LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei
Posted Image
LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
Posted Image Posted Image
2.a) Voltmetru de panou - Pret: 20lei/buc
RED - 17 lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
Posted Image
2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc
Dimension: 23mmx15mmx10mm
Sample period:500ms ; Resolution:1%+1digit
Reverse Voltage Protection
Posted Image
2. c) Mini-Voltmetru RED sau GREEN 0-100V - 15lei/buc
Afisaj 0.36"
Posted Image
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc - stoc limitat!
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
Posted Image
-o alta varianta
Posted Image
4.a) Sursa DC-DC step-down cu LM2596+ LED Power - 11lei/buc
Uin: 4.75V-35V
Uout: 1.25V-26V ; Imax: 3A cu radiator
LED de Power
Dimensiuni : 46x26mm
4.b) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
Posted Image
4.c) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
Posted Image
5. Soclu ZIF40 - 4lei/buc
Posted Image
- disponibil 1 buc
6.Senzor PIR - 11lei/buc
Posted Image
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 26lei/buc
7.b)Set de 65 fire - 14lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
Posted Image
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
Posted Image
8. Mini freza pentru PCB - 25lei/buc
Alimentare 12V
+spiral de 0.8mm
Posted Image
9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
9. b). Set spirale 0.3mm - 1.2mm - 45lei/set
Numai set intreg.
carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm,
Posted Image
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
Posted Image
11. Termometru digital de panou Pret: 15lei/buc
Interval de masura: -50°C -> 110°C
Rezolutie afisare: 0.1
Precizie masurare: ±1°C
Alim: 2 buc LR44 (incluse)
Lung cablu semzor: 1m
Dimensiuni: 47*28*14mm
Posted Image
12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc
http://imageshack.us/a/img30/7024/pspa.jpg
12. b). Motor Drive Shield L293D pt. ARDUINO UNO, MEGA - 35ei/buc
http://i43.tinypic.com/1539r9i.jpg
13. Afisaje LED
http://imageshack.us/a/img62/4617/2f8f.jpg
4 Digits :CEAS - 5lei/buc
Pin Number: 12 pins.
Digit Number: 4 digits.
Common anode.
Digit Height: 0.56 inch.
Color: Red.
3 DIGITI + comun - 2lei/buc
Display: 0.36" LED digital tube
Range: 1.9 -2.2V
Display Color: Red
Size: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W)
10-Segmente GREEN - 2lei/buc
Size: Approx. 2.4*1*1.4cm (L*W*H)
14. Diferite CI-uri
http://imageshack.us/a/img132/8272/f3uq.jpg
DS12C887+ - 20 lei/buc
M48T02-70PC1 - 25lei/buc
M48T02-150PC1 - 25lei/buc
M4T28-BR12SH1 - 10lei/buc
MAX1496 - 15lei/buc
MAX7219 - 10lei/buc
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
http://i62.tinypic.com/zxjz8l.jpg
Comanda minima 70lei
Transport+Ramburs: 11lei
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
Ai o bucata volt ampermetru? Pot sa masoare concomitent in acelasi circuit fiind alimentate din sursa din care masoara(tensiune >12Vcc, max 16Vcc). Intreb ca stiu ca unele ampetru si volmetru nu folosesc masa comuna.
Ai MP.
UP!
:101
Se adauga:
7. d) Mini-breadboard 170 puncte - 8lei/buc
Posted Image
16. Senzor temperatura DS18B20 - 20lei/buc
-digital, 1-Wire
-waterproof
-lungime cablu 1m
Posted Image
As putea sa-l alimentez la 12v?Care se vede la lumina zilei cel mai bine.Aveti unul care sa arate temperatura si tensiunea aceleasi dimensiuni?
Cele albastre si albe sunt f.puternice. Se alimenteaza intre 3.5 - 30V. Am si termometre de panou cu aceleasi dimensiuni.Daca mai ai intrebari, te rog sa folosesti MP.
