soringt Postat Iunie 6, 2014 Autor Partajează Postat Iunie 6, 2014 "3 DIGITI + comun - 2lei/bucDisplay: 0.36" LED digital tubeRange: 1.9 -2.2VDisplay Color: RedSize: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W)" Cati pini au ? Multumesc ! 11 pini Link spre comentariu
soringt Postat Iunie 7, 2014 Autor Partajează Postat Iunie 7, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40leiLCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/bucAceasta este culoarea caracterelor, fundalul este negru. Se vad excelent.2.a) Voltmetru de panou - Pret: 20lei/bucOperating voltage: 3.2 ~ 30VOperating Current: <60mADisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !Mounting holes: 45.5 x 26.5 mmMeasurement rate: ≥ 500mSMeasurement accuracy: 1%Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100VDisplay: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE !2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/bucDimension: 23mmx15mmx10mmSample period:500ms ; Resolution:1%+1digitReverse Voltage Protection2. c) Mini-Voltmetru RED ,GREEN sau BLUE 0-100V - 15lei/bucAfisaj 0.36"2.d) Voltmetru panou WATERPROOF 3-30V - 35lei/bucDimensiuni:40mm x 25mm x 23mm(L*W*H)Working Current:<20mADisplay: Three digit 0.4" LED RED / BLUE3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 40lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/bucDisplay color: (Red & Blue) or (Red & Red) LED (dual display).Display: 0.28" LED digital.Operating voltage: DC 4.5 ~ 30V.Measure voltage: DC 0 ~ 100V.Operating Current: <20mA.Measure current: 10A (direct measurement, built-in shunt).Mounting cutout: 45.5mm x 26.5mm.Size: 48mm x 29mm x 21mm3.c) Volt-Ampermetru RED-BLUE 4.5-30V 0-50A + shunt - 65lei/buc3.d) Volt-Ampermetru RED-RED 0-100V 0-100A + shunt - 80lei/buc 4.a) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40VUout: 1.25V-35VOutput current: 2A (max.3A)Transfer efficiency:92%(max)Switching Frequency:65KHzDimensiuni: 43x21mm4.b) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc Uin: 4-40 vUout:1.25V - 37VImax: 3A cu radiatorCuloare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF4.c) Sursa STEP-UP cu LM2577 - 15lei/buclink5. 6.Senzor PIR - 10lei/buc Working voltage range: DC 4.5-20VStatic current: <50uAHigh level output: 3.3 V / low 0VDelay time: 0.5-200S (adjustable)Blocking time: 2.5S (the default)Sensing range (3-7m)Size: 32mm*24mm circuit boardInduction angle: <100 degree cone angleWorking temperature: -15-+70 degreCu un tranzistor si un releu se poate face o automatizare instant!7.a) Breadboard 830 puncte - 26lei/buc7.b)Set de 65 fire - 14lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc)7.c)Set de 40 fire - 15lei/set Lungime 20cm1p-1p Male - Female7. d) Mini-breadboard 170 puncte - 8lei/buc7.e) Mini breadboard 400 puncte - 13lei/buc7.f) Sursa pentru breadboard 3.3v - 5V - 9lei/bucApply to MB102 breadboardInput voltage: 6.5-12 V (DC) or USB power supplyOutput voltage: 3.3V/5V can switch overMaximum output current: <700 ma8. Termometru IR (infrarosu) - 70lei/buc(-50 - 330°C - alim 2x1,5V AAA) sau (-50 - 380°C- alim 9V ; disponibil 2 buc.) (-50 - 500°C - alim 2x1,5V AAA) - 75lei/buc 9. a). Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/bucSuperior material made, strong structureTip Diameter: 0.8mmGrip Diameter: 3.175mmTotal Length: 37.5mmMaterial: cemented carbide(tungsten steel, tip), high-speed steel(grip)45lei/set de 10buc http://imageshack.us/a/img32/3916/uho4.jpg9. b). Set spirale 0.3mm - 1.2mm - 45lei/setNumai set intreg.carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm, link10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buclink11. Termometru digital de panou Pret: 15lei/bucInterval de masura: -50°C -> 110°CRezolutie afisare: 0.1Precizie masurare: ±1°CAlim: 2 buc LR44 (incluse)Lung cablu semzor: 1mDimensiuni: 47*28*14mmhttp://i39.tinypic.com/5d1cfr.jpg12. a). ARDUINO UNO R3 + cablu USB - 65ei/buc http://imageshack.us/a/img30/7024/pspa.jpg12. b). Shield LAN W5100 - 55lei/buc link12. c) Arduino MEGA 2560 R3 + cablu USB - 100lei/buc12. d) Shield LCD keypad - 45lei/buchttp://i62.tinypic.com/2hrft6x.jpg 13. Afisaje LEDhttp://imageshack.us/a/img62/4617/2f8f.jpg4 Digits :CEAS - 5lei/bucPin Number: 12 pins.Digit Number: 4 digits.Common anode.Digit Height: 0.56 inch.Color: Red.3 DIGITI + comun - 2lei/bucDisplay: 0.36" LED digital tubeRange: 1.9 -2.2VDisplay Color: RedSize: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W)10-Segmente GREEN - 2lei/bucSize: Approx. 2.4*1*1.4cm (L*W*H)14. 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 35lei/bucSize: 28.2 mm (length) * 13.1 mm (width) * 10 mm (high)Working voltage: 3 V - 5.5 VTemperature measurement range: - 40°c to 80°cMeasuring accuracy: 0.5°cThe humidity measuring range: 0-100% RHMeasuring accuracy: 2% RHhttp://i62.tinypic.com/zxjz8l.jpg16. Ampermetru de panou BLUE 0-10A - 20lei/buchttp://i44.tinypic.com/29kw0nt.jpg17. Player MP3 + radio + remote - 60lei/buclink1 link21.5" Display, working voltage: DC 8~14.5V, working current: 1500mA, USB output voltage: DC 5V + / - 5%, USB output current: 1000mA, decoding format: MP3, support storage: USB disk, TF card, TF card support up to 16GB, impedance: 32ohm, AUX input level: 650mV, FM frequency range: 87.5~108MHz, output power: 2 x 3W / 4ohm horn, connector: 1 x USB 2.0, 1 x TF card slot, 1 x 3.5mm out jack18. Sursa Step-UP USB 5V max.600mA - 7lei/buclinkSize:34 (mm) x16.2 (mm) ultra-small sizeUin: 1-5V; Output 5V stabilizat max.600mASe pot incarca telefoane, tablete, etc utilizand baterii sau elemente LIon 19. Aparat de masurat distanta cu ultrasunete - 80lei/buc Power supply: 1 x 9V Accuracy: +/-0.5% ; Frequency: 40 kHz (ultrasonic pickup)Auto stop: switches off if you do not press any key for 4 min Laser beam: Wattage 1mW Working temperature: 0oC ~ 43oCRange: 0.91m to 18mDimensions (H-P-l): 142 x 73 x 47mm 20. Display NOKIA5110 - 20lei/buc 21. Modul RTC I2C cu DS1307 + EEPROM 24C32 - 15lei/buc DS1307 I2C real time clock chip (RTC)24C32 32K I2C EEPROM memory Baterie inclusa 22. Set mufe M+F 5 pini - 8lei Diam. 12mm Comanda minima 70leiTransport+Ramburs: 11lei Oferta!!! Reducere 10% la orice comanda >100lei pana Luni 9.06.2014 Link spre comentariu
soringt Postat Iunie 9, 2014 Autor Partajează Postat Iunie 9, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 10, 2014 Autor Partajează Postat Iunie 10, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 11, 2014 Autor Partajează Postat Iunie 11, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 12, 2014 Autor Partajează Postat Iunie 12, 2014 Anunt valabil. Se adauga: Senzor DS18B20 waterproof - 15lei/buc Preturi noi pentru: 2.d) Voltmetru panou WATERPROOF 3-30V - 30lei/buc 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 35lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 30lei/buc 12. c) Arduino MEGA 2560 R3 + cablu USB - 90lei/buc - disponibile 2 buc. 12. d) Shield LCD keypad - 40lei/buc 15. Senzor de temperatura+ umiditate DHT22 (AM2302) - 30lei/buc 19. Aparat de masurat distanta cu ultrasunete - 75lei/buc Aceste reduceri sunt limitate in timp. Comanda minima 70lei + transport Link spre comentariu
soringt Postat Iunie 13, 2014 Autor Partajează Postat Iunie 13, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 14, 2014 Autor Partajează Postat Iunie 14, 2014 Anunt valabil Link spre comentariu
soringt Postat Iunie 16, 2014 Autor Partajează Postat Iunie 16, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 17, 2014 Autor Partajează Postat Iunie 17, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 18, 2014 Autor Partajează Postat Iunie 18, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 19, 2014 Autor Partajează Postat Iunie 19, 2014 Anunt valabil Link spre comentariu
soringt Postat Iunie 20, 2014 Autor Partajează Postat Iunie 20, 2014 Anunt valabil Oferta limitata! 8. Termometru IR (infrarosu) -50 - 330°C- 60lei/buc Comanda minima 70lei + transport Link spre comentariu
soringt Postat Iunie 21, 2014 Autor Partajează Postat Iunie 21, 2014 Anunt valabil. Link spre comentariu
soringt Postat Iunie 22, 2014 Autor Partajează Postat Iunie 22, 2014 Anunt valabil. Link spre comentariu
