johnnybili Postat Martie 11, 2014 Partajează Postat Martie 11, 2014 salut,am realizat proiectul de http://radiokot.ru/circuit/audio/filter/05/si m-am lovit de fisierul hex care este in limba rusa,cum il pot modifica in engleza sau romana? Link spre comentariu
cristi7521 Postat Martie 12, 2014 Partajează Postat Martie 12, 2014 Aici ceva similarviewtopic.php?f=11&t=102723 Link spre comentariu
johnnybili Postat Martie 12, 2014 Autor Partajează Postat Martie 12, 2014 poate... dar este pentru tda8425,eu am tda 7318 si pic 16f628a,sper sa ma descurce cineva Link spre comentariu
cristi7521 Postat Martie 14, 2014 Partajează Postat Martie 14, 2014 Tradu pagina de aici cu google, se pare ca explica ce modificari trebuie sa faci. Se pare ca meniul e scris in eeprom. http://radiokot.ru/circuit/audio/filter/04/ Link spre comentariu
fratello Postat Martie 14, 2014 Partajează Postat Martie 14, 2014 @johnnybili : In arhiva pusa de tine ai si fisierul sursa. Datele sunt : __EEPROM_DATA(1,0xa1,0x70,0x6f,0xbc,0xba,0x6f,0x63);__EEPROM_DATA(0xbf,0xc4,2,0xa0,0x61,0xbb,0x61,0xbd);__EEPROM_DATA(0x63,3,0x54,0x65,0xbc,0xb2,0x70,0x20);__EEPROM_DATA(0xbd,0xb8,0xb7,0xba,0xb8,0x65,4,0x54);__EEPROM_DATA(0x65,0xbc,0xb2,0x70,0x20,0xb3,0xc3,0x63);__EEPROM_DATA(0x6f,0xba,0xb8,0x65,5,0x50,0x65,0xb6);__EEPROM_DATA(0xb8,0xbc,6,0x6f,0xb2,0xc3,0xc0,0xbd);__EEPROM_DATA(0xc3,0xb9,7,0x70,0x61,0x63,0xc1,0xb8);__EEPROM_DATA(0x70,0x65,0xbd,0xbd,0xc3,0xb9,8,0xbe);__EEPROM_DATA(0x63,0x65,0xb3,0xe3,0x6f,0x63,0xbf,0x65);__EEPROM_DATA(0x70,0x65,0x6f,9,0xbc,0x6f,0xbd,0x6f);__EEPROM_DATA(10,0x42,0x78,0x6f,0xe3,11,0xbb,0xb8);__EEPROM_DATA(0xbd,0x65,0xb9,0xbd,0xc3,0xb9,12,0xbe);__EEPROM_DATA(0x70,0xb8,0xb5,0xbc,0xbd,0xb8,0xba,13);__EEPROM_DATA('N','a','s','t','y','a',' ',14);__EEPROM_DATA(50,32,8,8,1,1,0,0);Modifica aici, cf. dorintelor si re-compileaza programul (foloseste Compiler: HI-TECH C for PIC10/12/16 MCUs (PRO Mode) V9.71a ). Link spre comentariu
cristi7521 Postat Martie 14, 2014 Partajează Postat Martie 14, 2014 Salut.Vezi daca apare ceva dupa ce programezi fisierul atasat.Fusebitii trebuie sa fie la fel.Daca apar mesaje imi spui cu ce trebuie inlocuit fiecare mesaj, de la 1 la 7. PROG-MESAJ.zip Link spre comentariu
