bozenai Postat Martie 2, 2016 Partajează Postat Martie 2, 2016 Dati un bip la 0729941474 sa vorbim,vreau sa cumpăr si eu ceva.V-am trimis si un MP,dar probabil nu l-am trimis bine. Link spre comentariu
soringt Postat Martie 2, 2016 Autor Partajează Postat Martie 2, 2016 (editat) 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei; LCD grafic 128x64 - 65leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 30lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc -stoc 0Display color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm Oferta! 3 buc -25lei 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/buc Uin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc 4.f) Sursa DC-DC Step-down CC + CV 9A - 55lei/buc reglare tensiune si curent IN: 5-40V ; OUT: 1.25 - 35V Curent iesire: 0.2-9A (max) 4.g) Sursa STEP-UP boost 6A - 35lei IN:10-32V ; OUT:10-35V 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 20lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7.e) Mini breadboard 400 puncte - 15lei/buc 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 70lei/buc Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. 12. a). ARDUINO UNO R3 + cablu USB - 50ei/buc 12. b). Shield LAN W5100 - 50lei/buc 12. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RH Senzor de temperatura+ umiditate DHT11 (albastru) - 7lei/buc 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 15lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 80lei/buc 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 11lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 12lei/buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 7lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc 17.h) Modul WI-FI ESP8266 ESP-12E - 25lei/buc 17.i) Modul TEA5767 Radio FM - 7lei/buc 17.j) Modul(set) RF 433MHz - 10lei/set 17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc (versiunea cu volume control -10lei/buc) 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 15lei/buc 18. Module Diverse: 18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set ( optional mai multe brelocuri albastre) 18.b) Modul senzor touch 1 canal - 9lei/buc 18.c) Modul senzor touch 4 canale - 12lei/buc 18.d) Modul senzor touch 8 canale - 15lei/buc Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 30lei/buc Modul HC-05 bluetooth serial port, master-slave, 6pini - 30lei/buc 18.f) Modul audio stereo KRC-86B v4.0 bluetooth 2.1 + EDR - 80lei/buc 19. 20. Display NOKIA5110 - 20lei/buc 21. VK-172 GMOUSE USB GPS/GLONASS USB - 70lei/buc Support DGPS [WAAS, EGNOS and MSAS] Reference coordinate system: WGS-84 Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Supported operating systems: Windows 8/7/Vista/XP/CE VK-172 automatically adapt the baud rate, the baud rate has any data output Support Google Earth Based on G7020-KT u-blox 7 GPS/GNSS C / A code, 1.023MHz stream Receive Band: L1 [1575.42MHz] Tracking Channels: 56 Support DGPS [WAAS, EGNOS and MSAS] Positioning performance : 2D plane: 5m [average] 2D plane: 3.5m [average], has DGPS auxiliary. Drift: <0.02m / s Reference coordinate system: WGS-84 Maximum altitude: 18,000 m Maximum speed: 500m / s Acceleration: <4g Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Warm start time: 28s [average] Hot start time: 1s [average] Recapture Time: 0.1s [average] 22. 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc 24. 25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 25lei/set - 1buc disponibila -se poate lega si in punte (1x36W) -alim. 2x12V AC -dim. 40x92mm Modul display 4digits (RED) cu 595 - 15lei/buc Modul WiFi ESP8266 ESP-12E - 25lei/buc Modul Ethernet ENC28J60 - 25lei/buc Modul MAX7219 dot matrix display 8x8 RED - 15lei/buc NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc Modul wireless 2.4G - NRF24L01 - 10lei/buc Adaptoare USB-TTL - Cu FTDI 232 - 25lei/buc - Cu CH340G - 10lei/buc Arduino NANO v3.0 - 20lei/buc (fara cablu USB) Adaptor pentru Arduino NANO - 20lei/buc Punte H DC stepper motor cu L298N - 20lei Editat Martie 2, 2016 de soringt Link spre comentariu
Vizitator mihai1961 Postat Martie 3, 2016 Partajează Postat Martie 3, 2016 Asi dori si eu un LCD BLUIE compatibil HD4478 16X2 si unul de 20x4 daca se poate. Ps. nu stiu cum s-a iau legatura! Link spre comentariu
autom Postat Martie 3, 2016 Partajează Postat Martie 3, 2016 (editat) Sa traiti! Multumesc pentru promptitudine. Editat Martie 3, 2016 de autom Link spre comentariu
soringt Postat Martie 4, 2016 Autor Partajează Postat Martie 4, 2016 (editat) Tuner digital USB DVB-T SDR Radio FM+DAB - 70lei/buc Tuner digital USB stick pentru DVB-T , DAB, SDR Radio FM -Chipset R820T + RTL2832U -Suporta MPEG-2, MPEG-4(H.264) -Microsoft Windows XP / 2000 / Vista / 7 / 8 Aparat de masurat umiditatea MD-4G - 60lei/buc range: 5-40% ; Precizie ±1% Alim: 9V Aparat de masurat umiditatea - 80lei/buc Range: 0-99,9% ; Precizie:±0.5% Calibrare pt 4 grupuri de tip lemn Alim:9V Multitester LCD grafic cu Mega328 - 85lei Display grafic 128x64 LCD cu backlight Testeaza si identifica componente, astfel: -Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm -Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare. -Bobine: 0.01mH - 20H -Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP -Tiristoare si triace -LED-uri si alte diode (identifica tens de deschidere) Durata masura: 2s (exceptie la condensatorii de capacitate mai mare) Alimentare: 9V Editat Martie 4, 2016 de soringt Link spre comentariu
autom Postat Martie 6, 2016 Partajează Postat Martie 6, 2016 Voltmetrul functioneaza impecabil, multumesc! Link spre comentariu
soringt Postat Martie 8, 2016 Autor Partajează Postat Martie 8, 2016 Anunt valabil. Link spre comentariu
soringt Postat Martie 9, 2016 Autor Partajează Postat Martie 9, 2016 (editat) Anunt valabil 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 25lei/buc Tuner digital USB DVB-T SDR Radio FM+DAB - 70lei/buc Tuner digital USB stick pentru DVB-T , DAB, SDR Radio FM -Chipset R820T + RTL2832U ( ver albastra este cu R820T2) -Suporta MPEG-2, MPEG-4(H.264) -Microsoft Windows XP / 2000 / Vista / 7 / 8 Lanterna LED - 40lei/buc Alim: 3x1.5 sau 1x 18650 Focus reglabil disponibil - 1buc Senzor temperatura PT100 - 7lei/buc Tester USB voltmetru / ampermetru - 25lei/buc Alim:3-9V Curent masurat: 0-3A(max) Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc. Comanda minima 70lei+ transport Discounturi in functie de comanda Editat Martie 9, 2016 de soringt Link spre comentariu
soringt Postat Martie 10, 2016 Autor Partajează Postat Martie 10, 2016 Anunt valabil. Link spre comentariu
soringt Postat Martie 11, 2016 Autor Partajează Postat Martie 11, 2016 Anunt valabil. Link spre comentariu
soringt Postat Martie 12, 2016 Autor Partajează Postat Martie 12, 2016 Anunt valabil. Modul Wi-Fi ESP-12E - 20lei/buc (oferta valabila doar in acest WE) Programator clona PICkit2 - 80lei/buc Programator clona PICkit3 - 100lei/buc (oferta valabila doar in acest WE) Adaptor soclu ZIF40 - 25lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 5lei/buc Se adauga: Dioda LASER 3V 650nm 5mW - 2lei/buc Modul releu 1-channel 5V (low trigger) - 9lei/buc Comanda minima 70lei+transport Link spre comentariu
Vizitator google09 Postat Martie 12, 2016 Partajează Postat Martie 12, 2016 Salut! Sunt nou pe forum si as vrea sa stiu daca pot comanda de la tine un modul din asta bluetooth model ovc3860? Link spre comentariu
soringt Postat Martie 12, 2016 Autor Partajează Postat Martie 12, 2016 @google09: Ai mesaj privat Link spre comentariu
soringt Postat Martie 13, 2016 Autor Partajează Postat Martie 13, 2016 Termostat digital - 20lei/buc Dimensiuni: 48x40mm Temperature control mode: ON / OFF Temperature range :-50-110 Celsius Resolution:0.1 Celsius Control accuracy: 0.1 Celsius Hysteresis accuracy: 0.1Celsius Refresh rate: 0.5S High temperature protection: 0-110 Celsius Supply voltage: for DC 12V Output power: 10A relay Measurement input: NTC (10K 0.5%) Waterproof Sensor Element Peltier TEC1-12705 - 20lei/buc 12V, 5A Diferenta max de temp: 66 grade C Dim: 40x40x4,6mm LED-uri 5mm straw-hat portocalii - 100buc / 10lei Link spre comentariu
soringt Postat Martie 15, 2016 Autor Partajează Postat Martie 15, 2016 Anunt valabil. Link spre comentariu
