Dif de 12" cu parametrii EW-1203
Vizitator moga alexxx
Salut pt dif :Nominal Diameter(ins) 12 Frequency Range(Hz) 47-3.5K Sensitivity(db,1w/1m) 94 Power Handling(w rms) 250 Nominal Impedance(ohm) 8 Resonance, Fs(Hz) 47 Effective Piston Diameter (mm) 250 Volume Vas(litres) 65,7 Total Dynamic Mass, Mmt(gm) 56,8 Total Q, Qts 0,61 Mechanical Factor, Qms 4,65 Electrical Factor, Qes 0,71 BL factor, BL(Txm) 11,52 Compliance, Cms(mm/N) 0,2 Coil Inductance @ 1kHz, Le(mH) 1,22 Baffle Cutout Diameter (mm) 279 Net Weight (kg) 3.2.
Cam ce mi se recomanda ? :smt003 .
Multumesc anticipat.
Mai mentionez ca vreau sa il folosesc ca bass pe boxe....( nu este nevoie sa coboare sub 40hz) din cauza ca vor fi folosite in aplicatie 2.1
  • Răspunsuri 0
Zile populare
