soringt Postat Septembrie 18, 2015 Autor Partajează Postat Septembrie 18, 2015 Este postata poza pt 25. d).Modul MP3 player Link spre comentariu
Vizitator victor ponta Postat Septembrie 18, 2015 Partajează Postat Septembrie 18, 2015 Deja am ''consumat'' si o a treia comanda. Multumesc pentru bonusuri si reduceri. Livrat rapid,promisiuni respectate,totul perfect. Link spre comentariu
soringt Postat Septembrie 21, 2015 Autor Partajează Postat Septembrie 21, 2015 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc - momentan stoc 0 Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 35lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc -stoc 0Display color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm Oferta! 3 buc -25lei 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/buc Uin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 35lei/buc 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 20lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc -stoc 07.e) Mini breadboard 400 puncte - 15lei/buc - stoc 0 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 70lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 85lei/buc Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. Termometru digital de panou Pret: 12lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mm Culoare ALB - stoc 012. a). ARDUINO UNO R3 + cablu USB - 60ei/buc 12. b). Shield LAN W5100 - 50lei/buc 12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RH Senzor de temperatura+ umiditate DHT11 (albastru) - 7lei/buc 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 18lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 80lei/buc 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 11lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 12lei/buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 7lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc 17.h) Modul WI-FI ESP8266 ESP-12 sau ESP-12E - 30lei/buc 17.i) Modul TEA5767 Radio FM - 7lei/buc 17.j) Modul(set) RF 433MHz - 10lei/set 17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 20lei/buc 18. Module Diverse: 18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set ( optional mai multe brelocuri albastre) 18.b) Modul senzor touch 1 canal - 9lei/buc 18.c) Modul senzor touch 4 canale - 13lei/buc 18.d) Modul senzor touch 8 canale - 17lei/buc 19. Aparat de masurat distanta cu ultrasunete - 80lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. VK-172 GMOUSE USB GPS/GLONASS USB - 70lei/buc Support DGPS [WAAS, EGNOS and MSAS] Reference coordinate system: WGS-84 Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Supported operating systems: Windows 8/7/Vista/XP/CE VK-172 automatically adapt the baud rate, the baud rate has any data output Support Google Earth Based on G7020-KT u-blox 7 GPS/GNSS C / A code, 1.023MHz stream Receive Band: L1 [1575.42MHz] Tracking Channels: 56 Support DGPS [WAAS, EGNOS and MSAS] Positioning performance : 2D plane: 5m [average] 2D plane: 3.5m [average], has DGPS auxiliary. Drift: <0.02m / s Reference coordinate system: WGS-84 Maximum altitude: 18,000 m Maximum speed: 500m / s Acceleration: <4g Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Warm start time: 28s [average] Hot start time: 1s [average] Recapture Time: 0.1s [average] 22. 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc 24. 25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 45lei/set -se poate lega si in punte (1x36W) -alim. 2x12V AC -dim. 40x92mm Comanda minima 70leiTransport+Ramburs: 11lei Link spre comentariu
soringt Postat Septembrie 23, 2015 Autor Partajează Postat Septembrie 23, 2015 8.e) Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 35lei/buc 18.f) Modul audio stereo KRC-86B v4.0 bluetooth 2.1 + EDR - 80lei/buc 25. a) Amplificator audio TDA7297 2x15W - 35lei/buc Ualim: 6-18V (recomandat 12V) Putere: 2x15W Dim: 52 x 47 x 52 25. b) Voltmetru + termometru auto 12V - 45lei/buc Alimentare de la bricheta 4.e) Sursa DC-DC STEP-UP 6A - 35lei/buc Input: 10-32V Output: 12-35V (setata default pe 19V) Iout: max 6A Dim: 65 x 49 x 23mm disponibil: 1 buc. 25.c) Acumulatori LiPo 500mA - 25lei/buc dimensiuni: 31 x 26 x 6.5mm disponibile 2 buc 5.b) Sursa step-down CV-CC LED driver , Lithium charger, max.5A - 25lei/buc Switching frequency: 300KHz Conversion efficiency: 95% (the highest) Output current: adjustable maximum 5A Output voltage: 0.8V-30V Input voltage: 5V-32V Rectification: non-synchronous rectification Module Properties: non-isolated constant current and voltage module 17.h) Adaptor PCB pentru modul ESP-12 WiFi - 8lei/buc 17.m) NodeMCU v2 ESP8266 cu ESP-12E - 70lei/buc 17.n) NodeMCU v0.9 ESP8266 cu ESP-12 - 60lei/buc 25.d) Modul MP3 player - 30lei/buc Power range: 3.7~5.5V Product size: 45mm*36mm Onboard 2Wmonoamplifier(5V power of up to 3W) - 4Ω3W MicroUSB port.Through the mobile phone data line can use mobile power supply or the USB cable to charge the MP3 battery,also can use 3.7V lithiumbattery,orUSB 5V power supply Support U disk (test 32G), TF Card (test 16G) play mode; power on default TF card mode Buttons can be adjusted up and down to control songs,volume up and down, pause or play, mode switching Adaptor cu soclu ZIF40 pentru programatoare PICkit2 sau 3 - 25lei/buc Programator PICkit 2 clona - 90lei/buc Programator PICkit 3 clona - 115lei/buc Carcasa transparenta pentru Arduino MEGA 2560 R3 - 30lei/buc PIC16F877A capsula PLCC 44 pin - 9buc/100lei Arduino NANO v3.0 - 20lei/buc (fara cablu USB) Microcontroller Atmel ATmega328 Operating Voltage (logic level): 5VInput Voltage (recommended): 7V ~ 12VInput Voltage (limits): 6V ~ 20 VDigital I/O Pins: 14 (of which 6 provide PWM output)Analog Input Pins: 8DC Current per I/O Pin: 40mAFlash Memory: 32KB (ATmega328) (of which 2 KB used by bootloader)SRAM: 2KB (ATmega328)EEPROM: 1KB (ATmega328)Clock Speed: 16MHz12 Digital input / output ports:D2 ~ D138 analog inputs ports:A0 ~ A71 pairs of TTL level serial transceiver ports RX / TX6 PWM ports:D3, D5, D6, D9, D10, D11Atmel Atmega328P-AU MCUCH340 USB driverSupport USB download and PowerSupport for external 5V ~ 12V DC power supplySupport power supply by 9V batterySupport ISP download Tester USB voltmetru / ampermetru - 35lei/buc Alim:3-9V Curent masurat: 0-3A(max) Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc. LED-uri 5mm straw-hat portocalii - 100buc / 10lei Termostat digital - 30lei/buc Dimensiuni: 48x40mm Temperature control mode: ON / OFF Temperature range :-50-110 Celsius Resolution:0.1 Celsius Control accuracy: 0.1 Celsius Hysteresis accuracy: 0.1Celsius Refresh rate: 0.5S High temperature protection: 0-110 Celsius Supply voltage: for DC 12V Output power: 10A relay Measurement input: NTC (10K 0.5%) Waterproof Sensor Adaptoare USB-TTL Cu FTDI 232 - 25lei/buc Cu CH340G - 10lei/buc Link spre comentariu
Vizitator جوليان جوليان Postat Septembrie 24, 2015 Partajează Postat Septembrie 24, 2015 Buna seara ...v-am dat sms ca mai am nevoie de doua bustere step up ..nu stiu daca ati vazut mesajul pe tel...nu am vrut sa insist ca daca am vazut ca nu mi-ati raspuns am zis ca sa nu va deranjez Link spre comentariu
soringt Postat Septembrie 25, 2015 Autor Partajează Postat Septembrie 25, 2015 Anunt valabil. Link spre comentariu
soringt Postat Septembrie 26, 2015 Autor Partajează Postat Septembrie 26, 2015 Anunt valabil. Link spre comentariu
soringt Postat Septembrie 28, 2015 Autor Partajează Postat Septembrie 28, 2015 Anunt valabil. Se adauga: Element Peltier TEC1-12705 - 20lei/buc 12V, 5A Diferenta max de temp: 66 grade C Dim: 40x40x4,6mm Modul wireless 2.4G - NRF24L01 - 10lei/buc Alim: 1.9 -3.6V Link spre comentariu
PKP98 Postat Septembrie 29, 2015 Partajează Postat Septembrie 29, 2015 Am comandat si eu ieri un voltmetru si un ampermetru de panou si astazi au sosit.Marfa e de calitate ,coletul era bine impachetat,user serios. Recomand cu incredere. Multumesc inca o data ,numai bine. Link spre comentariu
soringt Postat Septembrie 29, 2015 Autor Partajează Postat Septembrie 29, 2015 Anunt valabil. Multitester LCD grafic cu Mega328 - 85lei Display grafic 128x64 LCD cu backlight Testeaza si identifica componente, astfel: -Rezistori : pana la 50M ohm, cu rezolutie 0.1 ohm -Condensatori: 25pF - 100.000uF; masoara simultan ESR pentru cond. >2uF. Masurarea se face dupa descarcare. -Bobine: 0.01mH - 20H -Tranzistori: N -channel and P-channel MOSFET, fact. de amplificare; NPN, PNP -Tiristoare si triace -LED-uri si alte diode (identifica tens de deschidere) Durata masura: 2s (exceptie la condensatorii de capacitate mai mare) Alimentare: 9V Link spre comentariu
soringt Postat Septembrie 30, 2015 Autor Partajează Postat Septembrie 30, 2015 Anunt valabil. Link spre comentariu
Vizitator dorummm Postat Octombrie 3, 2015 Partajează Postat Octombrie 3, 2015 Buna ziua "Sursa STEP-UP cu LM2577 " mai e valabil anuntul? ms. Link spre comentariu
soringt Postat Octombrie 3, 2015 Autor Partajează Postat Octombrie 3, 2015 Surse cu LM2577 nu mai sunt disponibile momentan.Mai am doar step-up de 6A. Pct 4.e). Link spre comentariu
GMCD Postat Octombrie 3, 2015 Partajează Postat Octombrie 3, 2015 Va salut, Ma intereseaza 5.b) Sursa step-down CV-CC LED driver, Lithium charger, max.5A Mai aveti? Link spre comentariu
ionpat Postat Octombrie 3, 2015 Partajează Postat Octombrie 3, 2015 salut 3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc daca mai pun un sunt,pot masura 200a Link spre comentariu
