soringt Postat Ianuarie 11, 2015 Autor Partajează Postat Ianuarie 11, 2015 (editat) 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 12lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 75lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/bucUin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 25lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc7.e) Mini breadboard 400 puncte - 15lei/buc7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 65lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buclink1. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mmhttp://i39.tinypic.com/5d1cfr.jpg12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc 12. b). Shield LAN W5100 - 55lei/buc link12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc12. d) Shield LCD keypad - 45lei/buchttp://i62.tinypic.com/2hrft6x.jpg 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RHhttp://i62.tinypic.com/zxjz8l.jpg 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Player MP3 + radio + remote - 60lei/buclink1 link21.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack18. Sursa Step-UP USB 5V max.600mA - 7lei/buclinkSize:34 (mm) x16.2 (mm) ultra-small sizeUin: 1-5V; Output 5V stabilizat max.600mASe pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon 19. Aparat de masurat distanta cu ultrasunete - 75lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc DS1307 I2C real time clock chip (RTC)24C32 32K I2C EEPROM memory Baterie inclusa link 22. Mini freza pentru PCB - 25lei/buc Alimentare 12V+spiral de 0.8mm 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc Comanda minima 70leiTransport+Ramburs: 11lei Editat Ianuarie 11, 2015 de soringt 1 Link spre comentariu
soringt Postat Ianuarie 12, 2015 Autor Partajează Postat Ianuarie 12, 2015 Anunt valabil. Link spre comentariu
soringt Postat Ianuarie 13, 2015 Autor Partajează Postat Ianuarie 13, 2015 Anunt valabil Link spre comentariu
Vizitator dinnobolique Postat Ianuarie 14, 2015 Partajează Postat Ianuarie 14, 2015 Salut ma intereseaza si pe mine: 4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF Cea care are pCB-ul albastru, si ma interezeaza cum se variaza tensiunea de iesire, manual sau din telecomanda? Transformatoare aveti in oferta (pentru alimentare de la retea si comptatibil cu sursa 4b)? Astept raspuns urgent Link spre comentariu
soringt Postat Ianuarie 14, 2015 Autor Partajează Postat Ianuarie 14, 2015 @dinnobolique: Aveti MP. Anunt valabil in continuare. Link spre comentariu
florinellll Postat Ianuarie 14, 2015 Partajează Postat Ianuarie 14, 2015 -----4. d) Sursa DC-DC step-down 5A - 20lei/buc Uin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz ------ Cu sursa asta se poate alimenta un led de 100w? Link spre comentariu
soringt Postat Ianuarie 14, 2015 Autor Partajează Postat Ianuarie 14, 2015 Este recomandat sa se alimenteze LED-urile cu un curent constant. Aceasta este o sursa de tensiune stabilizata, nu de curent constant.Cu bine. Link spre comentariu
soringt Postat Ianuarie 15, 2015 Autor Partajează Postat Ianuarie 15, 2015 Anunt valabil. Link spre comentariu
soringt Postat Ianuarie 16, 2015 Autor Partajează Postat Ianuarie 16, 2015 Anunt valabil. Link spre comentariu
Eugen Chirila Postat Ianuarie 17, 2015 Partajează Postat Ianuarie 17, 2015 (editat) Ieri seara am facut o comanda, azi am ridicat personal componentele. Sunt foarte multumit, si mai ales am primit si un bonus, care valoreaza cam 14% din valoarea totala a comenzii. Multumesc Sorin. Urmeaza sa ridic o a doua comanda pe care am facut-o azi. Editat Ianuarie 17, 2015 de Eugen Chirila Link spre comentariu
soringt Postat Ianuarie 18, 2015 Autor Partajează Postat Ianuarie 18, 2015 Anunt valabil. Link spre comentariu
soringt Postat Ianuarie 19, 2015 Autor Partajează Postat Ianuarie 19, 2015 Anunt valabil. Se adauga: 12. d) LCD 2.4" color touch screen TFT pentru Arduino UNO R3 - 55lei/buc 2.4" diagonal LCD TFT display 240x320 resolution, 18-bit (262,000) color spfd5408 controller with built in video RAM buffer 8 bit digital interface, plus 4 control lines 4 white LED backlight; 4-wire resistive touchscreen Functioneaza doar cu UNO/Duemilanove/Diecimila, nu este compatibil cu MEGA, Leonardo, etc. Link spre comentariu
soringt Postat Ianuarie 20, 2015 Autor Partajează Postat Ianuarie 20, 2015 Anunt valabil Link spre comentariu
soringt Postat Ianuarie 21, 2015 Autor Partajează Postat Ianuarie 21, 2015 Anunt valabil. Link spre comentariu
