FRECVENTMETRU CU PIC ,INTREBARI HELP !
Vizitator LastSpartan
salut SUNT UN INCEPATOR , VA ROG NU MA LUATI TARE ! incerc sa realizez acest FRECVENTMETRU https://sites.google.com/site/vk3bhr/home/fm2 .daca observati pe schema in stanga jos a lcd ului se afla niste jumpere care duc la pic si care sunt desfacute ,autorul mentioneaza ceva de acele treceri 10 11 12 13 . dar nu inteleg ce zice . poate cineva sa mi raspunda concret la ce face fiecare ? va rog cititi sectiunea setting up si ajutati ma !
  • Răspunsuri 4
  • Mircea
Setting up!
Before the frequency meter will work properly, it must be calibrated. This may be as simple as connecting a known frequency source and adjusting the trimmer capacitor so the correct value is displayed. If you are unable to adjust the displayed frequency, then a "coarse calibration" is required.
[TRADUS] Inainte ca frecvmetru sa fie utilizat, trebuie calibrat. Asta poate fi simplu facut prin conectarea unei frecvente cunoscute si ajustand condensatorul trimmer pana cand valoarea buna este afisata. Daca nu merge asa, atunci o "calibrare grosiera" e necesara.
This involves starting with the power off. Pin 10 is connected to ground and the power is then turned on (and held on). The PIC will measure and display the input frequency, followed by the letters CAL. If you can't adjust the indicated frequency to the correct value (by adjusting the 33 pF trimmer), then coarse adjustments can be made by briefly connecting pin 12 or pin 13 to ground. It may take several tries, because the program only checks these pins once each measurement (0.4 second). Once you are happy with the adjustment, remove the ground from pin 10 (while power is still applied). This will cause the PIC to store the calibration in non volatile internal memory.
[TRADUS] Opresti alimentarea. Pinul 10 este conectat la masa, apoi alimentezi. PIC va masura frecventa si o va afisa, urmata fiind de textul CAL. Daca nu poti ajusta la valoarea corecta (prin varierea trimmerului de 33pF), atunci ajustarea grosiera poate fi facuta conectant pin 12 sau pin 13 la masa. Vei incerca de cateva ori pentru ca programul verifica acesti pini la fiecare masurare (0,4 sec). Odata buna ajustarea, deconectezi pin 10 de la masa (montajul inca alimentat). PIC va memora calibrarea in memoria nevolatila.
[NOTA] Banuesc ca prin apasarea 12 si 13 (punere la masa), incrementezi/decrementezi valoarea afisata.
Normally pin 10 is floating at turn on, but may be grounded later to "program" the Intermediate frequency offsets. The next few paragraphs, copied (with amendments) from the September 2002 article describe how this is done.
[TRADUS] In mod normal, pinul 10 este flotant la alimentare, dar poate fi pus la masa ca sa programezi offseturi pentru frecventele intermediare. Paragrafele urmatoare, copiate (cu anotari) din articolul din Sept 2002 descriu cum se face asta.
To program the intermediate frequencies, connect the BFO to the the counter then set up the PIC as follows:
[TRADUS] Sa programezi frecventele intermediare, conectezi BFO la frecventmetru si setezi PIC dupa cum urmeaza:
Ground pins 12 and/or 13 of the PIC to select one of three IF offsets. Pin 12 when pulled low, indicates the BFO is on its lower frequency. Pin 13 when pulled low, indicates the BFO is on its higher frequency. Alternatively, you can pull both pins 12 and 13 low to use the third offset. If both pins 12 and 13 are left floating, the PIC will not actually store anything!
[TRADUS] Pui la masa pinii PIC 12 si/sau 13 ca sa selectezi unul dintre offseturile IF. Cu pin 12 la masa, indica ca BFO este la valoarea minima a frecventei. Cu pin 13 la masa, indica ca BFO este la valoarea maxima a frecventei. Alternativ, poti pune la masa ambii pini 12 si 13 ca sa utilizezi al 3-lea offset. Daca ambii 12 si 13 sunt flotanti, PIC nu va memora nimic!
To store the measured BFO in the selected internal EEPROM, just ground pin 10 of the PIC for at least 0.5 second, then release it.
[TRADUS] Ca sa memoreze BFO masurata in EEPROM, pune la masa pinul 10 cel putin 0,5 sec, apoi lasa-l flotant.
[NOTA] Banuiesc ca pui pin 10 la masa dupa ce ai programat offset IF maxim si minim, si al 3-lea offset.
For normal operation, the RF input of the counter is connected to the receiver VFO and the PIC uses the stored IF offsets to calculate the actual frequency. If neither BFO selection pin (12 and/or 13) is pulled low, the PIC uses the average BFO frequency. If no IF offset is required, just measure and store 0Hz for both offsets. Alternatively, you can pull both pins 12 and 13 low to use the third offset (which must also be programmed to 0Hz.)
[TRADUS] In operarea normala, intrarea RF a frecventmetrului este conectata la VFO al receptorului si PIC utilizeaza valorile IF memorate ca sa calculeze frecventa reala. Daca nici o selectie de pinb 12 si/sau 13 nu este facuta (prin punere la masa), PIC foloseste valoarea media a frecevntei BFO. Daca offseturile IF nu sunt necesare, atunci memoreaza 0Hz pentru ambele offseturi. Altfel, poti pune la masa 12 si 13 ca sa folosesti al 3-lea offset (care trebuie programat la 0Hz).
Restul se refera la cum foloseste autorul frecventmetru ca sa-i afiseze frecventa la receptorul lui folosind offseturile IF. Nu cred ca este cazul tau. Sper sa fii inteles ce ai de facut, trebuie sa folosesti doar partial textul ca sa il folosesti doar ca un frecventmetru simplu.
multumesc pentru ca ai raspuns, insa pentru evitarea calibrarii grosiere, pot sa misc direct din trimer pana la afisarea frecventei corecte ?calibrarea grosiera are cam prea multi pasi de urmat ,si ma gandeam sa sar peste ea ...
Uite ca am facut un rezumat, mai simplu de atata nu se poate:
Daca din trimmerrul de 33pF nu aduce la frecventa dorita la afisaj, atunci trebuie musai sa faci asta:
Opresti alimentarea. Cu pinul 10 este conectat la masa, alimentezi. PIC va masura frecventa si o va afisa, urmata fiind de textul CAL. Atunci ajustarea grosiera poate fi facuta conectand prin alternanta pin 12 si pin 13 la masa. Vei incerca de cateva ori pentru ca programul verifica acesti pini la fiecare masurare (0,4 sec). Odata buna ajustarea, deconectezi pin 10 de la masa (montajul inca alimentat). PIC va memora calibrarea.
Prin apasarea 12 si 13 (punere la masa), incrementezi/decrementezi valoarea afisata.
Apoi, pentru ca frecventmetru este facut sa lucreze cu IF (pentru receptorul autorului) faci cel putin asta:
Pune la masa ambii pini 12 si 13 ca sa utilizezi al 3-lea offset. Si pui intrarea RF la masa ca sa masoare 0Hz. Ca sa memoreze , pune la masa pinul 10 cel putin 0,5 sec, apoi lasa-l flotant.
Apoi:
Pune definitiv la masa 12 si 13 ca sa folosesti al 3-lea offset (care trebuie programat la 0Hz).
Daca ti se pare prea complicat, atunci cauti alt frecventmetru pe Internet, ca este plin de ele, fara alte functii (ca aceste IF memorate).
