Cum instalez pe un Dell SX 270 XP daca nu am cd-rom ?
Vizitator Alexandrulcn
Hmmm.
Incearca smartdrv.exe, s-ar putea ca smartdvr.exe sa nu fie acelasi lucru. :yawinkle:
http://support.microsoft.com/kb/296814/
Daca disketa de 98 e in regula ar trebui sa poti executa smartdrv.exe.
Hmmm. Sa nu uiti sa fii pe a(sau ce litera are alocata unitatea de disketa) cand dai comanda smartdrv.
Fara smartdrv dureaza chiar mult. Cunosc persoane care lasau peste noapte sa "lucreze" pc-ul si dimineata cand se trezeau aveau senzatia de ... deja vu.
  • Răspunsuri 21
  • pyu
  • Blind
  • LevyB
  • Dr4g0n
:( era destul de simpla folosirea solutiei date de pyu .....
ai mai jos pasii pentru folosirea unei dischete de boot w98
How do I install Windows from the command prompt?
If your computer will not boot from a CD, you can still use the Windows XP Setup floppy disks to start Setup. During Setup, you will be prompted to insert the Windows XP CD. For more information, see "Create boot disks."
Otherwise, you can use a Windows 98 or Windows Millennium Edition Startup disk to start the computer, and then run Winnt.exe from the i386 folder of your Windows XP CD.
1. The Smartdrv.exe tool will speed up the process of copying files from the CD to your hard drive. To use the Smartdrv.exe tool, make sure the Smartdrv.exe file is present on the startup disk.
If you do not have Smartdrv.exe, file copying will take much longer but it can still be done successfully. Verify that the following entries exist in the following files on your startup disk; add the entries if they do not already exist:
In Autoexec.bat, add this line:
smartdrv.exe
In Config.sys, add this line:
device=himem.sys
Note: For information about modifying the Config.sys and Autoexec.bat files, see Microsoft Knowledge Base article 232558.
2. Insert the startup disk into your computer's floppy drive, and restart the computer.
3. When the DOS prompt appears (it looks like this: C:>), type the following lines, pressing ENTER after each one. Substitute the drive letter of your CD-ROM drive for the letter D, if yours is different.
D:
cd \i386
winnt
When Setup begins, follow the prompts on your screen.
sfatul meu este sa copiezi kitul (folderul i386) pe partitia D: (daca poti sa accesezi) si sa pornesti de acolo instalarea
hai ca iti explic eu pas cu pas :d:D bagi discheta bootabila de 98 ii dai sa iti booteze cu cd-rom chiar daca nu ai :d iti incarca bla bla.... dupa ce termina iti apare A:\ da??...... k, scri Smartdrv.exe..... dupa asta dai D:\unde ai tu kitul\i386\winnt .....bun, incepe copierea filelor il lasi ca sta mult .... cand tremina scoti discheta dai restart si nu o mai bagi ...... si el o sa inceapa Setupul propriu zis nu are voie sa stea dupa ce copiaza filele pe hdd... daca sta si nu intra in setup ar putea fii o problema hradware la el tu pana la urma nu poti sa desfaci calcu??? ar fii cel mai usor ..... bagi un cd-rom normal + un cd bootabil si gata :d
Sal , cu ajutorul lui Papi_Eib am reusit pina la urma sa bag Xp pe Dell sx 270 :doh: problema era ca pe undeva ..alegea sa buteze in linux ... si-mi dadea o eroare , am reusit sa bag Xp am reusit sa bag placa video on bord dar :doh: nu-mi merge sunetul ... PLS Help ... Everest zice urmatoarele :Analog Devices AD1981B(L) @ Intel 82801EB ICH5 - AC'97 Audio Controoler , am incercat cu Papi_Eib sa bag 2/3 variante de sunet dar nu a mers :doh: daca este cineva sa ma ajute ca atit mai am si eu de bagat :woot: sa ma pot si eu bucura de aceasta unitate draguta ... ;) seara este super aproape ca nu se aude nimic ... asa este de silentioasa :naughty: . Atit mai am si eu ..pls help :)
:smt005 Cauta pe net ac97 codec. Vezi pe situl producatorului placii de baza. Eu la placa de baza folosesc driverele de la realtek (am chipset de la sis). Tu avand de la intel, s-ar putea sa trebuiasca sa instalezi unul facut de ei.
Gata am reusit sa rezolv .... problema era ca la boot incerca sa plece de pe vechiul Linux instalat ... eu am formatat HDD cu Part. Magic 8 ... dar la plecare incerca sa intre in Linux . Pina la urma se poate cu kit de xp instalat pe D intri cu disk. de 98 si din Xp dai sa plece cu ajutorul lui i386 ...initial din cauza ca nu gasea Smartdrv dura 2/3 ore incarcarea xp ... dar l-am bagat si acum unitatea este perfect functionala , merge super misto nici pic de zgomot ... :supz: MULTUMESC celor care au incercat sa ma ajute ... :smt006 :smt006 :smt006
