termostat wireless home made?
mirceacra
Doresc sa imi construiesc un termostat pentru centrala dar wireless deoarece nu pot trage un fir din camera in care doresc reglarea temperaturii pana la centrala. Am un termostat mecanic cu un contact normal deschis, oare as putea sa il cuplez cu un modul tx rx de genul
Posted Image
Aceste module lucreaza pe 315mhz si au urmatoarele caracteristici
Product Model MX-05V
Operating voltage: DC5V quiescent current: 4MA
Receiving Frequency: 315MHZ
Receiver sensitivity:-105DB
Size: 30 * 14 * 7mm external antenna: 32CM single core wire, wound into a spiral
Technical parameters of the transmitter head
Product Model: MX-FS-03V
Launch distance :20-200 meters (different voltage, different results)
Operating voltage :3.5-12V
Dimensions: 19 * 19mm
Operating mode: AM
Transfer rate: 4KB / S
Transmitting power: 10mW
Transmitting frequency: 315M
An external antenna: 25cm ordinary multi-core or single-core line
Pinout from left ? right: (DATA; VCC; GND)
Application environment
Remote control switch, receiver module, motorcycles, automobile anti-theft products, home security products, electric doors, shutter doors, windows, remote control socket, remote control LED, remote audio remote control electric doors, garage door remote control, remote control retractable doors, remote volume gate, pan doors, remote control door opener, door closing device control system, remote control curtains, alarm host, alarm, remote control motorcycle remote control electric cars, remote control MP3.
Mentionez ca nu vreau sa cumpar un termostat wireless gata facut ce cost ain jur de 200 lei...
Mai am o telecomanda cu un canal prin radio pentru un corp de iluminat gen lustra dar care actioneaza numai la impuls (buton apasat), cum pot face ca atunci cand termostatul trece de pe contact inchis pe deschis si invers sa dea doar un impuls?
  • Răspunsuri 10
  • mirceacra
    5
  • salsa
  • leo 17
  • validae
Zile populare
de la frati nostri din china gasim sonerii fara fir ..adapteaza una si e mai simplu
am un astfel de montaj dar cum fac ca atunci cand termostatul trece de pe inchis pe deschis sa dea doar un impuls scurt (ca o apasare pe un buton)?
cu un 555 se poate realiza un temporizator pt o sec ,destul pt a da un start pt releu sau ce folositi pt comanda
termostatul mecanic contine un contact normal deschis care atunci cand scade temperatura se inchide alimenteaza un temprizator facut un 555 care da un impuls la telecomanda ce la randul ei comanda in receptor un releu ce se inchide si porneste centrala. cand ajunge la temperatura dorita termosatul deschide contactul dar cum mai da iarasi un impuls?
Eu cred ca acolo trebuie o telecomanda cu doua canale, unul pentru pornirea centralei, altul pentru oprirea ei.Fiecare canal sa fie comandat de contactele termostatului prin intrermediul unor circuite monostabile.La receptor, un circuit bistabil va fi basculat in cele doua stari pe rand primind comenzi de la termostat prin intermediul radiocomenzii. Eu asa as face, nu am studiat un produs comercial, dar asa i-mi pare normal.
Da cred ca aveti dreptate, am o telecomanda pentru o lustra cu 3 canale. Credeti ca ma puteti ajuta cu niste scheme de principiu?
Atentie ! Banda de 315MHz nu e autorizata in Romania pentru amatori. Nu stiu daca la puterea modulelor respective e vreo problema ...LE In Romania e folosita pentru radionavigatie aeronautica si maritima .
Termostatele comerciale wireless transmit comanda din 10 in 10 minute. Daca nu primeste comanda la timp, receptorul "piscuie". Nu mai retin daca opreste centrala sau doar se aprinde un led de avarie.Dar, plecand de la ideea asta se poate face urmatoarea smecherie: in momentul cand termostatul cupleaza, el alimenteaza un montaj care emite un semnal scurt, din 5 in 5 minute de exemplu. Acest semnal va reseta un temporizator de 6 minute, aflat in receptor. Deci receptorul, daca nu primeste semnalul de reset la timp, va decupla releul care comanda centrala. "Eroarea" de maxim 6 minute (doar la decuplare) nu cred ca e importanta in aplicatia de fata. Desigur, timpii pot fi setati dupa cum doreste executantul.Oricum ai nevoie de un asemenea sistem, pentru ca sa nu ai surpriza ca centrala va merge non-stop in caz ca se termina bateriile la emitator sau se intampla ceva cu montajul.
da se pare ca si userul #salsa are dreptate, intr-adevar se pare ca problema nu e foarte simpla, trebuie tinut cont si de acest aspect....Daca mai sunt ideii sunt binevenite....
Mai este posibilitatea, mai probabila decat epuizarea bateriilor emitatorului, unei pene de curent. In acest caz, centrala va porni la primirea unui nou semnal de reset din partea emitatorului, daca termostatul e cuplat.Desigur, am presupus ca emitatorul este alimentat din baterii si receptorul din retea, ca la orice termostat comercial.
