sistem fotovoltaic 50w
Vizitator nellu
Vizitator nellu
Buna ziua
As dori o parere despre acest sistem fotovoltaic, si bineinteles daca va functiona (sunt incepator).
Hidden text: ON
Available only to registered users.
Hidden text: OFF
Panou solar fotovoltaic 50w Monocristalin
Hidden text: ON
Hidden text: OFF
Manufactured in an ISO9001:2000 certified plant CE certified
Dimension 710x545x30mm)
Maximum Power (Pmax) 50Watts
Maximum Power Voltage (Vmp) 17.6V
Maximum Power Current (Imp) 2.86A
Open Circuit Voltage (Voc) 21V
Short Circuit Current (Isc) 3.2A
Maximum System Voltage 1000V
Temperature Coefficient of Isc 0.06% / degree C
Temperature Coefficient of Voc -0.397% / degree C
Temperature Coefficient of Pmax -0.549% / degree C
STC: Iluminare 1000W/m; Temperatura modul 25°C, AM=1.5
Regulator solar
Hidden text: ON
Hidden text: OFF
Total rated charge current 10A
Total rated load current 10A
System voltage 12V AUTO
Overload, short circuit protection 1.25 times the rated current for 60 seconds, 1.5 times the rated current for 5 seconds overload protection actions
>3 times the rated current of short circuit protection
Empty load loss
Charging circuit voltage drop Not more than 0.26V
Discharge circuit voltage drop ≤0.15V
Overpressure protection 17V
Invertor
Hidden text: ON
Hidden text: OFF
Invertor (convertor) 1000 W.
Carcasa metalica
Voltaj iesir: 220 VAC +/- 5% (priza normala).
Frecventa 50 Hz +/- 2 Hz
Putere consumata in gol (fara consumator): Randament (eficienta) maxim >90%
Forma sinusoidei de iesire: sinusooida modificata.
Putere maxima continua (constanta) pentru 30 de minute: 1000 W power output
Putere maxima continua (constanta) : 800 W power output
Varfuri de putere 2000W (pt. porniri)
Plaja de alimentare 10 - 15 V.
Alarma baterie descarcata 10,4 - 11 V.
Punctul de deconectare automata (baterie descarcata) pentru protejarea bateriei: 9,7 - 10,3 V
Punctul de deconectare supravoltaj la bornele bateriei: 14,5 - 15,5
Racire activa cu ventilator.
Protectie la: supra sarcina, baterie descarcata, supravoltaj, scurt circuit, temperatura ridicata.
Cabluri cu clestisori (crocodili) pentru alimentare direct de la baterie.
Acumulator auto
Hidden text: ON
Hidden text: OFF
Bosch 56Ah
  • Răspunsuri 7
  • pusttiu
  • Dr.L
  • rinaldoparaipan
Panou 50W cu invertor de 1000W si baterie AUTO de 56Ah....De functionat, va functiona, dar nu pentru mult timp(din cauza bateriei).Mai bine ne spui la ce vrei sa il folosesti , pentru o dimensionare corecta.
Vizitator nellu
Vreau sa fac acest sistem pentru ca pe timpul verii sunt plecat de acasa si nu am alte surse de energie electrica in apropiere.Vreau sa il folosesc pentru alimentarea a 2-3 becuri 12v 3w, radio; incarcat telefoane/acumulatori masina de insurubat; laptop; masina de gaurit 550w...probabil si un televizoram ales sa folosesc acumulatorul de 56Ah pentru ca il am cumparat
In functie de cat vei folosi bormasina si TV-ul, cel mai bine ar fi sa pornesti cu un panou de 100W, baterie cu gel de 200-250Ah, charger de 20-40A.E bine sa ai o rezerva de putere si eventual sa-ti maresti sistemul(adica inca o baterie, inca un panou).Si nu becuri auto, ci becuri cu LED.Bateriile auto nu au viata lunga in sistemele solare.56Ah x 12V=600Wh.Adica cam jumate de ora de functionat bormasina.Ca sa nu omori bateria.Daca le folosesti cand e soare afara, ar mai merge.Da-mi un pm ca sa-ti recomand ce si de unde sa iei.
bn ziua, ca sa nu va complicati cu invertorul , de banii de invertori mai bn luati un tv lcd cu alimentare la 12v , sunt destul de multe modele pe piata de sh si noi de diagonala 40-66cm. sigur este vb de becuri cu leduri de 12V si 3w, va recomand lumina calda, diferenta intre doua becuri la fel este enorma in locuinta( am eu acasa si e cam cit un bec de 60w cu filament) se vede mult mai bn decit o rola intreaga de banda cu leduri de 5m si 20w. la fel cu bormasina..... acumulatorul o sa va tina 2 ani daca il folositi numai in tampon cu regulatorul, daca il descarcati separat.....moare rapid. oricum cu un panou de 50w nu incarcati intr-o zi bateria dvs de 56Ah, tineti cont ca panoul nu lucreza la puterea maxima tot timpul zile...poate nici 1ora ca acea putere e data in anumite conditii de temperatura, iluminare, inlunatii, etc etc multa barbologie care e mai mult comerciala decit reala. eu calculez 75%din ce zice pe panou si tot is la limita.succes, poze vrem poze sa vedem ce iese.
