Vizitator GAEE1968 Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 VA SALUT PE TOTI AM UN CASETOFON MARCA GRUNDIG 6500 RDS INFOMAT NU STIU CUM SA IL FAC SA PORNEASCA , CAND IL DESCHID IMI APARE SAFE DUPA CARE IMI APARE 1 _ _ _ _ PRESUPUN CA TREBUIE SA INTRODUC CODUL NU? AM CODUL IL BAG DAR LA SFARSIT NU STIU PE CE BUTON SA APAS CA SA FUNCTIONEZE . MA POATE AJUTA CINEVA ? VA MUTUMESC ANTICIPAT Link spre comentariu
Vizitator Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 After switching on the set ' SAFE ' will be displayed followed by '1 - - - -' indicating the minimum timer lock.Press preset [ 1 ] repeatedly for the first digitPress preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digitPress preset [ 4 ] repeatedly for the fourth digit To save the code press the [ FM ] key for a few seconds.'SAFE' will display briefly and the set will operate. Link spre comentariu
Vizitator GAEE1968 Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 After switching on the set ' SAFE ' will be displayed followed by '1 - - - -' indicating the minimum timer lock.Press preset [ 1 ] repeatedly for the first digitPress preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digitPress preset [ 4 ] repeatedly for the fourth digit To save the code press the [ FM ] key for a few seconds.'SAFE' will display briefly and the set will operate.SCRI SI TU IN ROMANESTE TE ROG AM INTELES DAR VREAU SA FIU SIGUR MERSI MULT Link spre comentariu
Vizitator GAEE1968 Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 After switching on the set ' SAFE ' will be displayed followed by '1 - - - -' indicating the minimum timer lock.Press preset [ 1 ] repeatedly for the first digitPress preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digitPress preset [ 4 ] repeatedly for the fourth digit To save the code press the [ FM ] key for a few seconds.'SAFE' will display briefly and the set will operate.SCRI SI TU IN ROMANESTE TE ROG AM INTELES DAR VREAU SA FIU SIGUR MERSI MULTAM FACUT ASA CUM ESTE SCRIS DAR DUPA CE AM INTRODUS CODUL A APARUT SAFE SI NU MAI FACE NIMIC A RAMAS PE SAFE Link spre comentariu
Vizitator Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 Mai mult ca sigur ai bagat un cod gresit memorarea se face cu FM ,Pe viitor nu mai scrie cu majuscule pe forum?Posteaza serile de pe el poate primesti codul corect... Link spre comentariu
Vizitator GAEE1968 Postat Noiembrie 29, 2013 Partajează Postat Noiembrie 29, 2013 Mai mult ca sigur ai bagat un cod gresit memorarea se face cu FM ,Pe viitor nu mai scrie cu majuscule pe forum?Posteaza serile de pe el poate primesti codul corect...OK Mersi Link spre comentariu
