soringt Postat Martie 15, 2015 Autor Partajează Postat Martie 15, 2015 un nr tel te rog pr. Aveti MP. Link spre comentariu
soringt Postat Martie 16, 2015 Autor Partajează Postat Martie 16, 2015 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 0-100V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-BLUE 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/buc Uin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 20lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc 7.e) Mini breadboard 400 puncte - 15lei/buc - stoc 0 7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 70lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 80lei/buc Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) RED - 85lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. Termometru digital de panou Pret: 12lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mm Culoare ALB - stoc 012. a). ARDUINO UNO R3 + cablu USB - 65ei/buc 12. b). Shield LAN W5100 - 55lei/buc 12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 50lei/buc 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 12.f). Shield relee 2 sau 4 canale - 20 / 35 lei /buc 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RH Senzor de temperatura+ umiditate DHT11 (albastru) - 7lei/buc 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 18lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 90lei/buc 17.c) Modul RTC DS1307+ EEPROM 24C32 + baterie - 12lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 12lei/buc 17.f) Modul incarcare 1A celula Li-Ion 4.2V - 7lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc 17.h) Modul WI-FI ESP8266 ESP-12 - 30lei/buc 18. 19. Aparat de masurat distanta cu ultrasunete - 75lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. VK-172 GMOUSE USB GPS/GLONASS USB - 85lei/buc Support DGPS [WAAS, EGNOS and MSAS] Reference coordinate system: WGS-84 Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Supported operating systems: Windows 8/7/Vista/XP/CE VK-172 automatically adapt the baud rate, the baud rate has any data output Support Google Earth Based on G7020-KT u-blox 7 GPS/GNSS C / A code, 1.023MHz stream Receive Band: L1 [1575.42MHz] Tracking Channels: 56 Support DGPS [WAAS, EGNOS and MSAS] Positioning performance : 2D plane: 5m [average] 2D plane: 3.5m [average], has DGPS auxiliary. Drift: <0.02m / s Reference coordinate system: WGS-84 Maximum altitude: 18,000 m Maximum speed: 500m / s Acceleration: <4g Tracking sensitivity:-162dBm Acquisition sensitivity:-160dBm Cold Start Time: 29s [average] Warm start time: 28s [average] Hot start time: 1s [average] Recapture Time: 0.1s [average] 22. Mini freza pentru PCB - 25lei/buc Alimentare 12V+spiral de 0.8mm 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc Comanda minima 70leiTransport+Ramburs: 11lei Link spre comentariu
soringt Postat Martie 17, 2015 Autor Partajează Postat Martie 17, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 18, 2015 Autor Partajează Postat Martie 18, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 19, 2015 Autor Partajează Postat Martie 19, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 20, 2015 Autor Partajează Postat Martie 20, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 21, 2015 Autor Partajează Postat Martie 21, 2015 Anunt valabil. 17. Diverse module 17.a) Modul MAX7219 8 digiti rosu - 18lei/buc 17.b) Modul GPS Ublox NEO-6M antena ceramica Rx-Tx 9600 - 90lei/buc 17.c) Modul RTC DS3231+ EEPROM 24C32 (fara baterie) - 11lei/buc 17.d) Modul accelerometru GY-61 ADXL335 Module 3-axis - 15lei/buc 17.e) Senzor Barometric / presiune BMP180 - 12lei/buc 17.f) Modul incarcare 1A TP4056 celula Li-Ion 4.2V - 7lei/buc 17.g) Sursa Step-UP USB 5V max.600mA - 7lei/buc 17.h) Modul WI-FI ESP8266 ESP-12 - 30lei/buc 17.i) Modul TEA5767 Radio FM - 7lei/buc 17.j) Modul(set) RF 433MHz - 10lei/set 17.k) Modul amplificator audio 2x3W PAM8403 - 6lei/buc 17.l) Modul senzor Metan(MQ-5) sau Alcool(MQ-3) - 20lei/buc 18. Module Diverse: 18.a) Set RFID MFRC-522 (modul+card+breloc+pini) -30lei/set 18.b) Modul senzor touch 1 canal - 9lei/buc 18.c) Modul senzor touch 4 canale - 13lei/buc 18.d) Modul senzor touch 8 canale - 17lei/buc 24. Aparat de masurat umiditatea din lemn - 80lei Alimentare - 9V Domeniu de masura: 5% - 40% Link spre comentariu
soringt Postat Martie 22, 2015 Autor Partajează Postat Martie 22, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 23, 2015 Autor Partajează Postat Martie 23, 2015 Anunt valabil. Se adauga: 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 38lei/buc 18.e) Modul xs3868 bluetooth 2.0 audio stereo cu OVC3860 - 35lei/buc 18.f) Modul audio stereo KRC-86B v4.0 bluetooth 2.1 + EDR - 80lei/buc Link spre comentariu
soringt Postat Martie 24, 2015 Autor Partajează Postat Martie 24, 2015 Anunt valabil. Link spre comentariu
Vizitator KaN Postat Martie 24, 2015 Partajează Postat Martie 24, 2015 Anunt valabil. Salut, Legat de 4.e) Sursa DC-DC step-down 5A + Voltmetru LED - 38lei/buc. Ai documentatie la ea? Ma intereseasa daca este protejata la supra-sarcina. Link spre comentariu
soringt Postat Martie 24, 2015 Autor Partajează Postat Martie 24, 2015 @KaN: Aveti MP Link spre comentariu
soringt Postat Martie 25, 2015 Autor Partajează Postat Martie 25, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 26, 2015 Autor Partajează Postat Martie 26, 2015 Anunt valabil. Link spre comentariu
soringt Postat Martie 27, 2015 Autor Partajează Postat Martie 27, 2015 Anunt valabil. Link spre comentariu
