GanMark Postat Decembrie 17, 2014 Partajează Postat Decembrie 17, 2014 azi am ridicat coletul totul OK, ambalat frumos..... multumesc ! Link spre comentariu
Eugen Chirila Postat Decembrie 20, 2014 Partajează Postat Decembrie 20, 2014 (editat) Salut soringt. Mai ai de vanzare voltampermetru digital? 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 50lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc Display color: (Red & Blue) or (Red & Red) LED (dual display). Display: 0.28" LED digital. Operating voltage: DC 4.5 ~ 30V. Measure voltage: DC 0 ~ 100V. Operating Current: <20mA. Measure current: 10A (direct measurement, built-in shunt). Mounting cutout: 45.5mm x 26.5mm. Size: 48mm x 29mm x 21mm http://i42.tinypic.com/4goop3.jpg sau http://i41.tinypic.com/2115im9.jpg Editat Decembrie 20, 2014 de Eugen Chirila Link spre comentariu
soringt Postat Decembrie 20, 2014 Autor Partajează Postat Decembrie 20, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE/ GREEN2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buc4. d) Sursa DC-DC step-down 5A - 20lei/bucUin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 25lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc7.e) Mini breadboard 400 puncte - 15lei/buc7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 65lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buclink1. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mmhttp://i39.tinypic.com/5d1cfr.jpg12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc 12. b). Shield LAN W5100 - 55lei/buc link12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc12. d) Shield LCD keypad - 45lei/buchttp://i62.tinypic.com/2hrft6x.jpg 12.e) Shield Arduino Multifunctional - 60lei 4 digit 7-segment LED display module driven by two serial 74HC595’s 4 LED’s 10K potentiometer 3 x push buttons Piezo buzzer DS18B20 or LM35 temperature sensor interface (not included) Infrared receiver interface Serial interface header for connection to serial modules 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RHhttp://i62.tinypic.com/zxjz8l.jpg 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Player MP3 + radio + remote - 60lei/buclink1 link21.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack18. Sursa Step-UP USB 5V max.600mA - 7lei/buclinkSize:34 (mm) x16.2 (mm) ultra-small sizeUin: 1-5V; Output 5V stabilizat max.600mASe pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon 19. Aparat de masurat distanta cu ultrasunete - 75lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc DS1307 I2C real time clock chip (RTC)24C32 32K I2C EEPROM memory Baterie inclusa link 22. Mini freza pentru PCB - 25lei/buc Alimentare 12V+spiral de 0.8mm 23. Socluri ZIF40 a) Soclu ZIF40 wide nickel plated - 4lei/buc b) Soclu ZIF40 universal gold plated black - 12lei/buc c) Soclu ZIF40 universal gold plated blue - 10lei/buc Comanda minima 70leiTransport+Ramburs: 11lei Link spre comentariu
soringt Postat Decembrie 21, 2014 Autor Partajează Postat Decembrie 21, 2014 Anunt valabil. Link spre comentariu
soringt Postat Decembrie 22, 2014 Autor Partajează Postat Decembrie 22, 2014 Anunt valabil. Link spre comentariu
Vizitator paulcotrus Postat Ianuarie 3, 2015 Partajează Postat Ianuarie 3, 2015 buna vreau si eu sa comand : -set 65 fire 1buc -sursa 4.a 4 buc -sursa 4.d 2buc -sursa 4.b 2 - displ 20x4 1 -1v-a red-blue 1buc ............ cum procedam? pot primi factura? paul c.,brasov Link spre comentariu
soringt Postat Ianuarie 4, 2015 Autor Partajează Postat Ianuarie 4, 2015 @paulcotrus: Ai MP Multumesc. Link spre comentariu
soringt Postat Ianuarie 5, 2015 Autor Partajează Postat Ianuarie 5, 2015 Anunt valabil. Link spre comentariu
Vizitator gabiipit Postat Ianuarie 5, 2015 Partajează Postat Ianuarie 5, 2015 Buna seara, Sunt nou pe acest forum si nu am mai postat niciodata, dar incerc si sper sa-mi iasa. Il rog pe dl. Soringt sa-mi spuna daca mai poate aduce Set spirale 0.3mm - 1.2mm . Va multumesc! Link spre comentariu
soringt Postat Ianuarie 6, 2015 Autor Partajează Postat Ianuarie 6, 2015 Buna seara, Sunt nou pe acest forum si nu am mai postat niciodata, dar incerc si sper sa-mi iasa. Il rog pe dl. Soringt sa-mi spuna daca mai poate aduce Set spirale 0.3mm - 1.2mm . Va multumesc! Salut. Mai am un set disponibil. Astept un MP cu datele de contact. Multumesc. Link spre comentariu
Vizitator gabiipit Postat Ianuarie 6, 2015 Partajează Postat Ianuarie 6, 2015 Salut. Mai am un set disponibil. Astept un MP cu datele de contact. Multumesc. Buna seara, Va multumesc pentru raspuns. Am trimis un mesaj pe MP, dar nu stiu daca am procedat bine. Va rog sa-mi spuneti daca l-ati primit. Link spre comentariu
soringt Postat Ianuarie 7, 2015 Autor Partajează Postat Ianuarie 7, 2015 Anunt valabil. Link spre comentariu
soringt Postat Ianuarie 8, 2015 Autor Partajează Postat Ianuarie 8, 2015 Anunt valabil. Link spre comentariu
dorelb Postat Ianuarie 8, 2015 Partajează Postat Ianuarie 8, 2015 Am primit pachetul . Așa cum m-a așteptam . Marfa ireproșabila . Link spre comentariu
soringt Postat Ianuarie 10, 2015 Autor Partajează Postat Ianuarie 10, 2015 Anunt valabil. Link spre comentariu
