soringt Postat Februarie 27, 2017 Autor Partajează Postat Februarie 27, 2017 LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 35lei; grafic 128x64 - 55lei LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/buc Operating voltage: 3.2 ~ 30V Operating Current: <60mA Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! Mounting holes: 45.5 x 26.5 mm Measurement rate: ≥ 500mS Measurement accuracy: 1% Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! 2.b) 2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc Afisaj 0.36" 2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/buc Dimensiuni:40mm x 25mm x 23mm(L*W*H) Working Current:<20mA Display: Three digit 0.4" LED RED / BLUE/ GREEN 2. e) Voltmetru digital LCD 80V-300V AC - 30lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - stoc 0 Display color: (Red & Blue) or (Red & Red) LED (dual display). Display: 0.28" LED digital. Operating voltage: DC 4.5 ~ 30V. Measure voltage: DC 0 ~ 100V. Operating Current: <20mA. Measure current: 10A (direct measurement, built-in shunt). Mounting cutout: 45.5mm x 26.5mm. Size: 48mm x 29mm x 21mm 3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 60lei/buc 3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40V Uout: 1.25V-35V Output current: 2A (max.3A) Transfer efficiency:92%(max) Switching Frequency:65KHz Dimensiuni: 43x21mm 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 20lei/buc Uin: 4-40 v Uout:1.25V - 37V Imax: 3A cu radiator Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF 4.c) Sursa STEP-UP cu LM2577 - 15lei/buc 4. d) Sursa DC-DC step-down 5A - 15lei/buc Uin: 4V-38V Uout: 1.25V-36V Output current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc 4.f) Sursa DC-DC Step-down CC + CV 9A - 50lei/buc reglare tensiune si curent IN: 5-40V ; OUT: 1.25 - 35V Curent iesire: 0.2-9A (max) 4.g) Sursa STEP-UP boost 6A - 35lei IN:10-32V ; OUT:10-35V 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20V Static current: <50uA High level output: 3.3 V / low 0V Delay time: 0.5-200S (adjustable) Blocking time: 2.5S (the default) Sensing range (3-7m) Size: 32mm*24mm circuit board Induction angle: <100 degree cone angle Working temperature: -15-+70 degre Cu un tranzistor si un releu se poate face o automatizare instant! 7.a) Breadboard 830 puncte - 20lei/buc 7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc) 7.c)Set de 40 fire - 15lei/set Lungime 20cm 1p-1p Male - Female 1p-1p Female - Female 1p-1p Male - Male 7.e) Mini breadboard 400 puncte - 15lei/buc 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc Apply to MB102 breadboard Input voltage: 6.5-12 V (DC) or USB power supply Output voltage: 3.3V/5V can switch over Maximum output current: <700 ma 8. 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc Superior material made, strong structure Tip Diameter: 0.8mm Grip Diameter: 3.175mm Total Length: 37.5mm Material: cemented carbide(tungsten steel, tip), high-speed steel(grip) 45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. 12. a). ARDUINO UNO R3 + cablu USB - 50ei/buc 12. b). Shield LAN W5100 - 50lei/buc - stoc 0 12. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 15 / 20 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high) Working voltage: 3 V - 5.5 V Temperature measurement range: - 40°c to 80°c Measuring accuracy: 0.5°c The humidity measuring range: 0-100% RH Measuring accuracy: 2% RH 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 12lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 70lei/buc 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 10lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 15lei/buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 5lei/buc 17.h) Modul WI-FI ESP8266 ESP-12E sau ESP-12F - 20lei/buc 17.i) Modul TEA5767 Radio FM - 7lei/buc 17.j) Modul(set) RF 433MHz - 10lei/set 17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc (versiunea cu volume control -10lei/buc) 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 15lei/buc 18. Module Diverse: 18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -20lei/set ( optional mai multe brelocuri albastre 2lei/buc) 18.b) Modul senzor touch 1 canal - 9lei/buc 18.c) Modul senzor touch 4 canale - 12lei/buc 18.d) Modul senzor touch 8 canale - 15lei/buc Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 30lei/buc Modul HC-05 bluetooth serial port, master-slave, 6pini - 30lei/buc 19. 20. Display NOKIA5110 - 20lei/buc 21. 22. 23. Socluri ZIF40 Soclu ZIF40 universal gold plated black - 10lei/buc Soclu ZIF40 universal gold plated blue - 10lei/buc 24. 25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 25lei/set - 1buc disponibila -se poate lega si in punte (1x36W) -alim. 2x12V AC -dim. 40x92mm Modul display 4digits (RED) cu 595 - 15lei/buc Modul WiFi ESP8266 ESP-12E - 20lei/buc Modul Ethernet ENC28J60 - 25lei/buc Modul MAX7219 dot matrix display 8x8 RED - 15lei/buc NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc Modul wireless 2.4G - NRF24L01 - 10lei/buc Adaptoare USB-TTL - Cu FTDI 232 - 25lei/buc - Cu CH340G - 10lei/buc Arduino NANO v3.0 - 20lei/buc (fara cablu USB) Adaptor pentru Arduino NANO - 20lei/buc Aparat de masurat umiditatea MD-4G - 60lei/buc range: 5-40% ; Precizie ±1% Alim: 9V Aparat de masurat umiditatea - 80lei/buc Range: 0-99,9% ; Precizie:±0.5% Calibrare pt 4 grupuri de tip lemn Alim:9V Multitester LCD grafic cu Mega328 - 80lei Display grafic 128x64 LCD cu backlight Testeaza si identifica componente, astfel: -Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm -Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare. -Bobine: 0.01mH - 20H -Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP -Tiristoare si triace -LED-uri si alte diode (identifica tens de deschidere) Durata masura: 2s (exceptie la condensatorii de capacitate mai mare) Alimentare: 9V Optional: carcasa plexiglass transparenta - 25lei Termostat digital - 20lei/buc Dimensiuni: 48x40mm Temperature control mode: ON / OFF Temperature range :-50-110 Celsius Resolution:0.1 Celsius Control accuracy: 0.1 Celsius Hysteresis accuracy: 0.1Celsius Refresh rate: 0.5S High temperature protection: 0-110 Celsius Supply voltage: for DC 12V Output power: 10A relay Measurement input: NTC (10K 0.5%) Waterproof Sensor Modul RFID Reader RDM6300 - 20lei(buc) -125KHz - compatibil cu EM4100 RFID Card Key ID (nu sunt incluse) - Baud rate: 9600 - Interface: TTL level RS232 format - Working voltage: DC 5V(+/-5%) - Working current: <50mA - Receive distance: 20-50mm - Wiring size: 46*32*3mm - PCB size: 38.5*19*9mm Link spre comentariu
gabitzu2006 Postat Februarie 27, 2017 Partajează Postat Februarie 27, 2017 aveti PM Link spre comentariu
soringt Postat Februarie 28, 2017 Autor Partajează Postat Februarie 28, 2017 Modul charger TP4056 cu protectie - 6lei/buc Sursa Step-UP USB 5V max.600mA - 5lei/buc Sursa DC-DC step-down 5A + Voltmetru LED - 30lei/buc Sursa DC-DC CV CC step-down 5A + Voltmetru LED 4 digiti + USB - 45lei/buc Seturi semireglabili ( diverse valori) - 45lei/set multitura si "normali" Kit modem M590E GSM GPRS - 15lei 900-1800M Alim: 5V/1A Obs. Desi sunt sigilate, se pare ca modulul GSM a mai fost lipit (testat?) Arduino LilyPad 328 - 20lei/buc Adaptor RS232-TTL cu MAX232 - 4lei/buc Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc Modul amplificator clasa D 2x15W cu PAM8610 cu volume control - 25lei/buc Modul receptor bluetooth + amplif. 2x3W cu PAM8403 - 45lei/buc Modul amplificator mono 35W cu TDA8932 - 25lei/buc Modul amplificator clasa D 2x15W cu TPA3110 - 65lei/buc Sursa stabilizata 5A - 15lei/buc In: 5-32V Out: 0.8-32V Tester USB voltmetru / ampermetru - 25lei/buc Alim:3-9V Curent masurat: 0-3A(max) Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc. Programator clona PICkit2 - 80lei/buc Programator clona PICkit3 - 100lei/buc Adaptor soclu ZIF40 - 25lei/buc Modul WiFi D1 mini NodeMCU - 30lei/buc Lanterna 7W - 20lei/buc Led Q5, zoom, focus ajustabil 1xAA sau 1x14500 Transmitator audio bluetooth - 70lei/buc -acumulator inclus -cablu audio si cablu incarcare(USB) incluse USB ASP - 10lei/buc Platforma dezvoltare WiFi NodeMCU cu ESP-12E - 35lei/buc Interfata USB cu CH340G Link spre comentariu
soringt Postat Martie 1, 2017 Autor Partajează Postat Martie 1, 2017 Anunt valabil Amplificator 2x50W cu TDA7492 cu bluetooth - 90lei -alim: 10-25V -iesire: recomandat 8ohm ( suporta si 4, 6 sau 16 ohm) -modul bluetooth V4.0 : CSR8635 -microfon -AUX Modul releu 1-channel 5V (low trigger) - 9lei/buc Link spre comentariu
Marius84 Postat Martie 1, 2017 Partajează Postat Martie 1, 2017 Va salut! As vrea sa iau o Sursa stabilizata 5A - 15lei/buc. Am o sursa in comutatie care da exact 32 de volti. Are rost sa folosesc aceasta sursa reglabila la tensiunea maxima, sau nu rezista? Va intreb ca poate ati incercat-o dvs. Stiu ca uneori chineziii mai umfla specificatiile... Link spre comentariu
soringt Postat Martie 2, 2017 Autor Partajează Postat Martie 2, 2017 @Marius84: Aveti PM Link spre comentariu
sctsandu_175391 Postat Martie 2, 2017 Partajează Postat Martie 2, 2017 sctsandu -aveti PM Link spre comentariu
soringt Postat Martie 3, 2017 Autor Partajează Postat Martie 3, 2017 Anunt valabil. Link spre comentariu
sctsandu_175391 Postat Martie 4, 2017 Partajează Postat Martie 4, 2017 PRIMIT MODULELE.O.K. UN MARE MERCI PT SORINGT! Sctsandu. Link spre comentariu
soringt Postat Martie 5, 2017 Autor Partajează Postat Martie 5, 2017 Anunt valabil. Link spre comentariu
soringt Postat Martie 6, 2017 Autor Partajează Postat Martie 6, 2017 Anunt valabil. Link spre comentariu
soringt Postat Martie 7, 2017 Autor Partajează Postat Martie 7, 2017 Anunt valabil. Link spre comentariu
soringt Postat Martie 8, 2017 Autor Partajează Postat Martie 8, 2017 Anunt valabil Punte H DC stepper motor cu L298N - 20lei Link spre comentariu
yo9hmd Postat Martie 9, 2017 Partajează Postat Martie 9, 2017 Am primit coletul! Mersi de bonus! Link spre comentariu
soringt Postat Martie 12, 2017 Autor Partajează Postat Martie 12, 2017 Anunt valabil. Link spre comentariu
