a 123 systems lifepo4 Ajutor!!!
Vizitator sorin28m
Vizitator sorin28m
nu stiu daca este sectiunea cea mai potrivita dar eu incerc !vreau sa construiesc un acumulator pentru motocicleta din celule a123 cu specificatiile de mai jos!de c ate celule am nevoie si cum sa le leg ?am nevoie de min 12 ah si 12v(un acu normal are incarcat cam 13.3v)Cell SpecificationsCell Dimensions: ø32 x 113mmCell Weight: 205gDischarge Rate: 30CCell Capacity (Nominal): 4400mAhEnergy Content (Nominal): 14.6WhPeak Power @ 10 Sec: 550WVoltage (Nominal): 3.3VRecommended End Of Discharge Cutoff: 2.0VRecommended Standard Change: 1.5C to 3.6VRecommended Fast Charge: 4C to 3.5VSpecific Power (Nominal): 2700 W/kgSpecific Energy (Nominal): 71 Wh/kgEnergy Density (Nominal): 161 Wh/LTemp Range: -30°C to 55°CStorage temperature range: -40°C to 60°C merci !
  • Răspunsuri 1
  • asyx
Zile populare
