viorel1964 Postat Aprilie 11, 2014 Partajează Postat Aprilie 11, 2014 Puneti va rog si o poza cu voltmetrul cu 2 fire care masoara tensiuni sub 10 volti .Vreau sa masor si zeci de mV (ex: 6.xx V ).Multumesc Link spre comentariu
soringt Postat Aprilie 11, 2014 Autor Partajează Postat Aprilie 11, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/buc Operating voltage: 3.2 ~ 30V Operating Current: <60mA Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! Mounting holes: 45.5 x 26.5 mm Measurement rate: ≥ 500mS Measurement accuracy: 1% Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! 2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc Dimension: 23mmx15mmx10mm Sample period:500ms ; Resolution:1%+1digit Reverse Voltage Protection 2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc Afisaj 0.36" 2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/buc Dimensiuni:40mm x 25mm x 23mm(L*W*H) Working Current:<20mA Display: Three digit 0.4" LED RED / BLUE 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc - stoc limitat! 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc Display color: (Red & Blue) or (Red & Red) LED (dual display). Display: 0.28" LED digital. Operating voltage: DC 4.5 ~ 30V. Measure voltage: DC 0 ~ 100V. Operating Current: <20mA. Measure current: 10A (direct measurement, built-in shunt). Mounting cutout: 45.5mm x 26.5mm. Size: 48mm x 29mm x 21mm 3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc 3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40V Uout: 1.25V-35V Output current: 2A (max.3A) Transfer efficiency:92%(max) Switching Frequency:65KHz Dimensiuni: 43x21mm 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc Uin: 4-40 v Uout:1.25V - 37V Imax: 3A cu radiator Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF 4.c) Sursa STEP-UP cu LM2577 - 15lei/buc 5. 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20V Static current: <50uA High level output: 3.3 V / low 0V Delay time: 0.5-200S (adjustable) Blocking time: 2.5S (the default) Sensing range (3-7m) Size: 32mm*24mm circuit board Induction angle: <100 degree cone angle Working temperature: -15-+70 degre Cu un tranzistor si un releu se poate face o automatizare instant! 7.a) Breadboard 830 puncte - 26lei/buc 7.b)Set de 65 fire - 14lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc) 7.c)Set de 40 fire - 15lei/set Lungime 20cm 1p-1p Male - Female 7. d) Mini-breadboard 170 puncte - 8lei/buc 7.e) Mini breadboard 400 puncte - 13lei/buc 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc Apply to MB102 breadboard Input voltage: 6.5-12 V (DC) or USB power supply Output voltage: 3.3V/5V can switch over Maximum output current: <700 ma 8. Mini freza pentru PCB - 25lei/buc Alimentare 12V +spiral de 0.8mm 9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc Superior material made, strong structure Tip Diameter: 0.8mm Grip Diameter: 3.175mm Total Length: 37.5mm Material: cemented carbide(tungsten steel, tip), high-speed steel(grip) 45lei/set de 10buc http://imageshack.us/a/img32/3916/uho4.jpg 9. b). Set spirale 0.3mm - 1.2mm - 45lei/set Numai set intreg. carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm, http://i40.tinypic.com/xddpvn.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc http://imageshack.us/a/img259/3507/l5yk.jpg 11. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°C Rezolutie afisare: 0.1 Precizie masurare: ±1°C Alim: 2 buc LR44 (incluse) Lung cablu semzor: 1m Dimensiuni: 47*28*14mm http://i39.tinypic.com/5d1cfr.jpg 12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc http://imageshack.us/a/img30/7024/pspa.jpg 12. b). 12. c) Arduino MEGA 2560 R3 + cablu USB - 100lei/buc http://i61.tinypic.com/2usa62p.jpg 12. d) Shield LCD keypad - 45lei/buc http://i62.tinypic.com/2hrft6x.jpg 13. Afisaje LED http://imageshack.us/a/img62/4617/2f8f.jpg 4 Digits :CEAS - 5lei/buc Pin Number: 12 pins. Digit Number: 4 digits. Common anode. Digit Height: 0.56 inch. Color: Red. 3 DIGITI + comun - 2lei/buc Display: 0.36" LED digital tube Range: 1.9 -2.2V Display Color: Red Size: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W) 10-Segmente GREEN - 2lei/buc Size: Approx. 2.4*1*1.4cm (L*W*H) 14. Diferite CI-uri http://imageshack.us/a/img132/8272/f3uq.jpg DS12C887+ - 20 lei/buc M48T02-70PC1 - 25lei/buc M48T02-150PC1 - 25lei/buc M4T28-BR12SH1 - 10lei/buc MAX1496 - 15lei/buc MAX7219 - 10lei/buc 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high) Working voltage: 3 V - 5.5 V Temperature measurement range: - 40°c to 80°c Measuring accuracy: 0.5°c The humidity measuring range: 0-100% RH Measuring accuracy: 2% RH http://i62.tinypic.com/zxjz8l.jpg 16. Ampermetru de panou BLUE 0-10A - 20lei/buc http://i44.tinypic.com/29kw0nt.jpg 17. Player MP3 + radio + remote - 60lei/buc http://i59.tinypic.com/2jfhlph.jpg http://i62.tinypic.com/11ha34l.jpg 1.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack 18. Sursa Step-UP USB 5V max.600mA - 7lei/buc http://i62.tinypic.com/m5w86.jpg Size:34 (mm) x16.2 (mm) ultra-small size Uin: 1-5V; Output 5V stabilizat max.600mA Se pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon Comanda minima 70lei Transport+Ramburs: 11lei Link spre comentariu
Vizitator elecalex67 Postat Aprilie 11, 2014 Partajează Postat Aprilie 11, 2014 Cum pot intra in contact ma intereseaza volt+amp sa cumpar.Vreau sa folosesc la o instalatie fotovoltaica 24 V 50 A sa monitorizez intalatia .problema este pe ampermetru sa indice curentul de incarcare si descarcare -50A ...+50A daca se poate si pentru 100A. Astept sa ma contactati la nr.0761 650 606. Link spre comentariu
soringt Postat Aprilie 12, 2014 Autor Partajează Postat Aprilie 12, 2014 Puneti va rog si o poza cu voltmetrul cu 2 fire care masoara tensiuni sub 10 volti .Vreau sa masor si zeci de mV (ex: 6.xx V ).Multumesc Link spre comentariu
dorelb Postat Aprilie 13, 2014 Partajează Postat Aprilie 13, 2014 Salut. Modul RTC nu este ? Link spre comentariu
soringt Postat Aprilie 13, 2014 Autor Partajează Postat Aprilie 13, 2014 Salut. Modul RTC nu este ?Salut. Nu am module RTC. Link spre comentariu
Vizitator pippogsm Postat Aprilie 13, 2014 Partajează Postat Aprilie 13, 2014 Salut.Ma intereseaza:Senzor PIR - 10lei/buc - 3buc Sursa DC-DC step-down cu LM2596 - 10lei/buc x 1 bucSet spirale 0.3mm - 1.2mm - 45lei/set x 1bucNu vad date de contact, am trimis si PM, poate ne auzim la un telefon azi.Multumesc. Link spre comentariu
Vizitator pippogsm Postat Aprilie 13, 2014 Partajează Postat Aprilie 13, 2014 Am fost, am vazut, am cumparat.Multumesc Sorin! Link spre comentariu
soringt Postat Aprilie 13, 2014 Autor Partajează Postat Aprilie 13, 2014 Am fost, am vazut, am cumparat.Multumesc Sorin!Cu placere. Link spre comentariu
soringt Postat Aprilie 15, 2014 Autor Partajează Postat Aprilie 15, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/buc Operating voltage: 3.2 ~ 30V Operating Current: <60mA Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! Mounting holes: 45.5 x 26.5 mm Measurement rate: ≥ 500mS Measurement accuracy: 1% Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! 2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc Dimension: 23mmx15mmx10mm Sample period:500ms ; Resolution:1%+1digit Reverse Voltage Protection 2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc Afisaj 0.36" 2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/buc Dimensiuni:40mm x 25mm x 23mm(L*W*H) Working Current:<20mA Display: Three digit 0.4" LED RED / BLUE 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc - stoc limitat! 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc Display color: (Red & Blue) or (Red & Red) LED (dual display). Display: 0.28" LED digital. Operating voltage: DC 4.5 ~ 30V. Measure voltage: DC 0 ~ 100V. Operating Current: <20mA. Measure current: 10A (direct measurement, built-in shunt). Mounting cutout: 45.5mm x 26.5mm. Size: 48mm x 29mm x 21mm 3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc 3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40V Uout: 1.25V-35V Output current: 2A (max.3A) Transfer efficiency:92%(max) Switching Frequency:65KHz Dimensiuni: 43x21mm 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc Uin: 4-40 v Uout:1.25V - 37V Imax: 3A cu radiator Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF 4.c) Sursa STEP-UP cu LM2577 - 15lei/buc 5. 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20V Static current: <50uA High level output: 3.3 V / low 0V Delay time: 0.5-200S (adjustable) Blocking time: 2.5S (the default) Sensing range (3-7m) Size: 32mm*24mm circuit board Induction angle: <100 degree cone angle Working temperature: -15-+70 degre Cu un tranzistor si un releu se poate face o automatizare instant! 7.a) Breadboard 830 puncte - 26lei/buc 7.b)Set de 65 fire - 14lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc) 7.c)Set de 40 fire - 15lei/set Lungime 20cm 1p-1p Male - Female 7. d) Mini-breadboard 170 puncte - 8lei/buc 7.e) Mini breadboard 400 puncte - 13lei/buc 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc Apply to MB102 breadboard Input voltage: 6.5-12 V (DC) or USB power supply Output voltage: 3.3V/5V can switch over Maximum output current: <700 ma 8. Mini freza pentru PCB - 25lei/buc Alimentare 12V +spiral de 0.8mm 9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc Superior material made, strong structure Tip Diameter: 0.8mm Grip Diameter: 3.175mm Total Length: 37.5mm Material: cemented carbide(tungsten steel, tip), high-speed steel(grip) 45lei/set de 10buc http://imageshack.us/a/img32/3916/uho4.jpg 9. b). Set spirale 0.3mm - 1.2mm - 45lei/set Numai set intreg. carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm, http://i40.tinypic.com/xddpvn.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc http://imageshack.us/a/img259/3507/l5yk.jpg 11. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°C Rezolutie afisare: 0.1 Precizie masurare: ±1°C Alim: 2 buc LR44 (incluse) Lung cablu semzor: 1m Dimensiuni: 47*28*14mm http://i39.tinypic.com/5d1cfr.jpg 12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc http://imageshack.us/a/img30/7024/pspa.jpg 12. b). 12. c) Arduino MEGA 2560 R3 + cablu USB - 100lei/buc http://i61.tinypic.com/2usa62p.jpg 12. d) Shield LCD keypad - 45lei/buc http://i62.tinypic.com/2hrft6x.jpg 13. Afisaje LED http://imageshack.us/a/img62/4617/2f8f.jpg 4 Digits :CEAS - 5lei/buc Pin Number: 12 pins. Digit Number: 4 digits. Common anode. Digit Height: 0.56 inch. Color: Red. 3 DIGITI + comun - 2lei/buc Display: 0.36" LED digital tube Range: 1.9 -2.2V Display Color: Red Size: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W) 10-Segmente GREEN - 2lei/buc Size: Approx. 2.4*1*1.4cm (L*W*H) 14. Diferite CI-uri http://imageshack.us/a/img132/8272/f3uq.jpg DS12C887+ - 20 lei/buc M48T02-70PC1 - 25lei/buc M48T02-150PC1 - 25lei/buc M4T28-BR12SH1 - 10lei/buc MAX1496 - 15lei/buc MAX7219 - 10lei/buc 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high) Working voltage: 3 V - 5.5 V Temperature measurement range: - 40°c to 80°c Measuring accuracy: 0.5°c The humidity measuring range: 0-100% RH Measuring accuracy: 2% RH http://i62.tinypic.com/zxjz8l.jpg 16. Ampermetru de panou BLUE 0-10A - 20lei/buc http://i44.tinypic.com/29kw0nt.jpg 17. Player MP3 + radio + remote - 60lei/buc http://i59.tinypic.com/2jfhlph.jpg http://i62.tinypic.com/11ha34l.jpg 1.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack 18. Sursa Step-UP USB 5V max.600mA - 7lei/buc http://i62.tinypic.com/m5w86.jpg Size:34 (mm) x16.2 (mm) ultra-small size Uin: 1-5V; Output 5V stabilizat max.600mA Se pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon Comanda minima 70lei Transport+Ramburs: 11lei Link spre comentariu
soringt Postat Aprilie 16, 2014 Autor Partajează Postat Aprilie 16, 2014 Se modifica punctul 10 astfel: 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc Link spre comentariu
soringt Postat Aprilie 18, 2014 Autor Partajează Postat Aprilie 18, 2014 UP! Se adauga: 5. Termometru IR (infrarosu) Interval masura: -50 - 330°C - 70lei/buc -50 - 500°C - 75lei/buc ( disponibl 1 buc). -alimentare 2x 1.5V AAA Link spre comentariu
soringt Postat Aprilie 20, 2014 Autor Partajează Postat Aprilie 20, 2014 Paste Fericit!UP! Link spre comentariu
