LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
Dacă mai este valabilă oferta, doresc si eu două Volt-Ampermetre RED + BLUE 0-100V 0-10A - 35lei/buc modelul cu V si A luminate, o sursă DC-DC step-down cu LM2596 - 10lei/buc și dacă aveți, numai mandrina la o mini freza pentru PCB. Aștept răspuns.Vă mulțumesc.
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei
Posted Image
LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
Posted Image Posted Image
2.a) Voltmetru de panou - Pret: 20lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
Posted Image
2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc
Dimension: 23mmx15mmx10mm
Sample period:500ms ; Resolution:1%+1digit
Reverse Voltage Protection
Posted Image
2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc
Afisaj 0.36"
Posted Image
2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/buc
Dimensiuni:40mm x 25mm x 23mm(L*W*H)
Working Current:<20mA
Display: Three digit 0.4" LED RED / BLUE
Posted Image
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc - stoc limitat!
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
Posted Image
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
Posted Image
4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Imax: 3A cu radiator
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
Posted Image
4.c) Sursa STEP-UP cu LM2577 - 15lei/buc
Posted Image
5. Soclu ZIF40 - 4lei/buc
Posted Image
- disponibil 1 buc
6.Senzor PIR - 10lei/buc
Posted Image
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 26lei/buc
7.b)Set de 65 fire - 14lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
Posted Image
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
Posted Image
7. d) Mini-breadboard 170 puncte - 8lei/buc
Posted Image
7.e) Mini breadboard 400 puncte - 13lei/buc
7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc
Apply to MB102 breadboard
Input voltage: 6.5-12 V (DC) or USB power supply
Output voltage: 3.3V/5V can switch over
Maximum output current: <700 ma
Posted Image
8. Mini freza pentru PCB - 25lei/buc
Alimentare 12V
+spiral de 0.8mm
Posted Image
9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
9. b). Set spirale 0.3mm - 1.2mm - 45lei/set
Numai set intreg.
carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm,
http://i40.tinypic.com/xddpvn.jpg
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
http://imageshack.us/a/img259/3507/l5yk.jpg
11. Termometru digital de panou Pret: 15lei/buc
Interval de masura: -50°C -> 110°C
Rezolutie afisare: 0.1
Precizie masurare: ±1°C
Alim: 2 buc LR44 (incluse)
Lung cablu semzor: 1m
Dimensiuni: 47*28*14mm
http://i39.tinypic.com/5d1cfr.jpg
12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc
http://imageshack.us/a/img30/7024/pspa.jpg
12. b). Motor Drive Shield L293D pt. ARDUINO UNO, MEGA - 35ei/buc
http://i43.tinypic.com/1539r9i.jpg
12. c) Arduino MEGA 2560 R3 + cablu USB - 100lei/buc
http://i61.tinypic.com/2usa62p.jpg
13. Afisaje LED
http://imageshack.us/a/img62/4617/2f8f.jpg
4 Digits :CEAS - 5lei/buc
Pin Number: 12 pins.
Digit Number: 4 digits.
Common anode.
Digit Height: 0.56 inch.
Color: Red.
3 DIGITI + comun - 2lei/buc
Display: 0.36" LED digital tube
Range: 1.9 -2.2V
Display Color: Red
Size: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W)
10-Segmente GREEN - 2lei/buc
Size: Approx. 2.4*1*1.4cm (L*W*H)
14. Diferite CI-uri
http://imageshack.us/a/img132/8272/f3uq.jpg
DS12C887+ - 20 lei/buc
M48T02-70PC1 - 25lei/buc
M48T02-150PC1 - 25lei/buc
M4T28-BR12SH1 - 10lei/buc
MAX1496 - 15lei/buc
MAX7219 - 10lei/buc
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
http://i62.tinypic.com/zxjz8l.jpg
16. Ampermetru de panou BLUE 0-10A - 20lei/buc
http://i44.tinypic.com/29kw0nt.jpg
17. Player MP3 + radio + remote - 60lei/buc
http://i59.tinypic.com/2jfhlph.jpg
http://i62.tinypic.com/11ha34l.jpg
1.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack
18. Sursa Step-UP USB 5V max.600mA - 7lei/buc
http://i62.tinypic.com/m5w86.jpg
Size:34 (mm) x16.2 (mm) ultra-small size
Uin: 1-5V; Output 5V stabilizat max.600mA
Se pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon
Comanda minima 70lei
Transport+Ramburs: 11lei
Probabil La aceste preturi se adauga si pretul de transport ???,care la o lista subtire ,nu s-ar justifica. De exemplu,doresc:7.a) Breadboard 830 puncte - 26lei/buc7.b)Set de 65 fire - 14lei/set 11. Termometru digital de panou Pret: 15lei/buc;doresc de asemenea o clona PICKIT2,pe care nu cred ca dv.o aveti.Nu stiu ,sint si alte solutii?!(de exemplu sa ne intilnim daca locuiti in bucuresti)?(Scuzati de intrebare Nu ca i-mi doresc neaparat sa ne intilnim).
Posted Image
Posted Image
Posted Image
Afisaj 0.36"
Posted Image
Posted Image
Posted Image
Uin: 3.2V-40V
Uout: 1.25V-35V
Dimensiuni: 43x21mm
Posted Image
Uin: 4-40 v
Uout:1.25V - 37V
Posted Image
Posted Image
Posted Image
- disponibil 1 buc
Posted Image
Posted Image
Lungime 20cm
1p-1p Male - Female
Posted Image
Posted Image
Posted Image
Alimentare 12V
+spiral de 0.8mm
Posted Image
Tip Diameter: 0.8mm
45lei/set de 10buc
Numai set intreg.
13. Afisaje LED
Common anode.
Color: Red.
Range: 1.9 -2.2V
Display Color: Red
14. Diferite CI-uri
MAX1496 - 15lei/buc
MAX7219 - 10lei/buc
Ieri am ridicat coletul de la poștă, totul este OK, marfă de calitate, user foarte corect și prompt, să tot faci afaceri cu așa oameni.Să ne trăiești Sorine și baftă la vânzări.
