soringt Postat Octombrie 20, 2017 Autor Partajează Postat Octombrie 20, 2017 Salut. Da, mai am disponibile. Multumesc Link spre comentariu
soringt Postat Octombrie 23, 2017 Autor Partajează Postat Octombrie 23, 2017 LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 35lei; grafic 128x64 - 55leiLCD HD44780 16x2 GREEN,WHITE,BLUE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)2. c) 2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 30lei/bucPrecizie:±1.5%Dim: 55x40x25mmSe introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - stoc 0Display color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 60lei/buc3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc - stoc 04.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 20lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 15lei/bucUin: 4V-38VUout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max)Switching Frequency:180KHz 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc 4.f) Sursa DC-DC Step-down CC + CV 9A - 50lei/bucreglare tensiune si curentIN: 5-40V ; OUT: 1.25 - 35VCurent iesire: 0.2-9A (max) 4.g) Sursa STEP-UP boost 6A - 35leiIN:10-32V ; OUT:10-35V 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 20lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female1p-1p Female - Female1p-1p Male - Male7.e) Mini breadboard 400 puncte - 15lei/buc 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma8. 9. Spiral 0.1mm, 0.2mm,0.3mm, 0.5mm, 0.7mm, 0.8mm, 0.9mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc11. 12. a). ARDUINO UNO R3 + cablu USB - 50ei/buc 12. b). Shield LAN W5100 - 50lei/buc - stoc 012. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 40lei4 digit 7-segment LED display module driven by two serial 74HC595’s4 LED’s10K potentiometer3 x push buttonsPiezo buzzerDS18B20 or LM35 temperature sensor interface (not included)Infrared receiver interfaceSerial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 15 / 20 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RH 16. Senzor temperatura DS18B20 waterproof - 15lei/buclungime cablu: 1m 17. Diverse module17.a) Modul MAX7219 8 digiti rosu - 12lei/buc17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 60lei/buc17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 10lei/buc17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc17.e) Senzor Barometric / presiune BMP180 - 15lei/buc17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc17.g) Sursa Step-UP USB 5V max.600mA - 5lei/buc 17.h) Modul WI-FI ESP8266 ESP-12E sau ESP-12F - 20lei/buc17.i) Modul TEA5767 Radio FM - 7lei/buc17.j) Modul(set) RF 433MHz - 10lei/set17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc (versiunea cu volume control -10lei/buc) 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 15lei/buc 18. Module Diverse:18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -20lei/set ( optional mai multe brelocuri albastre 2lei/buc)18.b) Modul senzor touch 1 canal - 9lei/buc18.c) Modul senzor touch 4 canale - 12lei/buc18.d) Modul senzor touch 8 canale - 15lei/buc Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 30lei/bucModul HC-05 bluetooth serial port, master-slave, 6pini - 30lei/buc 19. 20. Display NOKIA5110 - 20lei/buc 21. 22. 23. Socluri ZIF40Soclu ZIF40 universal gold plated black - 10lei/bucSoclu ZIF40 universal gold plated blue - 10lei/buc 24. 25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 25lei/set - 1buc disponibila-se poate lega si in punte (1x36W)-alim. 2x12V AC-dim. 40x92mm Modul display 4digits (RED) cu 595 - 15lei/bucModul WiFi ESP8266 ESP-12E - 20lei/bucModul Ethernet ENC28J60 - 25lei/bucModul MAX7219 dot matrix display 8x8 RED - 15lei/bucNodeMCU v2 ESP8266 cu ESP-12E - 70lei/bucModul wireless 2.4G - NRF24L01 - 10lei/bucAdaptoare USB-TTL- Cu FTDI 232 - 25lei/buc- Cu CH340G - 10lei/bucArduino NANO v3.0 - 20lei/buc (fara cablu USB)Adaptor pentru Arduino NANO - 20lei/buc Aparat de masurat umiditatea MD-4G - 60lei/bucrange: 5-40% ; Precizie ±1%Alim: 9V Aparat de masurat umiditatea - 80lei/bucRange: 0-99,9% ; Precizie:±0.5%Calibrare pt 4 grupuri de tip lemnAlim:9V Multitester LCD grafic cu Mega328 - 80leiDisplay grafic 128x64 LCD cu backlight Testeaza si identifica componente, astfel:-Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm-Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare.-Bobine: 0.01mH - 20H-Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP-Tiristoare si triace-LED-uri si alte diode (identifica tens de deschidere) Durata masura: 2s (exceptie la condensatorii de capacitate mai mare)Alimentare: 9VOptional: carcasa plexiglass transparenta - 25lei Termostat digital - 20lei/bucDimensiuni: 48x40mmTemperature control mode: ON / OFFTemperature range :-50-110 CelsiusResolution:0.1 CelsiusControl accuracy: 0.1 CelsiusHysteresis accuracy: 0.1CelsiusRefresh rate: 0.5SHigh temperature protection: 0-110 CelsiusSupply voltage: for DC 12VOutput power: 10A relay Measurement input: NTC (10K 0.5%) Waterproof Sensor Modul RFID Reader RDM6300 - 20lei(buc)-125KHz- compatibil cu EM4100 RFID Card Key ID (nu sunt incluse)- Baud rate: 9600- Interface: TTL level RS232 format- Working voltage: DC 5V(+/-5%)- Working current: <50mA- Receive distance: 20-50mm- Wiring size: 46*32*3mm- PCB size: 38.5*19*9mm Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 20lei/buc Afisaj 0.36" Modul charger TP4056 cu protectie - 6lei/buc Link spre comentariu
YO9IBC Postat Octombrie 25, 2017 Partajează Postat Octombrie 25, 2017 Coletul a ajuns ok, multumesc! Recomand! Link spre comentariu
soringt Postat Octombrie 26, 2017 Autor Partajează Postat Octombrie 26, 2017 Sursa Step-UP USB 5V max.600mA - 5lei/buc Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc Sursa DC-DC CV CC step-down 5A + Voltmetru LED 4 digiti + USB - 45lei/buc Seturi semireglabili ( diverse valori) - 45lei/set multitura si "normali" Adaptor RS232-TTL cu MAX232 - 4lei/buc Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc Modul amplificator clasa D 2x15W cu PAM8610 cu volume control - 25lei/buc Modul receptor bluetooth + amplif. 2x3W cu PAM8403 - 40lei/buc Modul amplificator mono 35W cu TDA8932 - 25lei/buc Modul amplificator clasa D 2x15W cu TPA3110 - 65lei/buc - stoc 0 Sursa stabilizata 5A - 15lei/buc In: 5-32V Out: 0.8-32V Tester USB voltmetru / ampermetru - 25lei/buc Alim:3-9V Curent masurat: 0-3A(max) Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc. Programator clona PICkit2 - 80lei/buc Programator clona PICkit3 - 100lei/buc Adaptor soclu ZIF40 - 25lei/buc Modul WiFi D1 mini NodeMCU - 30lei/buc Lanterna 7W - 20lei/buc Led Q5, zoom, focus ajustabil 1xAA sau 1x14500 Transmitator audio bluetooth - 70lei/buc -acumulator inclus -cablu audio si cablu incarcare(USB) incluse USB ASP - 10lei/buc OLED display 128x64 0.96inch - 30lei/buc -interfata I2C, controller SSD1306 -white sau blue Modul releu 1-channel 5V (low trigger) - 10lei/buc Punte H DC stepper motor cu L298N - 20lei Module ESP8266 ESP-12E sau ESp-12F - 25lei/buc Link spre comentariu
soringt Postat Octombrie 31, 2017 Autor Partajează Postat Octombrie 31, 2017 Amplificator 2x50W cu TDA7492 cu bluetooth - 90lei -alim: 10-25V -iesire: recomandat 8ohm ( suporta si 4, 6 sau 16 ohm) -modul bluetooth V4.0 : CSR8635 -microfon -AUX Platforma dezvoltare WiFi NodeMCU cu ESP-12E - 40lei/buc Interfata USB cu CH340G Link spre comentariu
soringt Postat Noiembrie 1, 2017 Autor Partajează Postat Noiembrie 1, 2017 Anunt valabil. Link spre comentariu
soringt Postat Noiembrie 3, 2017 Autor Partajează Postat Noiembrie 3, 2017 Anunt valabil. Link spre comentariu
soringt Postat Noiembrie 6, 2017 Autor Partajează Postat Noiembrie 6, 2017 Anunt valabil. Link spre comentariu
Vizitator Alin Radu Postat Noiembrie 10, 2017 Partajează Postat Noiembrie 10, 2017 Mai sunt disponibile Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc Link spre comentariu
soringt Postat Noiembrie 11, 2017 Autor Partajează Postat Noiembrie 11, 2017 Mai sunt disponibile Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc Mai sunt disponibile. Link spre comentariu
Vizitator Alin Radu Postat Noiembrie 11, 2017 Partajează Postat Noiembrie 11, 2017 Salut.As dori Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc 2buc Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc 1buc Modul charger TP4056 cu protectie - 6lei/buc 2buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc 2buc 4. d) Sursa DC-DC step-down 5A - 15lei/buc 1buc Cum pot lua legatura cu tine pentru ca nu pot trimite mp Link spre comentariu
soringt Postat Noiembrie 12, 2017 Autor Partajează Postat Noiembrie 12, 2017 Salut.As dori Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc 2buc Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc 1buc Modul charger TP4056 cu protectie - 6lei/buc 2buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc 2buc 4. d) Sursa DC-DC step-down 5A - 15lei/buc 1buc Cum pot lua legatura cu tine pentru ca nu pot trimite mp Da-mi nr. tu de telefon. Multumesc. Link spre comentariu
Vizitator Alin Radu Postat Noiembrie 12, 2017 Partajează Postat Noiembrie 12, 2017 Nr 0724858713 Link spre comentariu
soringt Postat Noiembrie 13, 2017 Autor Partajează Postat Noiembrie 13, 2017 Anunt valabil. Link spre comentariu
stefan33 Postat Noiembrie 15, 2017 Partajează Postat Noiembrie 15, 2017 Termometru de panou, culoare albastru aveti ? Link spre comentariu
