LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
  • 3 săptămâni mai târziu...
LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 35lei; grafic 128x64 - 55lei
LCD HD44780 16x2 GREEN,WHITE,BLUE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
2.a) Voltmetru de panou - Pret: 20lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
2.b)
2. c)
2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/buc
Dimensiuni:40mm x 25mm x 23mm(L*W*H)
Working Current:<20mA
Display: Three digit 0.4" LED RED / BLUE/ GREEN
2. e) Voltmetru digital LCD 80V-300V AC - 30lei/buc
Precizie:±1.5%
Dim: 55x40x25mm
Se introduce direct in priza
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - stoc 0
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 60lei/buc
3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc - stoc 0
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 20lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Imax: 3A cu radiator
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
4.c) Sursa STEP-UP cu LM2577 - 15lei/buc
4. d) Sursa DC-DC step-down 5A - 15lei/buc
Uin: 4V-38V
Uout: 1.25V-36V
Output current: 0-5A
Transfer efficiency:96%(max)
Switching Frequency:180KHz
4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc
4.f) Sursa DC-DC Step-down CC + CV 9A - 50lei/buc
reglare tensiune si curent
IN: 5-40V ; OUT: 1.25 - 35V
Curent iesire: 0.2-9A (max)
4.g) Sursa STEP-UP boost 6A - 35lei
IN:10-32V ; OUT:10-35V
5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc
6.Senzor PIR - 10lei/buc
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 20lei/buc
7.b)Set de 65 fire - 15lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
1p-1p Female - Female
1p-1p Male - Male
7.e) Mini breadboard 400 puncte - 15lei/buc
7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc
Apply to MB102 breadboard
Input voltage: 6.5-12 V (DC) or USB power supply
Output voltage: 3.3V/5V can switch over
Maximum output current: <700 ma
8.
9. Spiral 0.1mm, 0.2mm,0.3mm, 0.5mm, 0.7mm, 0.8mm, 0.9mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
http://imageshack.us...2/3916/uho4.jpg
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
11.
12. a). ARDUINO UNO R3 + cablu USB - 50ei/buc
12. b). Shield LAN W5100 - 50lei/buc - stoc 0
12. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc
12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc
12.e) Shield Arduino Multifunctional - 40lei
4 digit 7-segment LED display module driven by two serial 74HC595’s
4 LED’s
10K potentiometer
3 x push buttons
Piezo buzzer
DS18B20 or LM35 temperature sensor interface (not included)
Infrared receiver interface
Serial interface header for connection to serial modules
12.f). Shield relee 2 sau 4 canale - 15 / 20 lei /buc
13. Set Remote control 4 canale - 25lei/set
14.
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
16. Senzor temperatura DS18B20 waterproof - 15lei/buc
lungime cablu: 1m
17. Diverse module
17.a) Modul MAX7219 8 digiti rosu - 12lei/buc
17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 60lei/buc
17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 10lei/buc
17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc
17.e) Senzor Barometric / presiune BMP180 - 15lei/buc
17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc
17.g) Sursa Step-UP USB 5V max.600mA - 5lei/buc
17.h) Modul WI-FI ESP8266 ESP-12E sau ESP-12F - 20lei/buc
17.i) Modul TEA5767 Radio FM - 7lei/buc
17.j) Modul(set) RF 433MHz - 10lei/set
17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc (versiunea cu volume control -10lei/buc)
17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 15lei/buc
18. Module Diverse:
18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -20lei/set ( optional mai multe brelocuri albastre 2lei/buc)
18.b) Modul senzor touch 1 canal - 9lei/buc
18.c) Modul senzor touch 4 canale - 12lei/buc
18.d) Modul senzor touch 8 canale - 15lei/buc
Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 30lei/buc
Modul HC-05 bluetooth serial port, master-slave, 6pini - 30lei/buc
19.
20. Display NOKIA5110 - 20lei/buc
21.
22.
23. Socluri ZIF40
Soclu ZIF40 universal gold plated black - 10lei/buc
Soclu ZIF40 universal gold plated blue - 10lei/buc
24.
25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 25lei/set - 1buc disponibila
-se poate lega si in punte (1x36W)
-alim. 2x12V AC
-dim. 40x92mm
Modul display 4digits (RED) cu 595 - 15lei/buc
Modul WiFi ESP8266 ESP-12E - 20lei/buc
Modul Ethernet ENC28J60 - 25lei/buc
Modul MAX7219 dot matrix display 8x8 RED - 15lei/buc
NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc
Modul wireless 2.4G - NRF24L01 - 10lei/buc
Adaptoare USB-TTL
- Cu FTDI 232 - 25lei/buc
- Cu CH340G - 10lei/buc
Arduino NANO v3.0 - 20lei/buc (fara cablu USB)
Adaptor pentru Arduino NANO - 20lei/buc
Aparat de masurat umiditatea MD-4G - 60lei/buc
range: 5-40% ; Precizie ±1%
Alim: 9V
Aparat de masurat umiditatea - 80lei/buc
Range: 0-99,9% ; Precizie:±0.5%
Calibrare pt 4 grupuri de tip lemn
Alim:9V
Multitester LCD grafic cu Mega328 - 80lei
Display grafic 128x64 LCD cu backlight
Testeaza si identifica componente, astfel:
-Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm
-Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare.
-Bobine: 0.01mH - 20H
-Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP
-Tiristoare si triace
-LED-uri si alte diode (identifica tens de deschidere)
Durata masura: 2s (exceptie la condensatorii de capacitate mai mare)
Alimentare: 9V
Optional: carcasa plexiglass transparenta - 25lei
Termostat digital - 20lei/buc
Dimensiuni: 48x40mm
Temperature control mode: ON / OFF
Temperature range :-50-110 Celsius
Resolution:0.1 Celsius
Control accuracy: 0.1 Celsius
Hysteresis accuracy: 0.1Celsius
Refresh rate: 0.5S
High temperature protection: 0-110 Celsius
Supply voltage: for DC 12V
Output power: 10A relay
Measurement input: NTC (10K 0.5%) Waterproof Sensor
Modul RFID Reader RDM6300 - 20lei(buc)
-125KHz
- compatibil cu EM4100 RFID Card Key ID (nu sunt incluse)
- Baud rate: 9600
- Interface: TTL level RS232 format
- Working voltage: DC 5V(+/-5%)
- Working current: <50mA
- Receive distance: 20-50mm
- Wiring size: 46*32*3mm
- PCB size: 38.5*19*9mm
Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 20lei/buc
Afisaj 0.36"
Modul charger TP4056 cu protectie - 6lei/buc
Sursa DC-DC step-down 5A + Voltmetru LED - 30lei/buc
Sursa DC-DC CV CC step-down 5A + Voltmetru LED 4 digiti + USB - 45lei/buc
Seturi semireglabili ( diverse valori) - 45lei/set
multitura si "normali"
Adaptor RS232-TTL cu MAX232 - 4lei/buc
Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc
Modul amplificator clasa D 2x15W cu PAM8610 cu volume control - 25lei/buc
Modul receptor bluetooth + amplif. 2x3W cu PAM8403 - 40lei/buc
Modul amplificator mono 35W cu TDA8932 - 25lei/buc
Modul amplificator clasa D 2x15W cu TPA3110 - 65lei/buc - stoc 0
Sursa stabilizata 5A - 15lei/buc
In: 5-32V
Out: 0.8-32V
Tester USB voltmetru / ampermetru - 25lei/buc
Alim:3-9V
Curent masurat: 0-3A(max)
Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc.
Programator clona PICkit2 - 80lei/buc
Programator clona PICkit3 - 100lei/buc
Adaptor soclu ZIF40 - 25lei/buc
Modul WiFi D1 mini NodeMCU - 30lei/buc
Lanterna 7W - 20lei/buc
Led Q5, zoom, focus ajustabil
1xAA sau 1x14500
Transmitator audio bluetooth - 70lei/buc
-acumulator inclus
-cablu audio si cablu incarcare(USB) incluse
USB ASP - 10lei/buc
Platforma dezvoltare WiFi NodeMCU cu ESP-12E - 40lei/buc
Interfata USB cu CH340G
Editat de soringt
OLED display 128x64 0.96inch - 30lei/buc
-interfata I2C, controller SSD1306
-white sau blue
Modul releu 1-channel 5V (low trigger) - 10lei/buc
Punte H DC stepper motor cu L298N - 20lei
Module ESP8266 ESP-12E sau ESp-12F - 25lei/buc
