LCD-uri, surse DC, Voltmetre,Volt-Ampermetre,Termometre
soringt
Anunt valabil.
8. Termometru IR (infrarosu) - 60lei/buc [/
(-50 - 330°C - alim 2x1,5V AAA)
Termometru IR pana la 500 mai aveti?
12. c) Arduino MEGA 2560 R3 + cablu USB - 80lei/buc
Termometru IR pana la 500 grade mai aveti?
Editat de nicnec
  • Răspunsuri 1,2k
  • soringt
    889
  • vcdec
    10
  • albasete
    10
  • rosmarin
    7
1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei
Posted Image
LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc
Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.
Posted ImagePosted Image
2.a) Voltmetru de panou - Pret: 20lei/buc
Operating voltage: 3.2 ~ 30V
Operating Current: <60mA
Display: 0.56 "LED, color RED / BLUE GREEN / ORANGE / WHITE !
Mounting holes: 45.5 x 26.5 mm
Measurement rate: ≥ 500mS
Measurement accuracy: 1%
Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V
Posted Image
2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc
Dimension: 23mmx15mmx10mm
Sample period:500ms ; Resolution:1%+1digit
Reverse Voltage Protection
2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc
Afisaj 0.36"
Posted Image
2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/buc
Dimensiuni:40mm x 25mm x 23mm(L*W*H)
Working Current:<20mA
Display: Three digit 0.4" LED RED / BLUE
Posted Image
2. e) Voltmetru digital LCD 80V-300V AC - 35lei/buc
Precizie:±1.5%
Dim: 55x40x25mm
Se introduce direct in priza
Posted Image
3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc
3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc
Display color: (Red & Blue) or (Red & Red) LED (dual display).
Display: 0.28" LED digital.
Operating voltage: DC 4.5 ~ 30V.
Measure voltage: DC 0 ~ 100V.
Operating Current: <20mA.
Measure current: 10A (direct measurement, built-in shunt).
Mounting cutout: 45.5mm x 26.5mm.
Size: 48mm x 29mm x 21mm
Posted Image
3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc
Posted Image
3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc
Posted Image
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc
Uin: 3.2V-40V
Uout: 1.25V-35V
Output current: 2A (max.3A)
Transfer efficiency:92%(max)
Switching Frequency:65KHz
Dimensiuni: 43x21mm
4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 30lei/buc
Uin: 4-40 v
Uout:1.25V - 37V
Imax: 3A cu radiator
Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF
4.c) Sursa STEP-UP cu LM2577 - 15lei/buc
link
4. d) Sursa DC-DC step-down  5A - 20lei/buc
Uin: 4V-38V
Uout: 1.25V-36V
Output current: 0-5A
Transfer efficiency:96%(max)
Switching Frequency:180KHz
Posted Image
5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc
6.Senzor PIR - 10lei/buc
Working voltage range: DC 4.5-20V
Static current: <50uA
High level output: 3.3 V / low 0V
Delay time: 0.5-200S (adjustable)
Blocking time: 2.5S (the default)
Sensing range (3-7m)
Size: 32mm*24mm circuit board
Induction angle: <100 degree cone angle
Working temperature: -15-+70 degre
Cu un tranzistor si un releu se poate face o automatizare instant!
7.a) Breadboard 830 puncte - 26lei/buc
7.b)Set de 65 fire - 14lei/set
Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)
7.c)Set de 40 fire - 15lei/set
Lungime 20cm
1p-1p Male - Female
7. d) Mini-breadboard 170 puncte - 8lei/buc
7.e) Mini breadboard 400 puncte - 13lei/buc
7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/buc
Apply to MB102 breadboard
Input voltage: 6.5-12 V (DC) or USB power supply
Output voltage: 3.3V/5V can switch over
Maximum output current: <700 ma
Posted Image
8. Termometru IR (infrarosu) - 70lei/buc
(-50 - 330°C - alim 2x1,5V AAA)  sau (-50 - 380°C- alim 9V - stoc 0)
(-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc
Posted Image
9.  Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc
Superior material made, strong structure
Tip Diameter: 0.8mm
Grip Diameter: 3.175mm
Total Length: 37.5mm
Material: cemented carbide(tungsten steel, tip), high-speed steel(grip)
45lei/set de 10buc
http://imageshack.us...2/3916/uho4.jpg
10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc
link
1. Termometru digital de panou Pret: 15lei/buc
Interval de masura: -50°C -> 110°C
Rezolutie afisare: 0.1
Precizie masurare: ±1°C
Alim: 2 buc LR44 (incluse)
Lung cablu semzor: 1m
Dimensiuni: 47*28*14mm
http://i39.tinypic.com/5d1cfr.jpg
12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc
http://imageshack.us...0/7024/pspa.jpg
12. b). Shield LAN W5100 - 55lei/buc
link
12. c) Arduino MEGA 2560 R3 + cablu USB - 85lei/buc
Posted Image
12. d) Shield LCD keypad - 45lei/buc
http://i62.tinypic.com/2hrft6x.jpg
12. e) ARDUINO DUE R3 SAM3X8E - 100lei/buc
Posted Image
13. Set Remote control 4 canale - 25lei/set
Posted Image
14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc
-utilizari diverse ( UV box pentru expunere,, etc)
Posted Image
15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/buc
Size: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)
Working voltage: 3 V - 5.5 V
Temperature measurement range: - 40°c to 80°c
Measuring accuracy: 0.5°c
The humidity measuring range: 0-100% RH
Measuring accuracy: 2% RH
http://i62.tinypic.com/zxjz8l.jpg
16. Senzor temperatura DS18B20 waterproof - 15lei/buc
lungime cablu: 1m
Posted Image
17. Player MP3 + radio + remote - 60lei/buc
link1
link2
1.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack
18. Sursa Step-UP USB 5V max.600mA - 7lei/buc
link
Size:34 (mm) x16.2 (mm) ultra-small size
Uin: 1-5V; Output 5V stabilizat max.600mA
Se pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon
19. Aparat de masurat distanta cu ultrasunete - 75lei/buc
Power supply: 1 x 9V
Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)
Auto stop: switches off if you do not press any key for 4 min
Laser beam: Wattage 1mW
Working temperature: 0oC ~ 43oC
Range: 0.91m to 18m
Dimensions (H-P-l): 142 x 73 x 47mm
Posted Image
20. Display NOKIA5110 - 20lei/buc
Posted Image
21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc
DS1307 I2C real time clock chip (RTC)
24C32 32K I2C EEPROM memory
Baterie inclusa
link
22. Mini freza pentru PCB - 25lei/buc
Alimentare 12V
+spiral de 0.8mm
Comanda minima 70lei
Transport+Ramburs: 11lei
Salut!
M-ar interesa urmatoarele:
4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc - 3 BUCATI
Uin: 3.2V-40V
Uout: 1.25V-35V
Dimensiuni: 43x21mm
2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/buc - 1 BUCATA PE ALBASTRU.
Astept raspuns!
Stima!
Editat de khrystyan
