PPPOE + Asus rt-n12e
criss
Buna Mi-am luat un router Asus RT-N12E cu fw 2.0.0.25, folosesc reteaua RDS si am un media converter(acel modem) de la ei.Problema este ca nu ma pot conecta la internet in nici un fel!Am incercat cu laptopul care l-am folosit la instalare, crezand ca filtreaza adresa MAC dar si de pe un alt pc m-am putut conecta prin PPPOE, deci nu se filtreaza..... rahatul acesta de router nu-i instare de a se conecta(am incercat si cu clonarea adresei MAC).Cu routerul vechi DLINK DIR600 merge perfect! aceeasi setari le-am facut si pe acesta, dar nici in ruptul capului nu vrea sa-mi functioneze.Am dezactivat firewalul, resetat folosind setarile de baza(adresele ip + DHCP activ) + cele pt PPPOE dar nimic, chiar nu mai stiu ce sa-i fac inainte de al arunca pe geam :(Aici aveti loginurile pt acest router:
Oct 1 15:19:12 eth0 added. vid=9 Member port 0x10...Oct 1 15:19:12 eth1 added. vid=8 Member port 0x1...Oct 1 15:19:12 eth2 added. vid=9 Member port 0x2...Oct 1 15:19:12 eth3 added. vid=9 Member port 0x4...Oct 1 15:19:12 eth4 added. vid=9 Member port 0x8...Oct 1 15:19:12 [peth0] added, mapping to [eth1]...Oct 1 15:19:22 WAN: Init PPPOE connection on interface eth1Oct 1 15:19:22 UPnP: start_UPnPOct 1 17:19:27 pppd[729]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4Oct 1 17:19:27 pppd[729]: pppd 2.4.4 started by root, uid 0Oct 1 17:19:28 WAN Connection: WAN was exceptionally disconnected.Oct 1 17:20:12 pppd[729]: Timeout waiting for PADO packetsOct 1 17:20:13 pppd[729]: Connection terminated.Oct 1 17:20:13 pppd[729]: Unable to complete PPPoE DiscoveryOct 1 17:20:13 pppd[729]: Terminating on signal 15Oct 1 17:20:13 pppd[729]: Exit.Oct 1 17:20:27 pppd[803]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4Oct 1 17:20:27 pppd[803]: pppd 2.4.4 started by root, uid 0Oct 1 17:21:02 pppd[803]: Timeout waiting for PADO packetsOct 1 17:21:03 pppd[803]: Connection terminated.Oct 1 17:21:03 pppd[803]: Unable to complete PPPoE DiscoveryOct 1 17:21:03 pppd[803]: Terminating on signal 15Oct 1 17:21:03 pppd[803]: Exit.Oct 1 17:21:06 WAN Connection: Ethernet link down.Oct 1 17:21:08 WAN Connection: WAN was exceptionally disconnected.Oct 1 17:22:16 WAN: Init PPPOE connection on interface eth1Oct 1 17:22:17 UPnP: start_UPnPOct 1 17:22:20 pppd[1036]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4Oct 1 17:22:20 pppd[1036]: pppd 2.4.4 started by root, uid 0Oct 1 17:22:55 pppd[1036]: Timeout waiting for PADO packetsOct 1 17:22:56 pppd[1036]: Connection terminated.Oct 1 17:22:56 pppd[1036]: Unable to complete PPPoE DiscoveryOct 1 17:22:56 pppd[1036]: Terminating on signal 15Oct 1 17:22:56 pppd[1036]: Exit.
  • Răspunsuri 11
  • criss
    6
  • andreivlad1999
  • japan
  • popa ionut
acolo se discuta despre clonarea adresei mac, am incercat si aceasta metoda desi NU este filtrata adresa mac. reteaua in care se afla este compusa din 4 desktopuri 2 laptopuri si 2 servere, dintre care doar laptopul a fost conectat direct la media converter in momentul instalarii relei RDS deci celelalte pcuri nu au cum sa aiba stocate adresele mac la cei de la rds. desi cum am mai spus am clonat adresa mac si tot aceeasi rahat.
Au avut si altii probleme cu aces router pe PpPOE. Se pare ca nu reuseste sa se conecteze si daca se conecteaza este instabil, wirelessul este penibil. Uite un comentariu de pe un site de vanzari online:
Semnal wireless slab, inexistent de cele mai multe ori, accepta greu setarile ppoe de la RDS. A trebuit sa resetez routerul de vreo 10 ori pana am reusit sa imi comunice pe pppoe. Pe liber e ok, nu se pierde conexiunea wireless asa de des, dar pe ppoe, mai mult e picat decat functional. Merge mult mai bine Modelul N10 sau N10U.Pro: Pai cam nu are puncte pro in afara de router prin fir. Wireless e sub orice critica. Am mai luat si alte variante de router asus, dar asta e cea mai naspa. Recomand asus n10 ca alternativa. E mult mai ok.Contra: Semnal wireless cam slabut si cu cam tot timpul pica. Stau la casa si de la etaj pana jos la parter cam pierd tot semnalul wireless. Sunt momente cand semnalul wireless de la router nu emite deloc.
Uite si un altul de pe acelasi site:
Nu recomand acest router, l-am achizitionat si nu sunt nici 40% multumit de el. Merge tare naspa
Incearca sa faci un update la ultima varianta de firmware, eventual incearca un firmware alternativ daca ai aceasta optiune.
i-am facut uptadeul de la 2.0.0.24 la 2.0.0.25, aceeasi treaba. Maine am sa-l duc inapoi de unde l-am cumparat ca deja turb cu ea.ps. nu am crezut ca vreodata pot sa pun mana pe un router atat de penibil .. sub orice categorie...cred ca am sa-l inlocuiesc cu un dlink sau un netgear ca pana acuma nici unul dintre ele nu m-a dezamagit.
Din pacate in ultimul timp tot mai multe routere SOHO au probleme majore de stabilitate. Au probleme serioase de hard si/sau de soft. Eu am acum doua TP-Link si anume WR1043ND si un WDR3600. WR1043ND este stabil dar nu are hardware nat si are procesorul lent+memorie RAM mica. WDR3600 este mai rapid si ar trebui sa fie dual band dar in realitate poti considera ca nu ai 2.4GHz daca esti la mai mult de 7-8m de el. E un gunoi de router cand este vorba de aceasta banda. Poate ca am avut eu "noroc" cu cele doau WDR3600 versiune 1.4 care mi-au trecut prin mana dar nu cred. Sunt sub orice critica. Primul mi l-au inlocuit in garantie cu cel pe care il am acum si care este la fel de prost ca cel inlocuit.Puncte bune: rapid pe cablu, PPPOE functional, banda de 5GHz stabila.Puncte slabe: practic nu are banda de 2.4GHz(pentru ca nu functioneaza), nu este compatibil cu IPV6 de la RDS desi in specificatii este trecut ca ar fi compatibil IPV6.Ai grija ce router iti alegi :da .
cu TP-Link am mai avut probleme minore (cadere retea,oscilare nivel semnal wifi), dar niciodata cu conexiunea pppoe. Pana la urma pt un Dlink DIR-636L am optat, sper ca am facut o alegere corecta si sper ca sa raman cu aceeasi parere buna despre DLINK ca si pana acum.
  • 3 săptămâni mai târziu...
Buna seara. Ca sa nu mai deschid un subiect nou, am si eu o nelamurire. Internetul este de la RDS cu media converter (acel modem) de la ei,ma gandeam sa achizitionez un router wireless, care va fi utilizat pentru laptop, telefon mobil. Intrebarea este ce router wireless cu mufa usb 2.0 (voi conecta un hard extern) recomandati ? :jytuiyu Va multumesc anticipat.
Eu am testat TP Link WR1043ND si WDR3600 cu hard extern Seagate de 320. Ambele au functionat fara probleme cu un plus de viteza pentru WDR3600. Acoperirea wireless este slaba la WDR3600, acceptabila la WR1043.
Astazi l-am incercat cu un hdd extern de 2.5 alimentare prin usb 500Gb si mi-a mers struna, precizez acest hdd pacatos pe desktop nu-mi functioneaza corect(porneste cand are chef) doar pe laptop merge si aici din prima mi-a pornit. Este un Iomega 31887300 cu hdd samsung cu 2 partiti NTFS.post-8589-139829728288_thumb.jpgpost-8589-13982972829_thumb.jpg
