soringt Postat Ianuarie 15, 2014 Partajează Postat Ianuarie 15, 2014 1. LCD Blue compatibile HD44780 - Pret: 16x2 - 15lei ; 20x4 - 40lei LCD HD44780 16x2 GREEN,WHITE,BLUE,ORANGE - 40lei/buc Aceasta este culoarea caracterelor, fundalul este negru. Se vad excelent. 2.a) Voltmetru de panou - Pret: 20lei/buc RED - 17 lei/buc Operating voltage: 3.2 ~ 30V Operating Current: <60mA Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! Mounting holes: 45.5 x 26.5 mm Measurement rate: ≥ 500mS Measurement accuracy: 1% Cele cu 3 fire (RED,BLUE si GREEN) masoara tensiuni in intervalul 0 - 100V Display: 0.56 "LED, color RED / BLUE / GREEN / ORANGE / WHITE ! 2.b)Voltmetru BLUE (mini) 3V-32V - 15lei/buc Dimension: 23mmx15mmx10mm Sample period:500ms ; Resolution:1%+1digit Reverse Voltage Protection 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 50lei/buc 3. b) Volt-Ampermetru RED + RED 0-100V 0-10A - 35lei/buc Display color: (Red & Blue) or (Red & Red) LED (dual display). Display: 0.28" LED digital. Operating voltage: DC 4.5 ~ 30V. Measure voltage: DC 0 ~ 100V. Operating Current: <20mA. Measure current: 10A (direct measurement, built-in shunt). Mounting cutout: 45.5mm x 26.5mm. Size: 48mm x 29mm x 21mm 4.a) Sursa DC-DC step-down cu LM2596+ LED Power - 11lei/buc Uin: 4.75V-35V Uout: 1.25V-26V ; Imax: 3A cu radiator LED de Power Dimensiuni : 46x26mm 4.b) Sursa DC-DC step-down cu LM2596 - 10lei/buc Uin: 3.2V-40V Uout: 1.25V-35V Output current: 2A (max.3A) Transfer efficiency:92%(max) Switching Frequency:65KHz Dimensiuni: 43x21mm 4.c) Sursa DC-DC step-down cu LM2596 + Voltmetru LED - 35lei/buc Uin: 4-40 v Uout:1.25V - 37V Imax: 3A cu radiator Culoare afisaj: Rosu ; Rezolutia voltmetrului: ± 0.05V ; Comutare voltmetru intrare/iesire; Afisaj ON/OFF 4.d) Sursa DC-DC STEP-UP cu LM2577 - 15lei/buc Input 3V ~ 32V Output 4V ~ 38V Input Current: max 3A Conversion efficiency <94% Dimensions: 50x21mm 5. Soclu ZIF40 - 4lei/buc 6.Senzor PIR - 11lei/buc Working voltage range: DC 4.5-20V Static current: <50uA High level output: 3.3 V / low 0V Delay time: 0.5-200S (adjustable) Blocking time: 2.5S (the default) Sensing range (3-7m) Size: 32mm*24mm circuit board Induction angle: <100 degree cone angle Working temperature: -15-+70 degre Cu un tranzistor si un releu se poate face o automatizare instant! 7.a) Breadboard 830 puncte - 26lei/buc 7.b)Set de 65 fire - 14lei/set Lungime fire: 24CM(4buc)/20CM(4buc)/16CM(8buc)/12CM(49buc) 8. Mini freza pentru PCB - 25lei/buc Alimentare 12V +spiral de 0.8mm 9. Spiral 0.5mm, 0.8mm si 1mm carbura - 5lei/buc Superior material made, strong structure Tip Diameter: 0.8mm Grip Diameter: 3.175mm Total Length: 37.5mm Material: cemented carbide(tungsten steel, tip), high-speed steel(grip) 45lei/set de 10buc 10. Adaptor I2C pentru LCD 16x2 sau 20x4 - Pret: 12lei/buc 11. Termometru digital de panou Pret: 15lei/buc Interval de masura: -50°C -> 110°C Rezolutie afisare: 0.1 Precizie masurare: ±1°C Alim: 2 buc LR44 (incluse) Lung cablu semzor: 1m Dimensiuni: 47*28*14mm 12. ARDUINO UNO R3 + cablu USB - 60ei/buc 13. Afisaje LED 4 Digits :CEAS - 5lei/buc Pin Number: 12 pins. Digit Number: 4 digits. Common anode. Digit Height: 0.56 inch. Color: Red. 3 DIGITI + comun - 2lei/buc Display: 0.36" LED digital tube Range: 1.9 -2.2V Display Color: Red Size: Approx. 2.3cm x 1.5cm/0.91inch x 0.59inch (L*W) 10-Segmente GREEN - 2lei/buc Size: Approx. 2.4*1*1.4cm (L*W*H) 14. Diferite CI-uri DS12C887+ - 20 lei/buc M48T02-70PC1 - 25lei/buc M48T02-150PC1 - 25lei/buc M4T28-BR12SH1 - 10lei/buc MAX1496 - 15lei/buc MAX7219 - 10lei/buc Comanda minima 70lei Transport+Ramburs: 11lei Link spre comentariu
soringt Postat Ianuarie 16, 2014 Autor Partajează Postat Ianuarie 16, 2014 UP! 12. ARDUINO UNO R3 - stoc 0 Se adauga: 9.Set spirale 0.3mm - 1.2mm - 45lei/set Numai set intreg. carbide micro drill 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2mm, 15. Ampermetru de panou BLUE 0-10A - 20lei/buc Shunt inclus. Ualim: 4-30V Dimensiuni: 45 x 26 mm (L*W) Link spre comentariu
albasete Postat Ianuarie 20, 2014 Partajează Postat Ianuarie 20, 2014 Astept si eu un Voltampermetru red+red. Link spre comentariu
albasete Postat Ianuarie 21, 2014 Partajează Postat Ianuarie 21, 2014 Aveti un mp. Link spre comentariu
soringt Postat Ianuarie 21, 2014 Autor Partajează Postat Ianuarie 21, 2014 Aveti un mp. Coletul este deja la posta. Link spre comentariu
albasete Postat Ianuarie 21, 2014 Partajează Postat Ianuarie 21, 2014 Ola ! Multumesc ! Succes ! Link spre comentariu
soringt Postat Ianuarie 23, 2014 Autor Partajează Postat Ianuarie 23, 2014 Se adauga: 3. a) Volt-Ampermetru RED + BLUE 0-100V 0-10A - 50lei/buc -o alta varianta 7.3)Set de 40 fire - 15lei/set Lungime 20cm 1p-1p Male - Female 12. b) Motor Drive Shield L293D pt. ARDUINO UNO, MEGA - 35ei/buc Comanda minima 70lei + posta Link spre comentariu
albasete Postat Ianuarie 23, 2014 Partajează Postat Ianuarie 23, 2014 In seara aceasta am luat coletul de la posta. Excelent ambalat! User serios, recomand. Un mare UP de la mine ! Link spre comentariu
