori la rand? Adica nu merge schimbat argumentul? E absurd. Link spre comentariu
Ionut Pavel Postat Martie 16, 2014 Partajează Postat Martie 16, 2014 Nu. Dai argumentul care il vrei tu. Era copy paste dintr-o bucata de cod (10 ala) . Link spre comentariu
pspsuceava Postat Martie 16, 2014 Autor Partajează Postat Martie 16, 2014 Am facut acum un alt proiect, am copiat un cod care are deja rutinele astea, ca daca le scriu eu nu merge, tot imi da eroare, e ciudat ma cam enerveaza compilatorul asta nou de la microchip...Eu nu inteleg o chestie, deci pana la urma pinii de la display trebuie conectati pe porturile RB4- Rb7, nu?voidlcd_write(unsigned char c){__delay_us(40);LCD_DATA = ( ( c >> 4 ) & 0x0F ); // mi-a explicat aici cineva ca are ar face RB4-RB7 0, deci inteleg ca pinii astia 4 ii folosesc, nu?LCD_STROBE();LCD_DATA = ( c & 0x0F );LCD_STROBE();}Sau invers, pe 0 - 4?Multumesc tuturor pentru ajutor !!! Link spre comentariu
Ionut Pavel Postat Martie 16, 2014 Partajează Postat Martie 16, 2014 LCD_DATA = ( ( c >> 4 ) & 0x0F ); /*Iti face bitii 3-0 ai portului egali cu bitii 7-4 al lui c dar bitii 7-4 ai portului ii face 0*/LCD_DATA = ( c & 0x0F ); /*Iti face bitii 3-0 ai portului egali cu bitii 3-0 al lui c dar bitii 7-4 ai portului ii face 0*/Deci bitii 7-4 ai portului ii face 0 si apare o problema daca tu mai ai ceva conectat acolo. Link spre comentariu
pspsuceava Postat Martie 16, 2014 Autor Partajează Postat Martie 16, 2014 Am inteles ( cred ), deci pana la urma, eu conectez D4-D7 de la ecran la RB0-RB3, asa-i? Link spre comentariu
Elef Postat Martie 16, 2014 Partajează Postat Martie 16, 2014 unsigned char temp;temp = LCD_DATA;temp = temp & 0xF0temp = temp | ((c>>4)&0x0F);LCD_DATA = temp; Link spre comentariu
pspsuceava Postat Martie 16, 2014 Autor Partajează Postat Martie 16, 2014 unsigned char temp;temp = LCD_DATA;temp = temp & 0xF0temp = temp | ((c>>4)&0x0F);LCD_DATA = temp;? Sa modific programul sa pun asta in loc sau ?Si inca o intrebare, eu am alimentare diferentiata pentru picsi pentru display, pentru display am pus un incarcator de telefon, pentru pic am lasat pickit2-ul pe vdd on. ideea e ca daca il programez cat timp am displayul conectat, imi da eroare, trebuie sa scot displayul din montaj, sa programez picul dupa care sa il pun iarasi. e corect sau nu?Si cu MCLR-ul eu in program in pragma config il pun OFF, si din pickit2 il tin in reset, e ok, nu?Stiu ca pot face MCLR-ul si " hardware ", adica sa il pun leg cu un switch si o rezistenta, dar credca merge si din program direct, nu?Ma gandesc ca circuitul pentru MCLR e util daca fac PCB-ul si nu o sa mai am pickitul conectat la el, dar asa, nu e nevoie, ma gandesc eu. Link spre comentariu
Ionut Pavel Postat Martie 16, 2014 Partajează Postat Martie 16, 2014 Cum spune Elef. Se aplica la trimiterea datelor catre LCD.Sau asa. LCD_DATA = (LCD_DATA & 0xF0) | (c >> 4); /*Pentru high nibble*/LCD_DATA = (LCD_DATA & 0xF0) | c; /*Pentru low nibble*/Astea nu iti mai modifica bitii 7-4 ai portului.Sau daca vrei sa fii total safe:LCD_DATA = (LCD_DATA & 0xF0) | ((c >> 4) & 0x0F); /*Pentru high nibble*/LCD_DATA = (LCD_DATA & 0xF0) | (c & 0x0F); /*Pentru low nibble*/ Link spre comentariu
