soringt Postat Octombrie 21, 2014 Autor Partajează Postat Octombrie 21, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc Precizie:±1.5% Dim: 55x40x25mm Se introduce direct in priza 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 25lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buclink4. d) Sursa DC-DC step-down 5A - 20lei/bucUin: 4V-38V Uout: 1.25V-36VOutput current: 0-5A Transfer efficiency:96%(max) Switching Frequency:180KHz 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 25lei/buc7.b)Set de 65 fire - 15lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female 1p-1p Female - Female7. d) Mini-breadboard 170 puncte - 8lei/buc7.e) Mini breadboard 400 puncte - 15lei/buc7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma 8. Termometru IR (infrarosu) (-50 - 330°C - alim 2x1,5V AAA) - 65lei/buc (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us...2/3916/uho4.jpg 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buclink1. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mmhttp://i39.tinypic.com/5d1cfr.jpg12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc 12. b). Shield LAN W5100 - 55lei/buc link12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc12. d) Shield LCD keypad - 45lei/buchttp://i62.tinypic.com/2hrft6x.jpg 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RHhttp://i62.tinypic.com/zxjz8l.jpg 16. Senzor temperatura DS18B20 waterproof - 15lei/buc lungime cablu: 1m 17. Player MP3 + radio + remote - 60lei/buclink1 link21.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack18. Sursa Step-UP USB 5V max.600mA - 7lei/buclinkSize:34 (mm) x16.2 (mm) ultra-small sizeUin: 1-5V; Output 5V stabilizat max.600mASe pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon 19. Aparat de masurat distanta cu ultrasunete - 75lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc DS1307 I2C real time clock chip (RTC)24C32 32K I2C EEPROM memory Baterie inclusa link 22. Mini freza pentru PCB - 25lei/buc Alimentare 12V+spiral de 0.8mm Comanda minima 70leiTransport+Ramburs: 11lei 1 Link spre comentariu
soringt Postat Octombrie 23, 2014 Autor Partajează Postat Octombrie 23, 2014 Anunt valabil. Disponibila o noua versiune de sursa Step-UP cu LM2577 - 4.c) Link spre comentariu
soringt Postat Octombrie 24, 2014 Autor Partajează Postat Octombrie 24, 2014 (editat) Anunt valabil Soclu ZIF40 - 4lei/buc . Editat Octombrie 24, 2014 de soringt Link spre comentariu
soringt Postat Octombrie 25, 2014 Autor Partajează Postat Octombrie 25, 2014 Anunt valabil. Link spre comentariu
soringt Postat Octombrie 26, 2014 Autor Partajează Postat Octombrie 26, 2014 Anunt valabil. Oferta! 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 30lei/buc10 buc disponibile. Comanda minima 70lei + transport. Link spre comentariu
soringt Postat Octombrie 27, 2014 Autor Partajează Postat Octombrie 27, 2014 Anunt valabil. Link spre comentariu
soringt Postat Octombrie 29, 2014 Autor Partajează Postat Octombrie 29, 2014 Anunt valabil. Link spre comentariu
soringt Postat Octombrie 30, 2014 Autor Partajează Postat Octombrie 30, 2014 Anunt valabil Link spre comentariu
Vizitator Adi Irish Postat Octombrie 31, 2014 Partajează Postat Octombrie 31, 2014 salut ma intereseaza produsul 4.c) Sursa STEP-UP cu LM2577 - 15lei/buc da-mi un reply te rog daca esti din bucuresti ca sa ne putem intalni undeva daca ai si versiunea cu voltmetru te rog sa imi dai un pret si pentru ea multumesc Link spre comentariu
soringt Postat Octombrie 31, 2014 Autor Partajează Postat Octombrie 31, 2014 (editat) Anunt valabil. 8. Termometru IR (infrarosu) (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc - momentan stoc 0 Editat Octombrie 31, 2014 de soringt Link spre comentariu
rosmarin Postat Octombrie 31, 2014 Partajează Postat Octombrie 31, 2014 Buna seara Dl. Sorin doresc sa fac o comanda de 10 buc socluri zif cu 40 pini. Daca este valabila oferta?Astept un mesaj Link spre comentariu
soringt Postat Noiembrie 1, 2014 Autor Partajează Postat Noiembrie 1, 2014 @rosmarin: Nu va pot trimite nici un mesaj. Va rog sa verificati daca nu aveti mesageria deja plina. Link spre comentariu
soringt Postat Noiembrie 2, 2014 Autor Partajează Postat Noiembrie 2, 2014 Anunt valabil. Link spre comentariu
Vizitator lucian mocanu Postat Noiembrie 3, 2014 Partajează Postat Noiembrie 3, 2014 buna seara mai aveti spirale pana in 1mm Link spre comentariu
