LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei;  LCD grafic 128x64 - 65lei
LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
Posted Image
2.a) Voltmetru de panou - Pret: 20lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
Posted Image
2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc
Dimension: 23mmx15mmx10mm
Sample period:500ms ; Resolution:1%+1digit
Reverse Voltage Protection
2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/buc
Afisaj 0.36"
Posted Image
2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/buc
Dimensiuni:40mm x 25mm x 23mm(L*W*H)
Working Current:<20mA
Display: Three digit 0.4" LED RED / BLUE/ GREEN
Posted Image
2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc
Precizie:±1.5%
Dim: 55x40x25mm
Se introduce direct in priza
Posted Image
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 35lei/buc
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc -stoc 0
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
Posted Image
3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 65lei/buc
3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc
Posted Image
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
Oferta!  3 buc -25lei
4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Imax: 3A cu radiator
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
4.c) Sursa STEP-UP cu LM2577 - 15lei/buc
4. d) Sursa DC-DC step-down  5A - 20lei/buc
Uin: 4V-38V
Uout: 1.25V-36V
Output current: 0-5A
Transfer efficiency:96%(max)
Switching Frequency:180KHz
Posted Image
Posted Image
4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc
Posted Image
4.f) Sursa DC-DC Step-down CC + CV  9A - 55lei/buc
Posted Image
reglare tensiune si curent
IN: 5-40V ; OUT: 1.25 - 35V
Curent iesire: 0.2-9A (max)
4.g) Sursa STEP-UP boost 6A - 35lei
IN:10-32V ;  OUT:10-35V
Posted Image
5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc
6.Senzor PIR - 10lei/buc
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 20lei/buc
7.b)Set de 65 fire - 15lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
1p-1p Female - Female
7. d) Mini-breadboard 170 puncte - 8lei/buc -stoc 0
7.e) Mini breadboard 400 puncte - 15lei/buc - stoc 0
7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc
Apply to MB102 breadboard
Input voltage: 6.5-12 V (DC) or USB power supply
Output voltage: 3.3V/5V can switch over
Maximum output current: <700 ma
Posted Image
8. Termometru IR (infrarosu)
(-50 - 330°C - alim 2x1,5V AAA)  - 70lei/buc
(-50 - 500°C - alim 2x1,5V AAA) - 85lei/buc
Posted Image
Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc
Posted Image
9.  Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
http://imageshack.us...2/3916/uho4.jpg
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
11. Termometru digital de panou Pret: 12lei/buc
Interval de masura: -50°C -> 110°C
Rezolutie afisare: 0.1
Precizie masurare: ±1°C
Alim: 2 buc LR44 (incluse)
Lung cablu semzor: 1m
Dimensiuni: 47*28*14mm
12. a). ARDUINO UNO R3 + cablu USB - 60ei/buc
12. b). Shield LAN W5100 - 50lei/buc
12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc
12. d)  LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc
12.e) Shield Arduino Multifunctional - 60lei
4 digit 7-segment LED display module driven by two serial 74HC595’s
4 LED’s
10K potentiometer
3 x push buttons
Piezo buzzer
DS18B20 or LM35 temperature sensor interface (not included)
Infrared receiver interface
Serial interface header for connection to serial modules
12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc
Posted Image
13. Set Remote control 4 canale - 25lei/set
14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc
-utilizari diverse ( UV box pentru expunere,, etc)
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
Senzor de temperatura+ umiditate DHT11 (albastru) - 7lei/buc
16. Senzor temperatura DS18B20 waterproof - 15lei/buc
lungime cablu: 1m
17. Diverse module
17.a) Modul MAX7219 8 digiti rosu - 18lei/buc
17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 80lei/buc
17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie)  - 11lei/buc
17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc
17.e) Senzor Barometric / presiune BMP180 - 12lei/buc
17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 7lei/buc
17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc
17.h) Modul WI-FI ESP8266 ESP-12  sau ESP-12E - 25lei/buc
17.i) Modul TEA5767 Radio FM - 7lei/buc
17.j) Modul(set) RF 433MHz - 10lei/set
17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc
17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 20lei/buc
Posted Image
18. Module Diverse:
18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set ( optional mai multe brelocuri albastre)
18.b) Modul senzor touch 1 canal - 9lei/buc
18.c) Modul senzor touch 4 canale - 13lei/buc
18.d) Modul senzor touch 8 canale - 17lei/buc
Posted Image
19. Aparat de masurat distanta cu ultrasunete - 80lei/buc
Power supply: 1 x 9V
Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)
Auto stop: switches off if you do not press any key for 4 min
Laser beam: Wattage 1mW
Working temperature: 0oC ~ 43oC
Range: 0.91m to 18m
Dimensions (H-P-l): 142 x 73 x 47mm
20. Display NOKIA5110 - 20lei/buc
21. VK-172 GMOUSE USB GPS/GLONASS USB - 70lei/buc
Posted Image
Support DGPS [WAAS, EGNOS and MSAS]
Reference coordinate system: WGS-84
Tracking sensitivity:-162dBm
Acquisition sensitivity:-160dBm
Cold Start Time: 29s [average]
Supported operating systems: Windows 8/7/Vista/XP/CE
VK-172 automatically adapt the baud rate, the baud rate has
any data output
Support Google Earth
Based on G7020-KT u-blox 7 GPS/GNSS
C / A code, 1.023MHz stream
Receive Band: L1 [1575.42MHz]
Tracking Channels: 56
Positioning performance :
2D plane: 5m [average]
2D plane: 3.5m [average], has DGPS auxiliary.
Drift: <0.02m / s Reference coordinate system: WGS-84
Maximum altitude: 18,000 m
Maximum speed: 500m / s
Acceleration: <4g Tracking sensitivity:-162dBm
Warm start time: 28s [average]
Hot start time: 1s [average]
Recapture Time: 0.1s [average]
22.
23. Socluri ZIF40
a) Soclu ZIF40 wide nickel plated - 4lei/buc
b) Soclu ZIF40 universal gold plated black - 12lei/buc
c) Soclu ZIF40 universal gold plated blue   - 10lei/buc
24.
25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 45lei/set
-se poate lega si in punte (1x36W)
-alim. 2x12V AC
-dim. 40x92mm
Posted Image
Comanda minima 70lei
Transport+Ramburs: 11lei
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
te rog sa-mi expediezi-termostat digital cu 30lei-2buc        -LCD blue 1602-16x2 cu 15lei-3buc
        Talpos Ilie     loc.Bobota    jud.salaj   cod.457040
       tel.0742312123
                                     Multumesc
8.e) Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 35lei/buc
Posted Image
18.f) Modul audio stereo KRC-86B v4.0 bluetooth 2.1 + EDR - 80lei/buc
Posted Image
25. a) Amplificator audio TDA7297 2x15W - 35lei/buc
Ualim: 6-18V (recomandat 12V)
Putere: 2x15W
Dim: 52 x 47 x 52
Posted Image
25. b) Voltmetru + termometru auto 12V - 45lei/buc
Alimentare de la bricheta
Posted Image
25.c) Acumulatori LiPo 500mA - 25lei/buc
dimensiuni: 31 x 26 x 6.5mm
disponibile 2 buc
Posted Image
Posted Image
5.b) Sursa step-down CV-CC LED driver , Lithium charger, max.5A - 25lei/buc
Switching frequency: 300KHz
Conversion efficiency: 95% (the highest)
Output current: adjustable maximum 5A
Output voltage: 0.8V-30V
Input voltage: 5V-32V
Rectification: non-synchronous rectification
Module Properties: non-isolated constant current and voltage module
17.h) Adaptor PCB pentru modul ESP-12 WiFi - 8lei/buc
17.m) NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc
Posted Image
17.n) NodeMCU v0.9 ESP8266 cu ESP-12 - 60lei/buc
Posted Image
25.d) Modul MP3 player - 30lei/buc
Power range: 3.7~5.5V
Product size: 45mm*36mm
Onboard 2Wmonoamplifier(5V power of up to 3W) - 4Ω3W
MicroUSB port.Through the mobile phone data line can use mobile power supply or the USB cable to charge the MP3 battery,also can use 3.7V lithiumbattery,orUSB 5V power supply
Support U disk (test 32G), TF Card (test 16G) play mode; power on default TF card mode
Buttons can be adjusted up and down to control songs,volume up and down, pause or play, mode switching
Adaptor cu soclu ZIF40 pentru programatoare PICkit2 sau 3 - 25lei/buc
Posted Image
Programator PICkit 2 clona - 90lei/buc
Posted Image
Posted Image
Programator PICkit 3 clona - 115lei/buc
PIC16F877A capsula PLCC 44 pin - 9buc/100lei
Posted Image
Arduino NANO v3.0 - 20lei/buc
(fara cablu USB)
Posted Image
Microcontroller Atmel ATmega328
Operating Voltage (logic level): 5V
Input Voltage (recommended): 7V ~ 12V
Input Voltage (limits): 6V ~ 20 V
Digital I/O Pins: 14 (of which 6 provide PWM output)
Analog Input Pins: 8
DC Current per I/O Pin: 40mA
Flash Memory: 32KB (ATmega328) (of which 2 KB used by bootloader)
SRAM: 2KB (ATmega328)
EEPROM: 1KB (ATmega328)
Clock Speed: 16MHz
12 Digital input / output ports:D2 ~ D13
8 analog inputs ports:A0 ~ A7
1 pairs of TTL level serial transceiver ports RX / TX
6 PWM ports:D3, D5, D6, D9, D10, D11
Atmel Atmega328P-AU MCU
CH340 USB driver
Support USB download and Power
Support for external 5V ~ 12V DC power supply
Support power supply by 9V battery
Support ISP download
Tester USB voltmetru / ampermetru - 35lei/buc
Alim:3-9V
Curent masurat: 0-3A(max)
Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc.
Posted Image
LED-uri 5mm straw-hat portocalii - 100buc / 10lei
Posted Image
Adaptoare USB-TTL
Cu FTDI 232 - 25lei/buc
Cu CH340G - 10lei/buc
Posted Image
Element Peltier TEC1-12705 - 20lei/buc
12V, 5A
Diferenta max de temp: 66 grade C
Dim: 40x40x4,6mm
Posted Image
Modul wireless 2.4G - NRF24L01 - 10lei/buc
Alim: 1.9 -3.6V
Posted Image
LCD 128x64 grafic backlight Blue - 65lei/buc
Multitester LCD grafic cu Mega328 - 85lei
Display grafic 128x64 LCD cu backlight
Testeaza si identifica componente, astfel:
-Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm
-Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare.
-Bobine: 0.01mH - 20H
-Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP
-Tiristoare si triace
-LED-uri si alte diode (identifica tens de deschidere)
Durata masura: 2s (exceptie la condensatorii de capacitate mai mare)
Alimentare: 9V
Posted Image
Anunt valabil.
Se adauga:
Modul PAM8403 amplificator 2x3W cu volume control - 12lei/buc
Posted Image
Modul MAX7219 dot matrix display 8x8 RED - 15lei/buc
Posted Image
Modul Ethernet ENC28J60 - 25lei/buc
Posted Image
Carcasa plastic pt Raspbery Pi 2 - 25lei/buc
2 modele
Posted Image
Posted Image
Modul Radio FM PLL&DSP 87-108MHz - 60lei/buc
Posted Image
Comanda minima 70lei + transport.
Editat de soringt
