Vizitator xenia6 Postat Ianuarie 4, 2014 Partajează Postat Ianuarie 4, 2014 Buna , -Ma poate ajuta cineva cu un sfat in legatura cu un (procesor compresor ) DBX166XS? Mi as dorii sa stiu daca acest procesor se leaga intre mixer si crossover si daca se foloseste pentru uniformizarea semnalului ( gen muzica redata de pe PC care ataca crossoverul sau se foloseste doar pentru aplicatiile LIVE microfon, instrument ??? Link spre comentariu
validae Postat Ianuarie 4, 2014 Partajează Postat Ianuarie 4, 2014 http://www.dbxpro.com/en-US/products/166xs Adding a dbx® 166xs Compressor/Limiter/Gate to your live sound rig or studio gives you more dynamic control to help create a more polished, professional sound. Having compression in your audio chain gives you the ability to smooth out uneven levels, add sustain to guitars and fatten up your drums. It also makes it easy to bring vocals to the front of your mix - adding greater clarity and making them stand out from the surrounding instruments. To protect your expensive amps and speakers the PeakStop® limiter provides an absolute ceiling for peak excursions or large transients that could damage your equipment. Aici explica foarte clar avantajele ! Link spre comentariu
