ajutor porti automate cu pic
tomaur
  • Răspunsuri 181
  • tomaur
    66
  • costi002
    59
  • ROBERT78
    10
  • q_acdc
    8
se poate rezolva, dupa ce am citit din germana cu google translate asta ar spune daca clipeste ledul de pe placa, cauta un manual si vezi ca spune cum se reprogrameaza,
traducere:
Commissioning and learning process for the end position of the wing at the FA G 2601 / EFA 1200
The learning process is always enabled after you exit the installation mode (the red LED next to the teach-in button flashes), therefore the short press can account for in this case the learn button.
The flashing of the LED in the learning mode, 2601 FA G / EFA 1200
  Adjust the position of the wing
  • [*]Turn on power [*]Short press (less than 1 second) on the learning button (learning) to start the learning process [*]LED flashes
Setting the final position in the learning process for drive 1 One drive is called drive 1, which must first open on the basis of the mechanical structure of the wing gate. This depends on the lock of the door. This drive must be connected to the connector for motor 1 on the Control Board.
    Setting the final position for drive 1
  • [*]Press CLOSE (start) button until the end position is reached to [*]Key learning 2 seconds press [*]LEARNING LED stays on for about 2 seconds and flashes again [*]Press the OPEN button as long as until the end position on reach [*]Key learning 2 seconds press [*]LEARNING LED lights up for 2 seconds and flashes back further (continuation end position for drive 2)
Setting the final position in the process of learning to drive 2 One drive is called drive 2, which must be open on the basis of the mechanical construction of the wing gate last. This depends on the lock of the door. This drive must be connected to the connection to motor 2 on the Control Board.
  Setting the final position to drive 2
  • [*]Press CLOSE (start) button until the end position is reached to [*]Key learning 2 seconds press [*]LEARNING LED stays on for about 2 seconds and flashes again [*]Press the OPEN button as long as until the end position on reach [*]Key learning 2 seconds press [*]LEARNING LED goes out if everything is OK (see photo) below for status display LED
nu mai pot sta in seara asta, vezi daca clipeste in un anume fel, fotocelulele -daca sunt- lucreaza, mai caut si eu in limita timpului disponibil, nu ai spus in ce localitate sunt portile
  • 2 săptămâni mai târziu...
Sal revin iarasi si cer ajutorul celor care au dezvoltat acest proiect
deci tot am incercat sa dau de capat cu placa pe care o am dar se pare ca e mort nu mai asculta nici o comanda
am scos motoru si are inca o placa micuta care e alimentat cu 12v si acesta cred eu prin impulsuri schimba directia de rotire a motorului care e 24vdc
am incercat motoru fara aceasta placa doar cu cele doua fire ce iasa din motor inversind firele intre ele se schimba rotatia
Intrebarea mea este daca pot sa o leg la placa dezvoltata aici cu modificari pe placa sau soft sau nu e nevoie de modificari?
Multumesc anticipat
Salut,
Daca ai motoare de cc care isi schimba sensul de rotatie la schimbarea firelor intre ele, foloseste ultima schema si ultimul soft.
Daca nu face ce iti doresti, da de veste.
  • 3 săptămâni mai târziu...
  • 4 săptămâni mai târziu...
  • 7 ani mai târziu...
