soringt Postat Iulie 3, 2015 Autor Partajează Postat Iulie 3, 2015 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/buc Uin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 38lei/buc 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 20lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc 7.e) Mini breadboard 400 puncte - 15lei/buc - stoc 0 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 70lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 80lei/buc Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. Termometru digital de panou Pret: 12lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mm Culoare ALB - stoc 012. a). ARDUINO UNO R3 + cablu USB - 60ei/buc 12. b). Shield LAN W5100 - 50lei/buc 12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RH Senzor de temperatura+ umiditate DHT11 (albastru) - 7lei/buc 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 18lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 80lei/buc 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 11lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 12lei/buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 7lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc 17.h) Modul WI-FI ESP8266 ESP-12 sau ESP-12E - 30lei/buc 17.i) Modul TEA5767 Radio FM - 7lei/buc 17.j) Modul(set) RF 433MHz - 10lei/set 17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 20lei/buc 18. Module Diverse: 18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set 18.b) Modul senzor touch 1 canal - 9lei/buc 18.c) Modul senzor touch 4 canale - 13lei/buc 18.d) Modul senzor touch 8 canale - 17lei/buc 19. Aparat de masurat distanta cu ultrasunete - 80lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. VK-172 GMOUSE USB GPS/GLONASS USB - 70lei/buc Support DGPS [WAAS, EGNOS and MSAS] Reference coordinate system: WGS-84 Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Supported operating systems: Windows 8/7/Vista/XP/CE VK-172 automatically adapt the baud rate, the baud rate has any data output Support Google Earth Based on G7020-KT u-blox 7 GPS/GNSS C / A code, 1.023MHz stream Receive Band: L1 [1575.42MHz] Tracking Channels: 56 Support DGPS [WAAS, EGNOS and MSAS] Positioning performance : 2D plane: 5m [average] 2D plane: 3.5m [average], has DGPS auxiliary. Drift: <0.02m / s Reference coordinate system: WGS-84 Maximum altitude: 18,000 m Maximum speed: 500m / s Acceleration: <4g Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Warm start time: 28s [average] Hot start time: 1s [average] Recapture Time: 0.1s [average] 22. Mini freza pentru PCB - 25lei/buc Alimentare 12V+spiral de 0.8mm 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc 24. 25. c) KIT DIY amplificator 2x18W ( 1x36W) cu TDA2030 - 45lei/set -se poate lega si in punte (1x36W) -alim. 2x12V AC -dim. 40x92mm Comanda minima 70leiTransport+Ramburs: 11lei Link spre comentariu
soringt Postat Iulie 4, 2015 Autor Partajează Postat Iulie 4, 2015 8.e) Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 35lei/buc 18.f) Modul audio stereo KRC-86B v4.0 bluetooth 2.1 + EDR - 80lei/buc 25. a) Amplificator audio TDA7297 2x15W - 35lei/buc Ualim: 6-18V (recomandat 12V) Putere: 2x15W Dim: 52 x 47 x 52 25. b) Voltmetru + termometru auto 12V - 50lei/buc Alimentare de la bricheta Programator PICkit2 clona - 100lei/buc 4.e) Sursa DC-DC STEP-UP 6A - 35lei/buc Input: 10-32V Output: 12-35V (setata default pe 19V) Iout: max 6A Dim: 65 x 49 x 23mm disponibil: 1 buc. 25.c) Acumulatori LiPo 500mA - 25lei/buc dimensiuni: 31 x 26 x 6.5mm disponibile 2 buc 5.b) Sursa step-down CV-CC LED driver , Lithium charger, max.5A - 25lei/buc Switching frequency: 300KHz Conversion efficiency: 95% (the highest) Output current: adjustable maximum 5A Output voltage: 0.8V-30V Input voltage: 5V-32V Rectification: non-synchronous rectification Module Properties: non-isolated constant current and voltage module 17.h) Adaptor PCB pentru modul ESP-12 WiFi - 8lei/buc 17.m) NodeMCU v2 ESP8266 cu ESP-12E - 75lei/buc 17.n) NodeMCU v0.9 ESP8266 cu ESP-12 - 65lei/buc 25.d) Modul MP3 player - 30lei/buc Power range: 3.7~5.5V Product size: 45mm*36mm Onboard 2Wmonoamplifier(5V power of up to 3W) - 4Ω3W MicroUSB port.Through the mobile phone data line can use mobile power supply or the USB cable to charge the MP3 battery,also can use 3.7V lithiumbattery,orUSB 5V power supply Support U disk (test 32G), TF Card (test 16G) play mode; power on default TF card mode Buttons can be adjusted up and down to control songs,volume up and down, pause or play, mode switching Adaptor cu soclu ZIF40 pentru programatoare PICkit2 sau 3 - 30lei/buc Cutie pentru montaje, 190 x 120 x 60 mm - 8lei/buc - dimensiuni panou frontal: 120 x 60 Cutie pentru montaje, 225x150x43 mm - 10lei/buc Programator PICkit 2 clona - 100lei/buc Programator PICkit 3 clona - 140lei/buc Carcasa transparenta pentru Arduino MEGA 2560 R3 - 30lei/buc PIC16F877A capsula PLCC 44 pin - 9buc/100lei Arduino NANO v3.0 - 20lei/buc (fara cablu USB) Microcontroller Atmel ATmega328 Operating Voltage (logic level): 5VInput Voltage (recommended): 7V ~ 12VInput Voltage (limits): 6V ~ 20 VDigital I/O Pins: 14 (of which 6 provide PWM output)Analog Input Pins: 8DC Current per I/O Pin: 40mAFlash Memory: 32KB (ATmega328) (of which 2 KB used by bootloader)SRAM: 2KB (ATmega328)EEPROM: 1KB (ATmega328)Clock Speed: 16MHz12 Digital input / output ports:D2 ~ D138 analog inputs ports:A0 ~ A71 pairs of TTL level serial transceiver ports RX / TX6 PWM ports:D3, D5, D6, D9, D10, D11Atmel Atmega328P-AU MCUCH340 USB driverSupport USB download and PowerSupport for external 5V ~ 12V DC power supplySupport power supply by 9V batterySupport ISP download Link spre comentariu
soringt Postat Iulie 5, 2015 Autor Partajează Postat Iulie 5, 2015 Anunt valabil. Link spre comentariu
rosmarin Postat Iulie 6, 2015 Partajează Postat Iulie 6, 2015 Conform promisiunii azi dimineata la 9.45 am alimentat. Multumesc frumos Link spre comentariu
soringt Postat Iulie 6, 2015 Autor Partajează Postat Iulie 6, 2015 Anunt valabil. Oferta zilei! 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 7.50 lei/buc Link spre comentariu
soringt Postat Iulie 7, 2015 Autor Partajează Postat Iulie 7, 2015 Anunt valabil. Se adauga: Tester USB voltmetru / ampermetru - 35lei/buc Alim:3-9V Curent masurat: 0-3A(max) Se poate utiliza la monitorizarea incarcarii telefoanelor/ tabletelor, etc. Link spre comentariu
Vizitator edmond Postat Iulie 8, 2015 Partajează Postat Iulie 8, 2015 am trimis adresa pentru expediere multumesc, eddie Link spre comentariu
soringt Postat Iulie 8, 2015 Autor Partajează Postat Iulie 8, 2015 Anunt valabil. Link spre comentariu
soringt Postat Iulie 9, 2015 Autor Partajează Postat Iulie 9, 2015 Anunt valabil. Oferta zilei! 25. a) Amplificator audio TDA7297 2x15W - 25lei/buc Ualim: 6-18V (recomandat 12V) Putere: 2x15W Dim: 52 x 47 x 52 Link spre comentariu
Vizitator edmond Postat Iulie 10, 2015 Partajează Postat Iulie 10, 2015 am cumparat Programator PICkit 3 clona - 140lei/buc Breadboard 830 puncte - 20lei/buc Set de 65 fire - 15lei/set servire instant recomand Link spre comentariu
soringt Postat Iulie 10, 2015 Autor Partajează Postat Iulie 10, 2015 Anunt valabil. Oferta zilei! 25. b) Voltmetru + termometru auto 12V - 45lei/buc Alimentare de la bricheta Link spre comentariu
Vizitator Danco Postat Iulie 13, 2015 Partajează Postat Iulie 13, 2015 Salut Sorin, Am primit pachetul...totul este OK Tinem legatura. Multumesc. Dan Link spre comentariu
mihaighe Postat Iulie 13, 2015 Partajează Postat Iulie 13, 2015 Cutie pentru montaje, 190 x 120 x 60 mm - 8lei/buc - dimensiuni panou frontal: 120 x 60 Cutie pentru montaje, 225x150x43 mm - 10lei/buc Cate 2 bucati din fiecare se gaseste? mersi Mihai. Link spre comentariu
quinn Postat Iulie 13, 2015 Partajează Postat Iulie 13, 2015 senzorul de Metan(MQ-5) ce valabilitate are? Link spre comentariu
soringt Postat Iulie 13, 2015 Autor Partajează Postat Iulie 13, 2015 @quinn: Nu am aceasta informatie. Anunt valabil in continuare. Oferta zilei! 4. d) Sursa DC-DC step-down 5A - 15lei/buc Comanda minima 70lei + transport. Link spre comentariu
