11 AK 28-6 TV DEFECT.
  • Răspunsuri 4
  • valioval
  • dan-a2
  • dan cod
  • leoncris
Zile populare
ok, multumesc cu schema am rezolvat si tv ul . Belea si cu smd urile astea! Dar de tv NEI N20 S4XM model20 txt stiti cum se intra an service mode am schimbat deflexia si are imaginea mai scurta?
NEIul asta nu-i cumva cu TDA8362 si atunci reglajele se fac din semireglabili.Pentru dimensiunea orizontala umblii la condul de cuplaj eventual la condul de recuperare,strapezi bobina de liniaritate etc.
Sasiu PT90,92.The service menu is entered by pressing the key on the RC and VOLUME-DOWN key on the TV simultaneously when the TV is in TV- mode. The service menu is left by pressing the key.When entering the service mode the first menu item is IF (selection of normal IF). Next items can be selected using the keys and . The value of each item can be changed using the keys and. The item values are displayed as decimal values, except for the tuner-band-selection, BITS and optionitems.They are displayed as hexa-decimal values. All values are stored in non-volatile memory when the service menu is left. The“INIT CTV832U” item initializes the NVM: It clears all names and tuning information of all programs and writes default values for the service alignments and preset values in NVM. While doing so, the OSD displays “BUSY”. When the initialization isfinished, the message “READY” is written on the screen.Item DefauIt ExplanationIF 38.9 IF selection (58.8, 45.8, 38.9 or 38.00 MHz)IFL1 33.9 IF for SECAM-L1 selection (33.4 or 33.9 MHz)HP 31 Horizontal parallelogramHB 31 Horizontal bowEW 37 East-west Width for picture setting 16:9PW 18 East-west Parabola for picture setting 16:9UCP 13 East-west Upper Corner parabola for picture setting 16:9LCP 13 East-west Lower Corner parabola for picture setting 16:9TC 28 East-west Trapezium for picture setting 16:9HP4:3 31 Horizontal parallelogram for picture setting 4:3HB4:3 31 Horizontal bow for picture setting 4:3EW4:3 45 East-west Width for picture setting 4:3PW4:3 15 East-west Parabola for picture setting 4:3UCP4:3 35 East-west Upper Corner parabola for picture setting 4:3LCP4:3 25 East-west Lower Corner parabola for picture setting 4:3TC4:3 31 East-west Trapezium for picture setting 4:3HS 31 Horizontal ShiftVS 31 Vertical SlopeVA 31 Vertical AmplitudeSC 31 S-CorrectionVSD off Vertical Scan DisableVSH31 Vertical ShiftVX 25 Vertical zoom (East-west only)BLR 7 Black Level RedBLG 7 Black Level GreenWPR 31 White point correction RedWPG 31 White point correction GreenWPB 31 White point correction BlueYs 15 Y-delay adjustment for SECAMYn 8 Y-delay adjustment for NTSCYP 0 Y-delay adjustment for PAL
