ceas cu pic
Vizitator H4cK3r
Vizitator H4cK3r
Buna seara!
Pentru a invata cum functioneaza timer-ii si intreruperile, m-am decis sa-mi fac un ceas.
//microu config#pragma config PLLDIV = 5#pragma config CPUDIV = OSC1_PLL2#pragma config USBDIV = 2 #pragma config FOSC = INTOSCIO_EC#pragma config FCMEN = OFF#pragma config IESO = OFF#pragma config PWRT = OFF#pragma config BOR = OFF#pragma config BORV = 3#pragma config VREGEN = OFF#pragma config WDT = OFF#pragma config WDTPS = 32768#pragma config CCP2MX = ON#pragma config PBADEN = OFF#pragma config LPT1OSC = OFF#pragma config MCLRE = OFF#pragma config STVREN = ON#pragma config LVP = OFF#pragma config ICPRT = OFF#pragma config XINST = OFF#pragma config DEBUG = OFF#pragma config CP0 = OFF,CP1=OFF,CP2=OFF,CP3=OFF#pragma config CPB = OFF#pragma config CPD = OFF#pragma config WRT0 = OFF,WRT1 = OFF,WRT2 = OFF,WRT3 = OFF#pragma config WRTC = OFF#pragma config WRTB = OFF#pragma config WRTD = OFF#pragma config EBTR0 = OFF,EBTR1 = OFF,EBTR2 = OFF,EBTR3 = OFF#pragma config EBTRB = OFF//include#include<p18f4550.h>#include<timers.h>//cifreint catod[4]={14,13,11,7};int anod[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//prototipurivoid high_ISR(void);void interruptcode(void);void afisare(void);void time(void);////#pragma code HIGH_INTERRUPT_VECTOR = 0x000008	void high_ISR(void){	_asm goto interruptcode _endasm}#pragma code////////////////////////#pragma interrupt interruptcodevoid interruptcode(void){		if(PIR1bits.TMR2IF == 1){		//timer2 flag			PIR1bits.TMR2IF = 0;			afisare();				}		if(PIR2bits.TMR3IF == 1){		//timer3 flag			PIR2bits.TMR3IF = 0;			time();						}}#pragma code//varint i=0,count=0;int h=10,m=59;//mainvoid main(void){  	OSCCONbits.IRCF2 = 1; //seteaza ceasul la 1MHz  	OSCCONbits.IRCF1 = 0;  	OSCCONbits.IRCF0 = 0;	T2CONbits.TMR2ON = 0;	//opreste timer2	T3CONbits.TMR3ON = 0;	//opreste timer3	ADCON1bits.PCFG3 = 1;	//toate pin-urile digital	ADCON1bits.PCFG2 = 1;	ADCON1bits.PCFG1 = 1;	ADCON1bits.PCFG0 = 1;	RCONbits.IPEN = 1;	INTCONbits.GIE_GIEH = 1;		//timer2 config	T2CONbits.T2CKPS1 = 1;	//prescale 1:16	T2CONbits.T2CKPS0 = 1;	T2CONbits.T2OUTPS3 = 1;	//postscale 1:16	T2CONbits.T2OUTPS2 = 1;	T2CONbits.T2OUTPS1 = 1;	T2CONbits.T2OUTPS0 = 1;	PR2 = 2;  //registru periodic	PIE1bits.TMR2IE = 1;	//enable timer2	IPR1bits.TMR2IP = 1;	//end timer2 config	//timer3 config	PIE2bits.TMR3IE = 1;	IPR2bits.TMR3IP = 1;	T3CONbits.T3CKPS1 = 1; //1:4 prescale	T3CONbits.T3CKPS0 = 0;	T3CONbits.TMR3CS = 0; //fol clock-ul intern	//end timer3 config	TRISB = 0;	TRISD = 0;	T2CONbits.TMR2ON = 1;	//porneste timers	T3CONbits.TMR3ON = 1;	while(1){}	//loop infinit	}//functiivoid time(void){	if(i < 60)i++;		else i = 0;	if(i == 60)	 {	if(m < 60)m++;			else m=0;		i=0;	 }	if(m==60)	{  if(h<12)h++;			else h=0;		m=0;	}}void afisare(void){	if(count%4==0){		PORTD = catod[count%4];		PORTB = anod[m%10];	}	if(count%4==1){		PORTD = catod[count%4];		PORTB = anod[(m/10)%10];	}	if(count%4==2){		PORTD = catod[count%4];		PORTB = anod[h%10];	}	if(count%4==3){		PORTD = catod[count%4];		PORTB = anod[(h/10)%10];	}	count++;}
inca n-am pus butoane pentru minut/ora, insa am o problema cu afisarea cifrelor.
Posted Image
arata ca si cand cifra din urma este dublata pe urmatorul ecran, si nu inteleg de ce.aveti vreo idee ce-ar putea cauza asta?sa fie oare de vina metoda nu prea inteligenta de multiplexing?(acum afiseaza 10:59)
btw, g-ul de la 9 si 5 lumineaza ok, insa la b6 am conectat si g-ul dar si PGC-ul de la pic.daca scot mufa de la pickit2, g-ul se aprinde ok.
  • Răspunsuri 5
  • 10vid
Zile populare
Baga un delay de 5 ms in functia 'afisare', dupa cele patru if-uri, inainte de count++.Acele imagini "fantoma" apar din cauza ca e imposibil sa se schimbe in acelasi timp si catodul si anodul de la afisaj (eventual cu un uC de 16 biti). Astfel ca pentru scurt timp intre instructiunile: PORTD = catod[count%4]; PORTB = anod[.....];afisajul e gresit, iar intensitatea acelei parti e data de timpul mai sus amintit, raportat la timpul total al buclei, adica undeva la 1/10 din intensitatea totala, ceea ce e enorm.Cu un delay de 5 ms, acea parte va avea undeva pe la 1/1000 din intensitatea totala, la 4 MHz (dar in functie si de codul generat de compilator). Existenta, dar practic invizibila.O alta metoda, pentru a elimina complet problema, e stingerea catodului curent, incarcarea noilor anozi si aprinderea catodului urmator. Delay-ul ramane valabil insa si aici, pentru ca altfel s-ar introduce o diminuare inutila a luminozitatii, cauzata de acele stingeri.
Vizitator H4cK3r
am facut urmatoarele modificari:
//microu config
//include
#include
#include
//cifre
//prototipuri
void afisare(void);
void time(void);
#pragma code
afisare();
if(INTCONbits.TMR0IF == 1){ //timer0 flag
INTCONbits.TMR0IF = 0;
time();
#pragma code
//var
int i=0,count=0;
int h=0,m=50;
//main
void main(void){
OSCCONbits.IRCF2 = 1; //seteaza ceasul la 8MHz
OSCCONbits.IRCF1 = 1;
OSCCONbits.IRCF0 = 1;
T0CONbits.TMR0ON = 0; //opreste timer0
RCONbits.IPEN = 1;
//timer2 config
PR2 = 0; //registru periodic
//end timer2 config
//timer0 config
INTCONbits.TMR0IE = 1;
INTCON2bits.TMR0IP = 1;
T0CONbits.T08BIT = 0; //16 bits
T0CONbits.T0CS = 0; //fol clock-ul intern
T0CONbits.PSA = 0; //fol prescale
T0CONbits.T0PS2 = 1;
T0CONbits.T0PS1 = 0;
T0CONbits.T0PS0 = 0;
//end timer0 config
TRISB = 0;
TRISD = 0;
T0CONbits.TMR0ON = 1;
//functii
void time(void){
if(i < 60)i++;
else i = 0;
if(i == 60)
{ if(m < 60)m++;
else m=0;
i=0;
if(m==60)
{ if(h<12)h++;
else h=0;
m=0;
void afisare(void){
if(count%4==0){
PORTB = anod[m%10];
if(count%4==1){
if(count%4==2){
PORTB = anod[h%10];
if(count%4==3){
Delay100TCYx(50);
PORTD = 0;
PORTB = 0;
count++;
insa acum, dupa ce trec 2 minute, ramane aprins doar primul display, celelalte se inchid de tot.ai putea te rog sa-mi explici de ce?
Vizitator H4cK3r
oricum, mersi mult 10vid pentru ajutor, nu stiu cum faci dar tot timpul ai o explicatie pentru orice :)).cu modificarile facute, display-ul este luminos si afiseaza cum trebuie, mai trebuie insa sa rezolv bug-ul cu disparitia cifrelor dupa 2 minute.
Vizitator H4cK3r
am depistat problema.am uitat ca acel count e un int si are si el o valoare maxima, care dupa doua minute trecea de valoarea aia si avea niste valori aiurea(negative cel probabil)
if(count<4)count++;		else count=0;
codul de sus a remediat problema.
  • 3 săptămâni mai târziu...
