LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
Vizitator Florian Vutof
Buna, as dori un voltmetru digital de c.a. din acela care se baga in priza, cu afisaj LCD si iluminat ecranul cu albastru.
Cum procedez ca sa-l achizitionez?
Multumesc !
Editat de Florian Vutof
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ;         20x4 - 40lei;       grafic 128x64 - 55lei
LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
Posted Image
2.a) Voltmetru de panou - Pret: 20lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
Posted Image
2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc
Dimension: 23mmx15mmx10mm
Sample period:500ms ; Resolution:1%+1digit
Reverse Voltage Protection
2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/buc
Afisaj 0.36"
Posted Image
2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/buc
Dimensiuni:40mm x 25mm x 23mm(L*W*H)
Working Current:<20mA
Display: Three digit 0.4" LED RED / BLUE/ GREEN
Posted Image
2. e) Voltmetru digital LCD 80V-300V AC - 30lei/buc
Precizie:±1.5%
Dim: 55x40x25mm
Se introduce direct in priza
Posted Image
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - stoc 0
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
Posted Image
3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 60lei/buc
3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc
Posted Image
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
Oferta!  3 buc -25lei  /  5buc - 40lei  /  10buc - 70lei
4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 20lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Imax: 3A cu radiator
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
4.c) Sursa STEP-UP cu LM2577 - 15lei/buc
4. d) Sursa DC-DC step-down  5A - 18lei/buc
Uin: 4V-38V
Uout: 1.25V-36V
Output current: 0-5A
Transfer efficiency:96%(max)
Switching Frequency:180KHz
Posted Image
4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc
4.f) Sursa DC-DC Step-down CC + CV  9A - 50lei/buc
reglare tensiune si curent
IN: 5-40V ; OUT: 1.25 - 35V
Curent iesire: 0.2-9A (max)
4.g) Sursa STEP-UP boost 6A - 35lei
IN:10-32V ;  OUT:10-35V
5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc
6.Senzor PIR - 10lei/buc
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 20lei/buc
7.b)Set de 65 fire - 15lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
1p-1p Female - Female
1p-1p Male - Male
7.e) Mini breadboard 400 puncte - 15lei/buc
7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc
Apply to MB102 breadboard
Input voltage: 6.5-12 V (DC) or USB power supply
Output voltage: 3.3V/5V can switch over
Maximum output current: <700 ma
Posted Image
8. Termometru IR (infrarosu)  (-50 - 330°C - alim 2x1,5V AAA)  - 70lei/buc
Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc
Posted Image
9.  Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
http://imageshack.us...2/3916/uho4.jpg
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
11.
12. a). ARDUINO UNO R3 + cablu USB - 50ei/buc
12. b). Shield LAN W5100 - 50lei/buc
12. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc
12. d)  LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc
12.e) Shield Arduino Multifunctional - 60lei
4 digit 7-segment LED display module driven by two serial 74HC595’s
4 LED’s
10K potentiometer
3 x push buttons
Piezo buzzer
DS18B20 or LM35 temperature sensor interface (not included)
Infrared receiver interface
Serial interface header for connection to serial modules
12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc
Posted Image
13. Set Remote control 4 canale - 25lei/set
14.
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
16. Senzor temperatura DS18B20 waterproof - 15lei/buc
lungime cablu: 1m
17. Diverse module
17.a) Modul MAX7219 8 digiti rosu - 12lei/buc
17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 70lei/buc
17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie)  - 10lei/buc
17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc
17.e) Senzor Barometric / presiune BMP180 - 15lei/buc
17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 6lei/buc
17.g) Sursa Step-UP USB 5V max.600mA - 5lei/buc
17.h) Modul WI-FI ESP8266 ESP-12E - 25lei/buc
17.i) Modul TEA5767 Radio FM - 7lei/buc
17.j) Modul(set) RF 433MHz - 10lei/set
17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc  (versiunea cu volume control -10lei/buc)
17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 15lei/buc
Posted Image
18. Module Diverse:
18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set ( optional mai multe brelocuri albastre)
18.b) Modul senzor touch 1 canal - 9lei/buc
18.c) Modul senzor touch 4 canale - 12lei/buc
18.d) Modul senzor touch 8 canale - 15lei/buc
Posted Image
Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 30lei/buc
Modul HC-05 bluetooth serial port, master-slave, 6pini - 30lei/buc
Posted Image
19.
20. Display NOKIA5110 - 20lei/buc
21.
22.
23. Socluri ZIF40
Soclu ZIF40 universal gold plated black - 10lei/buc
Soclu ZIF40 universal gold plated blue   - 10lei/buc
24.
25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 25lei/set - 1buc disponibila
-se poate lega si in punte (1x36W)
-alim. 2x12V AC
-dim. 40x92mm
Modul display 4digits (RED) cu 595 - 15lei/buc
Modul WiFi ESP8266 ESP-12E - 25lei/buc
Modul Ethernet ENC28J60 - 25lei/buc
Modul MAX7219 dot matrix display 8x8 RED - 15lei/buc
NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc
Modul wireless 2.4G - NRF24L01 - 10lei/buc
Adaptoare USB-TTL
- Cu FTDI 232 - 25lei/buc
- Cu CH340G - 10lei/buc
Arduino NANO v3.0 - 20lei/buc  (fara cablu USB)
Adaptor pentru Arduino NANO - 20lei/buc
Posted Image
Amplificator 2x50W cu TDA7492 cu bluetooth - 85lei
-alim: 10-25V
-iesire: recomandat 8ohm ( suporta si 4, 6 sau 16 ohm)
-modul bluetooth V4.0 : CSR8635
-microfon
-AUX
Posted Image
Aparat de masurat umiditatea MD-4G - 60lei/buc
range: 5-40% ; Precizie ±1%
Alim: 9V
Aparat de masurat umiditatea - 80lei/buc
Range: 0-99,9% ; Precizie:±0.5%
Calibrare pt 4 grupuri de tip lemn
Alim:9V
Posted Image
Multitester LCD grafic cu Mega328 - 80lei
Display grafic 128x64 LCD cu backlight
Testeaza si identifica componente, astfel:
-Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm
-Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare.
-Bobine: 0.01mH - 20H
-Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP
-Tiristoare si triace
-LED-uri si alte diode (identifica tens de deschidere)
Durata masura: 2s (exceptie la condensatorii de capacitate mai mare)
Alimentare: 9V
Posted Image
Termostat digital - 20lei/buc
Dimensiuni: 48x40mm
Temperature control mode: ON / OFF
Temperature range :-50-110 Celsius
Resolution:0.1 Celsius
Control accuracy: 0.1 Celsius
Hysteresis  accuracy: 0.1Celsius
Refresh rate: 0.5S
High temperature protection: 0-110 Celsius
Supply voltage: for DC 12V
Output power: 10A relay
Measurement input: NTC (10K 0.5%) Waterproof Sensor
Posted Image
Modul releu 1-channel 5V (low trigger) - 9lei/buc
Posted Image
Modul RFID Reader RDM6300 - 20lei(buc)
-125KHz
- compatibil cu EM4100 RFID Card Key ID (nu sunt incluse)
- Baud rate: 9600
- Interface: TTL level RS232 format
- Working voltage: DC 5V(+/-5%)
- Working current: <50mA
- Receive distance: 20-50mm
- Wiring size: 46*32*3mm
- PCB size: 38.5*19*9mm
Posted Image
Modul charger TP4056 cu protectie - 6lei/buc
Posted Image
Posted Image
Sursa DC-DC step-down 5A + Voltmetru LED - 30lei/buc
Sursa DC-DC CV CC step-down 5A + Voltmetru LED 4 digiti + USB - 45lei/buc
Posted Image
Seturi semireglabili ( diverse valori) - 45lei/set
multitura si "normali"
Posted Image
Kit modem M590E GSM GPRS - 15lei
900-1800M
Alim: 5V/1A
Obs. Desi sunt sigilate, se pare ca modulul GSM a mai fost lipit (testat?)
Posted Image
Arduino LilyPad 328 - 20lei/buc
Posted Image
Adaptor RS232-TTL cu MAX232 - 4lei/buc
Posted Image
Posted Image
Modul amplificator clasa D 2x15W cu PAM8610 - 10lei/buc
Modul amplificator clasa D 2x15W cu PAM8610 cu volume control - 25lei/buc
Modul receptor bluetooth + amplif. 2x3W cu PAM8403 - 45lei/buc
Modul amplificator mono 35W cu TDA8932 - 25lei/buc
Modul amplificator clasa D 2x15W cu TPA3110 - 65lei/buc
Sursa stabilizata 5A - 15lei/buc
In: 5-32V
Out: 0.8-32V
Posted Image
Tester USB voltmetru / ampermetru - 25lei/buc
Alim:3-9V
Curent masurat: 0-3A(max)
Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc.
Posted Image
-alim: 10-25V
-microfon
-AUX
Posted Image
Programator clona PICkit2 - 80lei/buc
Programator clona PICkit3 - 100lei/buc
Adaptor soclu ZIF40 - 25lei/buc
Posted Image
Modul WiFi D1 mini NodeMCU-25lei/buc
Posted Image
Lanterna 7W - 20lei/buc
Led Q5, zoom, focus ajustabil
1xAA sau 1x14500
Posted Image
Transmitator audio bluetooth - 70lei/buc
-acumulator inclus
-cablu audio si cablu incarcare(USB) incluse
Posted Image
Salut,
as fi interesat de 2 module GSM, alea la  15 lei, lasa-mi te rog  un numar de contact in privat ca sa te intreb mai multe. Multumesc!
Editat de Vlad Mihai
