molioa Postat Iunie 22, 2014 Partajează Postat Iunie 22, 2014 @ludovik: ai MP Anunt valabil in continuare Se adauga : 19. Termometru+ hygrometru cu PIC, LCD si DHT22 - 80lei Range masura: 0-100% humidity 2% accuracy -40 to 80°C temperature ±0.5°C accuracy Ualim: 9-12Vti? mai aveti? Link spre comentariu
soringt Postat Iunie 22, 2014 Autor Partajează Postat Iunie 22, 2014 @molioa: Aveti MP Link spre comentariu
soringt Postat Iunie 26, 2014 Autor Partajează Postat Iunie 26, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buclink5. 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 26lei/buc7.b)Set de 65 fire - 14lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female7. d) Mini-breadboard 170 puncte - 8lei/buc7.e) Mini breadboard 400 puncte - 13lei/buc7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma8. Termometru IR (infrarosu) - 70lei/buc(-50 - 330°C - alim 2x1,5V AAA) sau (-50 - 380°C- alim 9V ; disponibil 2 buc.) (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc 9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us/a/img32/3916/uho4.jpg9. b). Set spirale 0.3mm - 1.2mm - 45lei/setNumai set intreg.carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm, link10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buclink11. Termometru digital de panou Pret: 15lei/bucInterval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mmhttp://i39.tinypic.com/5d1cfr.jpg12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc http://imageshack.us/a/img30/7024/pspa.jpg12. b). Shield LAN W5100 - 55lei/buc link12. c) Arduino MEGA 2560 R3 + cablu USB - 100lei/buc12. d) Shield LCD keypad - 45lei/buchttp://i62.tinypic.com/2hrft6x.jpg 13. Afisaje LEDhttp://imageshack.us/a/img62/4617/2f8f.jpg4 Digits :CEAS - 5lei/bucPin Number: 12 pins.Digit Number: 4 digits.Common anode.Digit Height: 0.56 inch.Color: Red.3 DIGITI + comun - 2lei/bucDisplay: 0.36" LED digital tubeRange: 1.9 -2.2VDisplay Color: RedSize: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W)10-Segmente GREEN - 2lei/bucSize: Approx. 2.4*1*1.4cm (L*W*H)14. 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RHhttp://i62.tinypic.com/zxjz8l.jpg16. Ampermetru de panou BLUE 0-10A - 20lei/buchttp://i44.tinypic.com/29kw0nt.jpg17. Player MP3 + radio + remote - 60lei/buclink1 link21.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack18. Sursa Step-UP USB 5V max.600mA - 7lei/buclinkSize:34 (mm) x16.2 (mm) ultra-small sizeUin: 1-5V; Output 5V stabilizat max.600mASe pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon 19. Aparat de masurat distanta cu ultrasunete - 80lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc DS1307 I2C real time clock chip (RTC)24C32 32K I2C EEPROM memory Baterie inclusa 22. Set mufe M+F 5 pini - 8lei Diam. 12mm Comanda minima 70leiTransport+Ramburs: 11lei Link spre comentariu
soringt Postat Iunie 27, 2014 Autor Partajează Postat Iunie 27, 2014 Anunt valabil. Link spre comentariu
vcdec Postat Iunie 28, 2014 Partajează Postat Iunie 28, 2014 vreau si eu 4 contollere rgb pe radiocomanda! detalii pe pm Link spre comentariu
soringt Postat Iunie 29, 2014 Autor Partajează Postat Iunie 29, 2014 @vcdec: rezervate Anunt valabil in continuare. Link spre comentariu
soringt Postat Iunie 30, 2014 Autor Partajează Postat Iunie 30, 2014 Anunt valabil Link spre comentariu
soringt Postat Iulie 1, 2014 Autor Partajează Postat Iulie 1, 2014 Anunt valabil Link spre comentariu
soringt Postat Iulie 2, 2014 Autor Partajează Postat Iulie 2, 2014 Anunt valabil. Se adauga: 5. Sursa CC LED Driver DC-DC 5-35V to 1.25-30V - 20lei/buc 13. Set Remote control 4 canale - 25lei/set 14. Timer digital countdown 0 - 999 sec 12V - 40lei/buc -utilizari diverse ( UV box pentru expunere,, etc) Link spre comentariu
soringt Postat Iulie 3, 2014 Autor Partajează Postat Iulie 3, 2014 Anunt valabil Link spre comentariu
soringt Postat Iulie 4, 2014 Autor Partajează Postat Iulie 4, 2014 Anunt valabil Link spre comentariu
soringt Postat Iulie 6, 2014 Autor Partajează Postat Iulie 6, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iulie 7, 2014 Autor Partajează Postat Iulie 7, 2014 (editat) Anunt valabil. Se aduga: 12. e) ARDUINO DUE R3 SAM3X8E - 100lei/buc Editat Iulie 7, 2014 de soringt Link spre comentariu
soringt Postat Iulie 8, 2014 Autor Partajează Postat Iulie 8, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iulie 9, 2014 Autor Partajează Postat Iulie 9, 2014 Anunt valabil Link spre comentariu
